Old Oct 18, 2012, 06:37 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Build Log
Predator Outrigger Airboat
Thanks to everyone that helped with my other build log "1980 Outrigger with an Electric Outboard". You guys were a lot of help. I closed that build log. I am now going to build a "Predator" outrigger airboat. I have always wanted to build an outrigger and love how an RC airboat drives. First picture shows an outrigger airboat like I talking about. The 2nd picture shows what I have done so far. They are the tub sides. They are 1/8" plywood with 1/8" balsa doublers. (Blanket is making transom edge look jagged, they are cut straight). 3rd picture is a PDF file of the "Predator" outrigger.
Dave8888 is offline Find More Posts by Dave8888
Old Oct 20, 2012, 04:29 PM
Dave8888 is offline
Joined Nov 2011
Got the bulkheads (formers) cut. They are 1/8" plywood.
Old Oct 22, 2012, 01:24 PM
Dave8888 is offline
Joined Nov 2011
Bulkheads (formers) and transom are now glued in. I put in 2 extra formers (the little ones that go side to side) to make it a little more rigid. It still needs to be sanded. I forgot to drill hole through main former for wiring to go through. I will fix that.
Old Oct 26, 2012, 10:08 AM
Dave8888 is offline
Joined Nov 2011
The nose piece is now on, so are most of the balsa reinforcements (had to use square stock, hobby store was out of triangle stock). Bottom is skinned with 1/32" ply. This will be it for a couple of weeks, until I get supplies.
Old Nov 10, 2012, 03:18 PM
Dave8888 is offline
Joined Nov 2011
Rear sponsons are built and glued on boat. I had some sanding to do on one of the sponsons to get both sponsons even and square to the transom. Rudder arrived (it's not bolted on yet). Pictures are bad I know. I took them really fast because it started snowing.
Old Nov 10, 2012, 05:05 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
She is looking good.
Kcal is offline Find More Posts by Kcal
Old Nov 11, 2012, 01:17 PM
Dave8888 is offline
Joined Nov 2011
Thanks Kcal. I am building the hatch covers in a different way. It's 1 hatch cover from front to back. Hatch cover is thin clear plastic (a little thinner then the 1/32" plywood). Here is a close up picture. After I sand the front I will post a picture of the whole boat showing all of the hatch cover. The deck is not glued on yet.
Old Nov 11, 2012, 03:23 PM
Dave8888 is offline
Joined Nov 2011
Here it is with the clear hatch cover on. It's hard to see with all the glare. The deck is just taped down.
Old Nov 24, 2012, 03:17 PM
Dave8888 is offline
Joined Nov 2011
I changed the rear sponsons. I glued 1/32" plywood over them. I am trying to make it more of a flat bottom (remember this is going to be an airboat). I could have just taken rear sponsons off, but that would change the ride attitude of the boat (the transom would now be lower then it should be when on plane). Steering servo is also mounted. I am using a Hi-Tec HS-81 because that is what I already have.
Old Nov 25, 2012, 06:18 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Those rear sponsons look pretty tall, are the fronts that deep below the hull too?
wparsons is offline Find More Posts by wparsons
Old Nov 25, 2012, 10:59 AM
Dave8888 is offline
Joined Nov 2011
Here is the PDF file, so you can look at it. I copied it so that the boat is 23 1/2" long. If you lay the boat on top of the plans, the rear sponson is 1/16" taller (below the bottom of the hull) then it should be and a little less then 1/16" longer (past the transom) then it should be. In the picture I agree, the rear sponson looks HUGE. Now let me ask you, should I make the front sponsons 1/16" bigger? Or is that difference little enough not to worry about?
Old Nov 26, 2012, 06:32 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I would make the fronts 1/16" taller (or just drill the holes so they sit 1/16" lower) to keep the hull flat. I didn't realize that the bottom curves up so much which is why the rears look so tall.
Old Nov 29, 2012, 06:26 PM
Dave8888 is offline
Joined Nov 2011
Now have the motor stand built. It is just sitting on the boat not glued on yet. I am planning on using a 9" prop. I am going to wait until I get the motor before I make motor mount "plate" and glue everything together. Inside of boat is sealed and painted. Boat is going to be white with green sponsons and green inside.
Old Nov 29, 2012, 06:29 PM
Dave8888 is offline
Joined Nov 2011
The holes are already drilled in the tub, so I am going to drill holes 1/16" higher in the front sponsons, so they will sit lower. Thanks for the idea.
Old Nov 30, 2012, 09:52 PM
Kcal is offline
Joined Jul 2008
I like the green, good choice.
Build Log 1980 Outrigger with an Electric Outboard - Changed to Predator Outrigger w/outboard Dave8888 Racing Boats - Electric 22 Oct 08, 2012 07:15 PM
Found Outrigger Boat Plans "Predator" in a PDF File Dave8888 Boats (FS/W) 1 Sep 21, 2012 07:23 AM
Download Free outrigger plans (Predator 6-8 cell) Climate Racing Boats - Electric 7 Jun 22, 2008 03:01 PM
Video Extreme homemade outrigger airboat USAF Dock Talk 0 Nov 23, 2007 08:29 PM
