Old Oct 18, 2012, 05:59 PM
Ortho10 is offline
Find More Posts by Ortho10
United Kingdom, Bristol
Joined Nov 2010
Build Log
Top Flite Spitfire Electric Conversion
I can't find much info from anyone who has electrified a Top Flite Spitfire.
Am far from an expert when it comes to building, so gonna need some help with this one.
I'm two evenings in to the build and no major problems so far.
Have ordered some Hobbyking electric retracts, gonna need some Oleos.
The Turnigy G60 Brushless Outrunner seem good value, but are available in a number of different KV options(help needed here)
Am planning to run a 6s Lipo pack.
Ortho10 is offline Find More Posts by Ortho10
Old Oct 18, 2012, 07:14 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
TG 60 in 400Kv will work fine if you plan on using 6S or 7S. I run a 14x14 APC pattern prop on a Efl Power60 and 6S and it's a rocket. My plane is a WM .60 Spit, so it is probably lighter than your TF Spit will turn out, however. You may want to consider a Power90 as well or the Turnigy equivalent. Hobbyking's Plush 60 or 80 controllers are bulletproof and would work will with that motor. I personally use HK's 700MaH 2S LIFE packs for my RXs, rather than the BEC.
Try to build the tail as light as you possibly can and set up your cowl area so that the batteries will be as close to the motor as possible: if they are not almost completely inside the cowl area, you will need to add nose weight. Spitfires are notorious for building tail heavy. Keep in mind the TF kits are designed to withstand glo vibrations, so try to find areas where you can lighten up the build for electric. If it's like my TF P-51, it calls for flexy and heavy 2/56 rod inside guide tubes. Ditch that heavy setup in favor of carbon tube with 2/56 threaded pieces epoxied in. Much lighter and stiffer.
Try to set up your build so you do not have to remove the wing to change batteries. Consider adding a hatch to the top of the cowl, just behind the motor, so you can insert the 6S 5000 pack vertically. It should just fit in there. I started out at 25% MAC CG and just left it there. No bad habits and flies like it's on rails.
Because of this, make sure your wheels will be as far forward as possible. Consider moving the retract rails forward, angling the rails, or both. These planes are also known for nosing over quite easily when at the correct CG if you try to use scale landing gear location / configuration. Scale is nice but breaking props and worse is no fun.
Not sure I would rely on those HK retracts for this nice plane at this weight. I'd get the.60-120 Eflite electrics, which are much beefier, and mate them to the excellent RcSkylite oleo struts that hobbyking now sells.
Good luck with the build.
TTRotary is offline Find More Posts by TTRotary
Old Oct 18, 2012, 09:06 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
If you intend to run a 3 blade prop, \i just completed some testing on a SK3 5055-320. It makes 1100watts on a Master 16/10 and 1265 using a Graupner Gsonic 16/12, both on 6S.
Your G60 would likely handle a 15/10/3 bladed prop, but testing with a wattmeter is important, along with proper esc setup. fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Oct 19, 2012, 06:39 AM
Ortho10 is offline
Joined Nov 2010
Thanks Guys, some really useful information there.
Would love the E-Flite retracts, but the hobby fundís say no.
I know the margins are a little thin on the HK retracts; hope Iím not going to get an ďI told you soĒ at the end of this.
Retracts are in transit at the moment, will have a good look when they turn up.
Top Flite seem to have done a bit of work lightening the kit since the instruction were printed certainly in the tail area.
Still undecided about battery position, my initial thought was to build a ply battery compartment within the cowl and make an access hatch in the firewall, but of course this would involve removing the wing every time to remove the battery.
The idea of a hatch just in front of the canopy also doesnít appeal, gonna have to put the thinking cap on.
Very much like the look of the SK3 5055-320, seems to be a step up in quality.
Will stick with a standard prop, to be strictly scale the MKIX Spitfire has a four blade prop.
Thanks again.
Old Oct 19, 2012, 06:18 PM
Electrofish is offline
Find More Posts by Electrofish
United States, FL, Stuart
Joined Apr 2012
As per the retracts: I wouldn't be surpried if both brands were made at the same facility in China.
Same with electric motors. And batteries. And ESCs
And............................................... ........you name it.
To pay over twice the money for the same thing doesn't work for me.
Only my opinion.
Electrofish is offline Find More Posts by Electrofish
Reply With Quote  (Disabled)
Old Oct 21, 2012, 08:18 PM
KOMET 44 is offline
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Ortho10,Taking the wing off isn't as bad as you think.If you look at my blog you will see picture of my Focke Wulf Fw 190.Yes it's conciderd "OLD SCHOOL". Making a top hatch you'll need to get it rite the first time.Good luck.
stefanP
KOMET 44 is offline Find More Posts by KOMET 44
Old Oct 22, 2012, 08:57 AM
Ortho10 is offline
Joined Nov 2010
Komet, Did your FW190 balance out ok, or did you need to add some lead up front?
