Old Oct 18, 2012, 09:14 PM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
Sweptback V-Tail Design
Here are just a few photos of my new sweptback V-tail. I wanted it to look fast even if it's sitting still. What do you guys think?
Description: Name: Picture 2.jpg
Description: Name: Picture 6.jpg
Description: Name: Picture 4.jpg
Description: Name: Picture 1.jpg
Description: Name: Picture 5.jpg
Description:
Some of my ideas I wanted to realize where...
Dual rear motor/prop pair should match thrust, and draw of each front rotor,
Dual rear prop pairing should be as close as possible to the same tip-to-tip span as each front props length, (rear span is 12", front props are 11" )
Center of all rotors/hubs should be equidistant from center of frame, so that the FC is at center of the rotational axis,
Fast yaw rate,
And finally, it must look menacing!
SPECS:
Flight Controller) KK2 (firmware V1.1) V-tail mix ( with reversed rudder outputs in mixer editor )
Props) 11x4.7 front, 7x3.5x3 rear
Motors) Turnigy AIR (L2215J) 900kV front, Turnigy AIR (L2210A) 1650kV rear
ESCs) HK-F20A x4 ( stock firmware )
LiPo) Nano-Tech 2200mAh 35-70C
heli-yeah is offline Find More Posts by heli-yeah
Old Oct 18, 2012, 10:02 PM
www.ParkFlySac.com
subaru4wd's Avatar
United States, CA, Rocklin
Joined Aug 2012
I am planning on converting my tri-copter into a V-Tail. Can you get some close-up pics of the tail mounted to your rear arm??
Great build btw! Any plans of some video of it in flight?
subaru4wd is offline Find More Posts by subaru4wd
Old Oct 19, 2012, 12:02 AM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Tail mounts look tig-welded to the rear boom. I want to know more of the rigs vital statistics if you please.
Granted is offline Find More Posts by Granted
Old Oct 19, 2012, 12:06 AM
www.ParkFlySac.com
subaru4wd's Avatar
Joined Aug 2012
I dont see any weld beads. It appears as if the rear V Plate enter the center of the rear arm, and are bolted on in some way.
Old Oct 19, 2012, 12:38 AM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
You're right, I was looking at the top-down shots.
Old Oct 19, 2012, 01:47 AM
United States, KY, Springfield
Joined Jul 2011
im a bit curious on what settings is used for a v-tail setup on the control board? is there a setting in the firmware for v-tail or does it just use a quad-x configuration?
thanks...
magic_marty is offline Find More Posts by magic_marty
Old Oct 19, 2012, 02:55 AM
disproving Newton
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
thanks...
I believe Y-4 config is used.
Old Oct 19, 2012, 07:46 AM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
@ subaru4wd
I hope to get some flight footage up soon... Here are a some pics of the tail. ( I still need to do some trimming, and add another bolt )
Description:
The V-arms are bolted to the tailboom, and I still need to work it up a bit for aesthetics... The whole frame in fact needs prettying up IMO!
thanks...
The updated firmware for the KK2 (v1.1) has a pre-mixed V-tail option, I just had to swap the outputs to the rudder, I have added some SPECS to the first post.
Old Oct 20, 2012, 02:39 PM
Enjoy Life B4U Die!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
Love the craftsmanship & design - best of luck with the maiden
Buzz_Man is offline Find More Posts by Buzz_Man
Old Oct 23, 2012, 07:18 AM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
Here is some video I got of a hover session in my front yard. The neighborhood kids showed up so I had to cut it short.
The video quality is crap (sorry), but you can still get an idea of the flight, and handling characteristics of my build.
Custom Sweptback V-Tail Multi-rotor (2 min 18 sec)
Old Oct 23, 2012, 08:59 AM
Matt Chester's Avatar
Newnan, GA
Joined Oct 2002
Is it dipping when you apply yaw control? How would you compare the flight characteristics to a standard Tri copter?
Matt Chester is offline Find More Posts by Matt Chester
Old Oct 23, 2012, 09:39 AM
Joined Sep 2012
Very cool. I've been gathering parts to do something very much like this. I was going to run 11 or 12's in the front, and dual 5's in the rear. I was calling it an asymmetric v-tail.
Looks like you beat me to it! Very cool.
edit:
Couple of thoughts... 3 blade props in the rear huh? I'm going with a 5x3 2 blade prop for the rear. Have you played with the angle of the V much? What do you think the weight split is? I was planning on weighting mine so the bulk of the weight will be on the front, larger props, and then tail would carry relatively little weight.
Ducati777 is offline Find More Posts by Ducati777
Old Oct 23, 2012, 09:50 AM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
Yes a little! I will mix it out at some point.
IDK, I have never flown a Tri-copter.
Old Oct 23, 2012, 10:06 AM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
edit:
Thank you!
I will be trying some 7" 2-blade props when I can make another order to GLB.
I have tweaked the V angles slightly inward, and outward, but I think it flies/yaws well at 90*, so I will leave it as is for now...
I'm not sure about the weights, but with mindful placement of electronic, and some beefier front arms (1/2" C-channel, instead of the current 3/8"), the CG should arrive at dead center.
Old Oct 27, 2012, 12:27 PM
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
Here is another video! This one is a little better quality than the first, and shows more of what this thing is capable of. Enjoy!!!
V-Tail Tri-copter Testing (7 min 12 sec)
Sold Stratos SL V-Tail, Receiver Ready w/wing bag/fuse bag & V-tail covers $400 LPU LowWatts Aircraft - Sailplanes (FS/W) 5 Aug 10, 2012 11:19 PM
Discussion Forward swept wing + V tail Design mixjsj Scratchbuilt EDFs 34 Aug 08, 2012 08:34 PM
Discussion Swept Wing Biplane/New Design Flyin' Happy Foamies (Scratchbuilt) 26 Jul 08, 2012 02:26 PM
Discussion Forward-swept wing + V tail Design mixjsj Scratchbuilt EDFs 22 Oct 20, 2011 08:08 AM
Discussion Merits of X-tail V T-tail V V-tail for visibility flyonline Slope 16 Mar 01, 2008 08:27 AM
