This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Old Oct 19, 2012, 12:56 AM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
Frank's Models summary
Below are almost all of the scratch builds I've done. Rocket boosted at the top and pusher parkjets below. If there is something here that you really are interested in, let me know and I'll see if I can get you a pdf of the plans/templates if I made them.
Here are some results of how the models flew, out of 64 built, just a few failures, and a few that had initial flight problems but were solved...If there are no notes, they flew fine off the board.
Avro Arrow
X-15: 5 versions, aileron/tail, taileron only, Full fuse, Delta configuration. 72" 29mm version
Small F-106
Large F-106
F-100
F-101
F-102
F-104
F-105 Small and larger
F-107 Ultra Sabre
XF-92 Dart
F-4 Phantom
Bomarc: 4 versions, A model, B model, 29mm 72" B model, 68" A model for G-12's
Bomarc A: with ramjet tractor motors, too heavy for 24mm motor, motor thrust was marginal on tractors, wind blew pad over on last test flight and destroyed model
XF-91 thunderceptor: Used 18mm and 24mm airstart plus pusher, worked great.
Space Shuttle
Buran
Saab Draken: flew great, rolled like a drill, killed when a spektrum lockout occured when pointed straight down...
InteR/Ceptor(3 versions, two smaller 24mm and one 72" 32mm version)
Jayhawk(2 versions, 24mm and 72" 29mm version)
Mach 10
Mach 10(upscale): Suffered wing flutter and destruction on test flight
Goblin
Flapjack: Used differential throttle for yaw control, flew great
A-4B(2 versions)
B-58 Hustler
ME-163 Komet: Flew as pusher, tractor and also airstart 24mm, wing flutter problem if pushed too fast but othewise flew fine
Bachem Natter: First flight was tail heavy, adjusted and flew fine.
XFU-7 SuperCrusader or Crusader III
V-1 Buzzbomb Rocket boosted
V-1 Tractor: Suffered full flying tail reversal in flight due to improper pivot point for full flying tail, was able to land upside down with minimal damage, replaced tail with new pivot location(no more than 30% area ahead of pivot), and flew fine
Space Battleship Yamato
Tomahawk Cruise Missile:2 versions, 24mm and 60" 29mm version)
Delta Lifting body: Was too nose heavy on boost, not enough elevon throw to keep nose up on glide, damaged on first flight, not repaired.
X-1: flew as both a pusher and RC boost glider
X-1A
X-20 DynaSoar: 3 versions, 2 profile(first was damaged due to spektrum lockout), and full fuse
SR-71: 2 versions, pusher and rocket boost only
BAc Lightning
X-13 Vertijet
X-24A: 2 versions, rocket boost and pusher
X-3 Stilletto: 2 versions, rocket boost and pusher(was laterally unstable on first flight, crash broke off vertical stab, replaced stab with 50% larger version, flew fine.
Spaceship One
Cutlass
Vigilante
X-37: Several flights, none had full control due to wing blanking the V tail controls and very sensitive to post boost CG shift, not a success. Converted Fuse into Buran Space shuttle
Not shown:
B-2
F-117: 3 versions, first two had lack of stability issues due to minimal intertial damping(motor mounted too close to CG). Moved motor back and reduced forward fuse profle and flew fine.
burkefj is offline Find More Posts by burkefj
Old Dec 04, 2012, 08:52 AM
OldeWolfe is offline
Find More Posts by OldeWolfe
Airplane Nut
OldeWolfe's Avatar
United States, CA, Ramona
Joined Oct 2008
Holy Moly! Where do you keep 'em all?
OldeWolfe is offline Find More Posts by OldeWolfe
Old Dec 04, 2012, 01:46 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Rafters of the garage, and in the closet of the spare bedroom....and some hanging in the office downstairs.....Some I've given away....
Frank
Old Jan 02, 2013, 06:41 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
Some of the other models I've built/flown:
World Models Mustang with .45 ST
World Models Zero with .45 ST
GWS A-10
Hobby Lobby F-18 Blue Angels
Alpha F-86
Alpha Mig 15
T-45 Goshawk
Parkzone J-3
Great Planes J-3 .15 size
Midwest aerolectric
Gentle Lady
Sig Riser
Sig Hummer
Kwik Fly
GWS B-2
E-flite P-38
E-flite P-47
Electrifly Fokker DVII
Electrifly Fokker Dr1
Sopwith Camel
Midwest ElectricHots
E-flite Airliner
Blade CX-2
eflite T-28
eflite Cessna 172
Goldberg Eaglet 50
Hobbylab SR-71
Sig Jenny
electrifly seawind
Das Electric Stick
Das Blue Max
World Models Rare Bear
World Models Voodoo
World Models Miss America
World Models September Fury
Sold Page Aviation GeeBee R2 plans and plastics Hemikiller Aircraft - Electric - Airplanes (FS/W) 3 Nov 12, 2012 07:05 AM
Discussion "I'll be Damned! We're Republicans!" - Most Powerful Speech of the Night Highflight Life, The Universe, and Politics 55 Aug 30, 2012 04:50 PM
Discussion Composite scratch build plans pages? jim2wright Composites Fabrication 4 Aug 21, 2012 05:55 AM
Found will be re-listing as a complete set-up TX/RX/4 S3001 BB servos, etc. crosby Aircraft - General - Radio Equipment (FS/W) 0 Jun 12, 2012 07:52 PM
