Old Oct 19, 2012, 07:59 AM
hondarc51 is offline
Find More Posts by hondarc51
Joined Oct 2012
Servo motor controls
Hello all, I am new to the forum and was hopping to be able to pick some brains about an idea I had using waterproof servo motors. What I am trying to accomplish is using servo motors to control the throttle and choke on a gasoline engine thats on a power unit in the bed of my truck. I would like to have it wired though, aka non wireless. I'd like to be able to control the servo motors with a toggle switch for easy adjustment of throttle and choke inside my truck cab. Also the servos I found are 6v and the system I have is 12v but I believe that is solved using a Bec. I hope someone can point me in the right direction!! Regards, Tom.
hondarc51 is offline Find More Posts by hondarc51
Old Dec 06, 2012, 02:37 PM
goly is offline
Find More Posts by goly
Joined Nov 2012
12V to 5V- you will need to use 7805 to get the voltage fit for the servo and the electronic card
with the use of 555 you can create circuit that will
1) send cmd to the servo to the position needed
2) toggle/pot switch to send the cmd you want
done in 5min if you need better exp' tell me
goly is offline Find More Posts by goly
Discussion Using old servo control boards as actuator driver/motor ESC for PROPORTIONAL control EQMOD Electric Power Cars 13 Dec 30, 2014 05:51 AM
Discussion Servo motor controls hondarc51 Car Talk 1 Oct 26, 2012 09:03 AM
Help! Push button Servo controller for digital servo ? garrcass Electric Plane Talk 3 Jul 28, 2012 04:49 AM
Prog. JR8103 for motor control+4 servo wing nadt770 Electric Sailplanes 8 Feb 22, 2002 06:14 PM
Servo Tester ccts for motor control steve lewin Control Line 1 Apr 26, 2001 07:40 AM
