Australia, NSW, Bathurst
Joined Mar 2009
Turnigy H.A.L. (Heavy Aerial Lift) Hexacopter Frame
Might have to add this one to the collection I thinks...
I like the landing gear on this one , looks a lot stronger than the quad version. |
United States, LA, Shreveport
Joined Jun 2011
Pm me if you have updates or pics that will help others by posting on here on the first page.
![]() My Parts List: 1. HK HAL 775mm Hexacopter http://www.hobbyking.com/hobbyking/s...ame_775mm.html 2. Turnigy 2826 1200kv http://hobbyking.com/hobbyking/store...dProduct=26820) http://www.hobbyking.com/hobbyking/s...00KV_315W.html 3. 28 Series Motor Accessory Pack http://www.hobbyking.com/hobbyking/s...sory_Pack.html 4. 10x4.5 Slow Flyer Props, 3 clockwise 3 counterclockwise (IVE BROKEN SEVERAL OF THESE PROPS MID AIR, FIND SOMETHING ELSE FOR THE HEXACOPTER) http://www.hobbyking.com/hobbyking/s...ion_Blue_.html 5. HK Blue 30a escs, they will re-flash for simonk program. http://www.hobbyking.com/hobbyking/s...ontroller.html 6. HK Octo Distribution Board http://www.hobbyking.com/hobbyking/s...ion_Board.html 7. HK KK2 Flight controller http://www.hobbyking.com/hobbyking/s...rol_Board.html 8. HK Orange Receiver (For DX6i) http://www.hobbyking.com/hobbyking/s...Sat_Port_.html 9. HK Orange Receiver Satelite Port (better range & signal strength) http://www.hobbyking.com/hobbyking/s..._Receiver.html 10. HK Male to Male Servo Extensions (RX to KK2) http://www.hobbyking.com/hobbyking/s...0pcs_set_.html 11. Battery Mount (I forgot to order this part) http://www.hobbyking.com/hobbyking/s...unt_Plate.html 12. Battery 3000mah 20-30c 3s *PREFERENCE* Im going 3500mah+ on next battery http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html and 4000mah http://www.hobbyking.com/hobbyking/s...3S1P_20C_.html 13. Plastic Contol Board Mounting Accessories (Wish I had bought a couple packs of these instead of one) http://www.hobbyking.com/hobbyking/s...cer_10pc_.html and http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html Optional Parts: 1. LED's http://www.hobbyking.com/hobbyking/s...0pcs_set_.html 2. HK 3 Axis Camera Mount http://www.hobbyking.com/hobbyking/s...era_Mount.html Build Notes: 1. Landing gear may or may not fit together from the factory, do not try to force it together as it will easily get stuck in place requiring you to drill it out and start all over. Some people were able to use lubricating oil, but I used a 5/16" drill bit to make it slide together easy. The diameter of the legs are bigger than the diameter holes they cut for them to fit in. 3. On the motor-to-esc wiring I used 18 gauge wiring from radio shack. (Heat-shrink, Zip Ties, Blue Thread-Lock, Velcro) 5. Frame Alignment. See this before build to avoid taking frame apart multiple times http://www.rcgroups.com/forums/showp...5&postcount=22 6. Help for first timers on HEX wiring and KK2 basics. http://www.rcgroups.com/forums/showp...0&postcount=26 7. KK2 voltage sensor solder point. http://www.rcgroups.com/forums/showp...9&postcount=11 8. KK2 tuning guide http://www.rcgroups.com/forums/showthread.php?t=1675613 9. Multiple pics below from build. Flying Weight With No Battery: 1684 Grams / 3.71lbs
****ORIGINAL POST**** (12/3/2012) The bracing for the legs aren't drilled for the right sizing of the legs I'm gonna have to buy a drill bit and widen the hole to the correct size or sand the legs down thinner !!!!!!! Nearly tore up a legs trying to put them together hahaha. The rest of the kit is ok so far. This frame is stout. Arms have thickness to them. Seems like this is going to be a rigid aluminum frame.![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Joined Jun 2011
Gear Fix with drill bit persuasion. This is the only flaw in the whole kit. I used a 5/16" drill bit to make it right. If you try to put them together without drilling them and it starts getting snug.....its too late. Every move accumulates more and more aluminum so it wont slide backwards or forwards. In the end I ended up with good long landing skids and the stock ones are tiny
. So far id highly recommend this multi copter. Day maiden coming.![]() Wooden Gear (ca hardened) next to stock gear. I think the stock gear is too short and I will replace the wood with even longer carbon fiber skids. ![]() ![]() ![]() ![]() ![]() ![]() Cheap battery tray made of packaging tape. I forgot to order one but this should work for now. ![]() ![]() ![]() ![]() No Battery 1684 Grams / 3.71lbs. ![]() ![]() 1919 Grams Flying weight with Turnigy 3000mah 20-30c 3s. ![]() Led test and maiden came all at once lol. Led's are plugged straight into the power distribution board. Now i have one more 12v out from the power distribution board, which will be for the camera equipment. Self Level Off in video, I thought it would be a bad idea to maiden with self level on. I wanted to feel the trim which needed no adjustment.
Joined Dec 2012
Whaouh, very clean build
can you please post screens of kk2.0 with all your settings? PID gain, misc, this could help ofr adjusting our own heaxcopter? Do you think i can mount 6 turnigy 2217 16turn 1050kv outrunner? or these are not enough powerful? http://www.hobbyking.com/hobbyking/s...Outrunner.html |
Joined Jun 2011
I actually just started playing with the PID settings when I realized that I left my charger at home. I started out with stock settings but have since changed since I activated self leveling / dampening. I will post vids and pics when charger arrives later this week. |
| Thread Tools | |
| New Product Turnigy H.A.L. (Heavy Aerial Lift) Quadcopter Frame | kad | Multirotor Talk | 248 | May 06, 2013 09:44 PM |
| New Product HK H.A.L. (Heavy Aerial Lift) Quadcopter Frame 585mm | epyonxero | Multirotor Talk | 23 | Mar 19, 2013 11:15 AM |
| Sold Heavy Lift Hexacopter $300 | Grips | Aircraft - Electric - Multirotor (FS/W) | 14 | Sep 07, 2012 07:21 PM |
| Discussion Heavy Lift xAircraft Hexacopter in-flight video | Goanna | Multirotor Talk | 0 | Jul 01, 2012 11:49 AM |
| Discussion Aerial Video of kayaking and motocross - Heavy lift hexacopter | wac | Multirotor Talk | 7 | Jun 18, 2011 05:07 AM |
