Old Jan 09, 2013, 07:26 AM
Ortho10 is offline
Find More Posts by Ortho10
United Kingdom, Bristol
Joined Nov 2010
Thanks TT, just had to Google denatured alchohol and it turns out to be...Meth's.
Have had a good supply of this in my cupboard all along, will let you know how I get on when I sheet the bottom half of the fuse.
Am suprised nobody had noticed the mistake on the front cover of the book in my previous post.
Ortho10 is offline Find More Posts by Ortho10
Old Jan 09, 2013, 03:55 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Its a Spitfire in Camouflage (Hurricane) so the Germans did not know how many Spits we had.
What a blunder
clive45 is offline Find More Posts by clive45
Old Jan 10, 2013, 01:20 PM
Ortho10 is offline
Joined Nov 2010
I know, this isn't getting the Spitfire built, but I found the explanation from the Author.
http://forum.keypublishing.com/showthread.php?p=1963331
Old Jan 31, 2013, 04:04 PM
Ortho10 is offline
Joined Nov 2010
Have now got my leading edges, (missing from kit) many thanks to Slough Radio Control Models, and Ripmax for getting these to me with no quibbles, great service.
Have been working on the centre section and am really pleased with the sheeting.
Hatch needs to be a bit bigger though.
My cheepie retracts are giving me a headache, am going to have to cut into rib 5 and epoxy in to position.
Ordered my motor and ESC today (more Turnigy I'm afraid) will post the item details and pics when they turn up.
Old Feb 03, 2013, 04:28 PM
Ortho10 is offline
Joined Nov 2010
Dry fitting the tailplane
Old Feb 04, 2013, 02:05 AM
jdlfreedom is offline
Find More Posts by jdlfreedom
jdlfreedom's Avatar
alberta
Joined Jan 2010
So I have not fallen off the earth!
I was in Mexico for dec and jan was a gong show.
In all of that I had gotten lots done on the spit. Fuselage is 95% done wings are done just waiting on the retracts so I can skin em and do the flaps and such.
I bench tested the power 90 on 6s with a 18x10 prop and was only making about 900 watts on my castle data logger so I'm thinking I either need a higher kv motor or run it on 8s...
jdlfreedom is offline Find More Posts by jdlfreedom
Old Feb 04, 2013, 03:20 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Or go to a 16x16 APC pattern prop. Should give you reasonable amp draw and lots of power AND speed. This is what I use on my 1/7 Sea Fury with a P110 and 7S.
TTRotary is offline Find More Posts by TTRotary
Old Feb 05, 2013, 03:00 PM
Ortho10 is offline
Joined Nov 2010
JDL, great to see all those bits of balsa begining to look like a Spitfire, those wing fillets look fantastic, any tips for me to get these right?
As far as your setup goes, I would have thought that 90 Watt/lb would give you pretty good performance from what I understand.
Old Feb 21, 2013, 04:22 PM
Ortho10 is offline
Joined Nov 2010
Progress so far, still waiting on Hobbyking.
Centre section finished.
Old Feb 23, 2013, 07:37 AM
Ortho10 is offline
Joined Nov 2010
Stringers now glued in to position, that fantastic shape now begining to reveal itself.
The bits I need to proceed have now been dispatched from the warehouse, happy days!
Old Mar 05, 2013, 04:54 PM
Ortho10 is offline
Joined Nov 2010
Have now finished sheeting the fuse, you can see from the fact that I didn't need any filler that this was an absolute breeze (and I'm showing you the good side).
For anyone else having a go at this kit, the cockpit floor is not as wide as it should be, so don't trim down former F4 and F5 to match the width of the cockpit floor, or you will be adding filler to restore the profile.
Onwards and upwards, have joined the wings now just waiting for those parts to arrive to complete.
Old Mar 09, 2013, 10:26 AM
Ortho10 is offline
Joined Nov 2010
Have now rounded the bottom deck, lots of tidying up to do.
Old Mar 19, 2013, 04:22 PM
jdlfreedom's Avatar
alberta
Joined Jan 2010
Update!!!
Whew been quite the last couple of months around here. I had a major flood that kind put a dent in my winter plane projects! House is almost all put back together now.
So here is where I'm at with the spit build.
Found a power system.
Got all the parts servos ect for it.
Finished the wood working.
Test fit the retracts.
Sorted out placement of ESC and battery in cowl.
Started glassing
FINALLY found a paint scheme to go with!
Old Mar 19, 2013, 06:08 PM
Ortho10 is offline
Joined Nov 2010
Looking good, how are you planning to access your battery?
That pilot also looks really good, where can I get one?
I'm really struggling with my retracts.
Oleos and slightly wider than standard wheels, have led to difficulties in getting the retracted wheel flush with the bottom of the wing.
Am going to have to bite the bullet and get the Robart items.
Will post some pic's so you can see the trouble I'm having.
Old Apr 06, 2013, 09:03 PM
jdlfreedom's Avatar
alberta
Joined Jan 2010
Light at the end of the tunnel!
Almost ready for paint!
Fiberglass is all done and mostly sanded and the control surfaces are covered.
I'm going to get all the gear in for some ground tests before I finish and weather it.
For the battery I made a tongue on the bottom of the firewall.
A gens ace 4400 mah 6s fits in the cowl perfectly.
The e flite's retracts are working great. I to got some 89mm
Fat wheels that are fitting well after shaving down some ribs
Very happy with the build thus far.
More to come.
Discussion Top Flite P47 Razorback Electric Conversion NCRealEstateGuy Electric Warbirds 54 Mar 10, 2015 06:03 PM
Build Log Top Flite P51 kit going electric haines74 Glow to Electric Conversions 30 Mar 21, 2013 12:44 PM
Help! Do you have a Top Flite Spitfire kit? gravityking Fuel Warbirds 0 Oct 08, 2012 08:39 PM
New Product Top Gun Park Flite Douglas C-47 Dakota ARTF Electric Warbird electricgeoff Electric Warbirds 9 Sep 12, 2012 11:59 PM
Discussion Sure Flite Spitfire electric conversion help celtic Electric Plane Talk 2 Aug 11, 2012 09:10 AM
