Old Dec 01, 2012, 03:39 PM
rustlererad3 is offline
Find More Posts by rustlererad3
Outdoor Extremist
rustlererad3's Avatar
Pennsylvania
Joined Jul 2010
this rig is awesome
rustlererad3 is offline Find More Posts by rustlererad3
Old Dec 05, 2012, 11:41 AM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Thinking of using this motor http://www.hobbyking.com/hobbyking/s...ner_Motor.html and this ESC http://www.hobbyking.com/hobbyking/s..._w_5A_BEC.html ALL comments good and bad are welcome. Thanks.
Dave8888 is offline Find More Posts by Dave8888
Old Dec 09, 2012, 06:04 PM
zozer is online now
Find More Posts by zozer
Steps? What steps?
zozer's Avatar
United States, TX, Humble
Joined Jan 2010
What are your speed goals? What voltage are you intending on using? That is a pretty small boat and will be stability-challenged with too much power. I'd aim for 15,000 rpm maximum on the prop speed, so for different voltages these are approximate Kvs and prop sizes:
2S = ~2000 rpm 9x6
3S = ~1350 rpm 10x5
4S = ~1000 rpm 10x6
Props are estimates from power calculators, the ideal prop for your application will depend on your packs, motor quality and ESC.
My latest 34" airboat runs 4S with a 13x6" prop on an older Scorpion 4020-8 motor I had laying around. I haven't tried to prop it for top speed, but it runs in the high 30s with the conservative prop. It uses a pair of .40-sized plane floats and a length of PVC pipe for the "fuselage". Two goals were to keep water out of the prop when running and keeping the airflow clean both into and out of the prop to maximize thrust and efficiency. Both goals were achieved. It looks a bit unconventional, but is not without precedent...
zozer is online now Find More Posts by zozer
Old Dec 09, 2012, 07:48 PM
Dave8888 is offline
Joined Nov 2011
Zozer, thanks for the input. It' a little under 24" and I was going to run a 1450kv motor on a 3S battery (this is what I already have). This is right in the range you are recommending. The prop I was thinking of a 9 x 6 APC, What do you think?. I would like it to run in the high 30's to low 40's mph.
Old Dec 09, 2012, 08:36 PM
zozer is online now
Steps? What steps?
zozer's Avatar
Joined Jan 2010
Depending on the motor's size and quality, that prop should give you around 4.4 pounds of thrust at 13,300 rpm and 50 amps, with a pitch speed of 76 mph. Your actual speed will be lower and totally dependent on cell quality and boat design/setup. I'd say it is a very good starting point.
Old Dec 10, 2012, 03:45 AM
Stretch1 is online now
Find More Posts by Stretch1
Happiness is a warm ESC.
Stretch1's Avatar
Ballarat Vic. Australia
Joined Jun 2008
2S = ~2000 rpm 9x6
3S = ~1350 rpm 10x5
4S = ~1000 rpm 10x6
G'day Zozer,
I like the concept! Where'd you source the floats?
Stretch1
Stretch1 is online now Find More Posts by Stretch1
Old Dec 10, 2012, 06:04 AM
zozer is online now
Steps? What steps?
zozer's Avatar
Joined Jan 2010
G'day Zozer, I like the concept! Where'd you source the floats?
They'd been sitting around for a couple years, I got them on-line at one of the airplane parts sites like Maxford RC.
http://www.maxfordusa.com/hz-40-fiber-floats.aspx
Old Dec 29, 2012, 06:55 PM
Dave8888 is offline
Joined Nov 2011
Now have the deck glued on, and the main sponson supports epoxyed on. Each of the main sponsons are going to be 1 1/2" further away from the tub then the plans call for to add a little more stability. Also received the rest of the parts for the back. The water intake on the rudder (for the ESC) is a little more then 1/2" below the rear sponson (doesn't look like that in the photo). I am finishing up with the waterproofing (Z-poxy finishing resin) on the deck. Will be about a week before I can get more wood and build the main sponsons, and then start painting.
Old Jan 11, 2013, 06:21 PM
Dave8888 is offline
Joined Nov 2011
Have the left main sponson built. Top still needs sanding. I was going to have 1 clear hatch cover all the way across the boat. I decided to make 2 for easier access to battery. They will still be clear. Because of balancing I am going to have to move motor stand from the back to the middle of the boat.
Old Jan 12, 2013, 12:56 PM
Amp Abuser is offline
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
This set up type for all out speed, sponson width helps cancel out prop torque.
Amp Abuser is offline Find More Posts by Amp Abuser
Old Jan 12, 2013, 01:02 PM
Dave8888 is offline
Joined Nov 2011
Your motor mount looks pretty cool. By sponson width do you mean how wide each sponson is or how far apart they are?
Old Jan 12, 2013, 09:40 PM
Amp Abuser's Avatar
Joined Dec 2007
Yes the natural design of a rigger having a wide stance up front, others have taken advantage of this with air props. Having the prop in the front of the CG of anything will increase stability allowing more speed in your case without blowing off the water. You should consider a vertical stab in the back if decide to over power the rigger. Say 1500watts as you have a ton of room in the tub for batts with room to move them in the right spot for a cg of 1.5 / 2in behind the sponson.
Notice in the vid a rigger with the prop behind the cg tends to cause adverse steering and of course enjoy a 75mph run with a brushless outrunner.
http://www.youtube.com/watch?v=BhbaulMN_Q8
Old Jan 21, 2013, 05:46 PM
Dave8888 is offline
Joined Nov 2011
Both front sponsons are now built and epoxyed on. The stance up front (inside of sponson to inside of sponson) is 3 1/2" wider then the plans call for (it's 13" instead of 9 1/2"). Amp Abuser, I am taking your advise and putting the prop in front of the CG. By moving motor stand more towards the front I can now adjust the CG from about 3/4" to about 3 3/4" behind the sponson just by moving the battery. The motor I will be using is 1450kv and 655watts. I will be using a 3S battery. I will run a 4S battery later. The prop is a 9 x 6 apc "style" electric. I am still playing around with adding a vertical stab (or 2 - 1 on each side of hatch).
Old Jan 21, 2013, 11:53 PM
Amp Abuser's Avatar
Joined Dec 2007
9x6 should shoot the rigger out of the hole with authority just the top end wont be as peachy. I would imagine you will bust 40 mph. Given the motor kv you should see 12k + at full pull on the striaghts. Can you source a metal shop an have them cut out you an aluminum motor mount?
Old Jan 22, 2013, 12:24 AM
Amp Abuser's Avatar
Joined Dec 2007
APC E 9x6
Build Log 1980 Outrigger with an Electric Outboard - Changed to Predator Outrigger w/outboard Dave8888 Racing Boats - Electric 22 Oct 08, 2012 07:15 PM
Found Outrigger Boat Plans "Predator" in a PDF File Dave8888 Boats (FS/W) 1 Sep 21, 2012 07:23 AM
Download Free outrigger plans (Predator 6-8 cell) Climate Racing Boats - Electric 7 Jun 22, 2008 03:01 PM
Video Extreme homemade outrigger airboat USAF Dock Talk 0 Nov 23, 2007 08:29 PM
