Old Oct 18, 2012, 06:25 PM
crd is offline
crd
Find More Posts by crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Build Log
Ultimate SWAT Style RC Car
I'm building myself a "Swat" wannabe rc car, just because I always wanted to have one, it will have the following installed.
VIDEO SYSTEM:
- 690TVL Ultra WDR Pixim SEAWOLF Camera (DAY CAMERA)
- 570TVL Pixim Videology Black/White Camera (NIGHT CAMERA)
- (2) IR Lamps 120 IR LEDs in total.
- 1.3ghz 1500mw Video TX
- 1.3ghz Custom diversity RX with Range Video diversity board
- R/C Video switcher for night/day camera
- OSD to monitor Volatges, Temps etc (still looking)
COMMUNICATIONS
- Motorola 5 watt UHF or VHF Radio, audio tx/rx will be controlled by R/C Radio
VEHICLE
Pride JET2HD Wheel Chair (4.5mph max)
Sabertooth 2x25amp ESC
(2) 12Volt, 55Ah AGM Batteries (battery range 25 miles per charge)
350lbs of pushing power (has torque like crazy)
(2) 10 watt LED lamps
(1) Emergency Kill Switch
I have a lot of work to do but the most difficult part "converting it to R/C is already done, the sabertooth ESC is EXCELLENT.
One of the things I will change later is the tires and if I find a good Thermal Camera on ebay, it will be installed too.
SORRY for the interference on the video, the RX was on the floor with the stock whip antenna in horizontal position, I'm building some cloverleaf and skew planar antennas tonight. ...........................OH YEAH This car is stealth, you can barelly hear the motors or wheels.
"Swat wannabe Spy Robot" (2 min 50 sec)
crd is offline Find More Posts by crd
Old Oct 18, 2012, 07:49 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Cool project. First Swatt FPV car
Are we free to propose idea
It miss a Tazer gun
VRflyer is offline Find More Posts by VRflyer
Old Oct 18, 2012, 08:04 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
It miss a Tazer gun
I have a stunt gun, .22lr semi-auto handgun, 12ga shotgun, 9mm and a 380. and I can possibly install a flame thrower but it will be illegal to install them on this
Old Oct 22, 2012, 09:17 PM
Sisco is offline
Find More Posts by Sisco
United States, ME, Skowhegan
Joined Sep 2012
That's pretty much my plan. An R/C electric wheelchair base with arduino and ping sensors (obstacle avoidance override) and perhaps light sensor to make it turn away from the sun (so I can install a solar panel on it's back for charging). I will also have FPV with headtracking via fatshark dominators. I also want an arm and collection basket.
Sisco is offline Find More Posts by Sisco
Old Oct 22, 2012, 09:20 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
CRD, you have the best ideas' dude....
can you give us some info on how you converted it to RC ?
once that is out of the way, the FPV part is easy! :-)
LexusFPV is offline Find More Posts by LexusFPV
Old Oct 22, 2012, 09:48 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
The big player here is the Sabertooth 2x25 , it was meant to be used on electric wheelchairs.
If you get a hold of this wheelchairs, you need to use AGM batteries, (car batteries wont last much and are a hazard)
1) the motors have 4 wires (2 for the motor and 2 for the magnetic brake) I removed the magnetic brake because the wheelchair motor gears by itself stops when the power is not present. the magnetic brake waste to much power when its in use and you have to add a relay etc etc. not worth it. Just take them out , very easy to do.
2) connect the motors to the Sabertooth, connect the battery to the sabertootk and the servo leads to your Radio receiver, do some easy calibrations and you are done.
I will add more info during the week.
Old Oct 22, 2012, 10:41 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
That is cool. Now you need a custom OSD with a antenna tracker to point your antennas back at the GS.
Martin Y is offline Find More Posts by Martin Y
Old Oct 23, 2012, 11:28 AM
LexusFPV is offline
Joined Feb 2011
crd,
how much money was that 'naked' wheelchair ?
can you give us a ball park figure on the price ? without the FPV gear?
PM me if you want:-)
p.s.
not to change the subject but, have you done testing on that ParkZone Radian motor pod?
thanks
Old Oct 23, 2012, 01:51 PM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
crd,
p.s.
thanks
I bought my wheelchair on a pawnshop for around $500 one battery was bad and I replaced both AGM batteries, at first I used tractor batteries but they died in less than a month of testing, AGM are sealed and last hours and hours of playing. The AGM batteries are not cheap tough.
I plan to built this "spy car" with good items and then sell it on ebay :-)
Something that I love about this wheelchair is that it gives me 20-25 miles per charge at 5mph and it will move a 350lbs person with ease.
As for the Radian pusher mount it will be tested hopefully tomorrow, I just finished installing my fpv gear to the radian.
Old Oct 24, 2012, 06:50 AM
LexusFPV is offline
Joined Feb 2011
crd
[/B]keep me informed, i'll buy one of each (wheelchair RC PnP, and your Radian motor pod mount)....I'm just iffy on the motor thrust angle. I'm not a expert on it (ie...WOT, it noses' down and vice versa).....
PM me when its on ebay please:-)
Old Oct 24, 2012, 06:54 AM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
crd
The motor mount will be adjustable, it will perform similar to the Easy Star, Bixler etc but with ability to adjust the angle.
Old Oct 24, 2012, 07:00 AM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
PS: I will be putting the chair back in the wheel frame and add a decapitaded maneequin for halloween and I will drive it around on halloween with my daughters
Old Oct 24, 2012, 07:50 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
This would be a good product to market as self-defense for disabled people in dangerous areas. Speach recognition for busting a cap. Steven hawkings patrolling the neighborhood.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Oct 25, 2012, 06:43 AM
LexusFPV is offline
Joined Feb 2011
crd,
I know the Summit Trucks are capable off roaders, but have you tried that wheelchair on other surfaces besides pavement and grassy areas'?....
p.s.
I like the 1.5hr runtimes:-)
Old Oct 25, 2012, 07:56 AM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
this is really cool - it seems like you have a ton of space too and with the weight handling capabilities you could put a small gas generator on it for extended operations lol...
chemnut842 is offline Find More Posts by chemnut842
For Sale The Ultimate RC Car Work Stand Wrecks Cars - Cars and Parts (FS/W) 5 Feb 03, 2011 07:28 PM
Yippee! RC Vehicle for SWAT use ultraking Car Talk 15 Feb 16, 2005 02:01 PM