Old Oct 22, 2012, 05:47 PM
KOMET 44 is offline
D.G.B.
KOMET 44's Avatar
Joined Jun 2000
motor/flight pack.
I put my motor as far foward as possible then I mounted my receiver battery in the cowel area too.Yes I still use receiver battereis.My flight pack lies on a flat tray/ board.I can slide the pack forward or back if needed.I'll post some up close pictures of the planes power system.
stefanP
Old Oct 22, 2012, 06:01 PM
Ortho10 is offline
Joined Nov 2010
Getting on with it, will be a while before I get to the Electric bit though!
Old Oct 23, 2012, 06:06 PM
Ortho10 is offline
Joined Nov 2010
Big sanding job ahead, yes that is filler!
Old Oct 26, 2012, 08:31 PM
Pilatuspc12 is offline
Find More Posts by Pilatuspc12
Onward and upward.
Pilatuspc12's Avatar
United States, CO, Hotchkiss
Joined Oct 2006
Be careful, these are extremely tail heavy built as stock.
Pilatuspc12 is offline Find More Posts by Pilatuspc12
Old Nov 14, 2012, 05:17 PM
Ortho10 is offline
Joined Nov 2010
Things are progressing slowly.
Good to see the retracts are the correct size for the rails.
Old Nov 14, 2012, 06:15 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Hi Ortho
Bristol - nice place, poked around it a little, used to drive past it plenty in my RAF days near Weston Super Mare and Newquay.
Can't help on this kit, unless some electronic drooling helps, but the one thing I've found with 'electrocuting' any wet power model is to think ahead. You're going to fit a completely different drivetrain in there. Shape, weight, weight distribution, cooling, 'fuel lines', how to 'refuel' - anything else you can imagine, it'll be different.
Realizing this when looking at a finished model on your bench is not good
Will give you that this is not as much fun as gluing bits of wood into a Spitfire shaped object. Tough. Get your fuselage plan out and your motor, ESC and battery. Figure a way to mount your much shorter motor - firmly, too. A new, correctly located 'firewall' is far better than hanging your motor off the kit firewall than a cobbled together extension,, for starters.
Battery security and access comes next. A solid battery mount tray, Velcro's as good as it gets for security and if you're thinking of charging a big lipo in your model, go read throe sticky on lipo fires in the battery forum. The 'record' used to be shared by a guy's garage and a Lexus Landcruiser truck, both destroyed. So look up similar models to your Spitfire and figure out a battery hatch that let's you swap packs with the model right way up in the pits. Do not even think of taking the wing off to get at the battery
Added light weight is still the cheapest performance upgrade going. Two aspects. One, overall flying weight - lighter is always better. Two - avoid tail-heaviness, as it costs in dead weight ballast and hence higher RTF weight.
Structure. You are being smart and fitting a vibration free motor. A lot of your kit's structure is there to cope with a slimer thumping away.
Good luck. Am only slightly jealous...
D
Dereck is offline Find More Posts by Dereck
Old Nov 15, 2012, 06:31 PM
Ortho10 is offline
Joined Nov 2010
Hi Dereck
You must have been based at RAF Locking in Weston Super Mare.
My Dad was involved in decommissioning some of the equipment when the base closed.
Newquay is now the number one destination for Stag Weekends in the UK!
As far as the model goes, youíre absolutely right; Iím not going to be charging the Battery while itís in the model.
Iím leaning towards the idea of making a hatch/making part of the cowl removable, and retaining with magnets. Still have to purchase my motor/Batteries combination so no decision will be made until these are in place.
I have a couple of electric conversions under my belt (see my blog), and I have mounted the motor using the threaded rod/bolt technique. I think this model does deserve a bit more; extending the firewall is probably a bit beyond my skill set though!
Am really enjoying the building so far, thanks for you advice.
Old Nov 20, 2012, 04:14 PM
jdlfreedom is online now
Find More Posts by jdlfreedom
jdlfreedom's Avatar
alberta
Joined Jan 2010
subscribed!
I just started to build my top flite spit today. Going to power it with a e flite power 90.
Looking forward to your updates!
jdlfreedom is online now Find More Posts by jdlfreedom
Discussion Top Flite P47 Razorback Electric Conversion NCRealEstateGuy Electric Warbirds 54 Mar 10, 2015 07:03 PM
Build Log Top Flite P51 kit going electric haines74 Glow to Electric Conversions 30 Mar 21, 2013 01:44 PM
Help! Do you have a Top Flite Spitfire kit? gravityking Fuel Warbirds 0 Oct 08, 2012 09:39 PM
New Product Top Gun Park Flite Douglas C-47 Dakota ARTF Electric Warbird electricgeoff Electric Warbirds 9 Sep 13, 2012 12:59 AM
Discussion Sure Flite Spitfire electric conversion help celtic Electric Plane Talk 2 Aug 11, 2012 10:10 AM
