Old Oct 18, 2012, 02:16 PM
reptileman is offline
Find More Posts by reptileman
nj
Joined Jan 2004
Question
Charging lipos at higher C rates?
Have a ? I have lipos rated at 5C and they are 5000MAH is it ok to lets say charge at 20 amps?
I am thinking the battery won't last as long but I am not sure as they do not even get worm during a 20Amp charge.
So what's the effect ... good or bad to high C charge?
THANKS
reptileman is offline Find More Posts by reptileman
Old Oct 18, 2012, 03:15 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
If they say it will handle 25 A (5C) then it should handle that much rate.
The fact that you see no warming at 20A is a good sign.
There is no evidence, one way or another, AFAIK that says higher C rate charging shortens pack life.
The main reason you can charge at these higher C rates, is back in the "old" days, we didn't balance charge. High rate charging in those conditions could cause serious heating of out of balance cells---the ones that were left in a high charge state. Also is why the manufacturers tended to use balanced cells in those packs.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Oct 18, 2012, 03:58 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
http://www.rcgroups.com/forums/showthread.php?t=1142882
a 3S 2250 charged at 11A and discharged at 40A for 300 cycles.
That would be 5C charges and 17.8 C discharges.
FWIW I am still using that LiPoly and it is currently being flown in my Blade 400 and Blade 450 helis.Total of 326 cycles seven in the past month.
Charles
Old Oct 18, 2012, 04:51 PM
bossee is online now
Find More Posts by bossee
Bo Edström, Sweden
Joined Jan 2009
Hi reptileman,
Usually it is in instructions with a LiPo battery how many amp it can be charged with. 1C (5 amp in your case) works for almost all LiPo I know of. 2C (10 amp in Your case) is probably safe to use on most LiPo today. Higher then that I would try to find out from manufacturer website or from good source how many amp is safe to use on that brand and model of LiPo. For example ThunderPower G6 LiPo can be charged with as much as 12C (with ThunderPower recommended chargers). Many LiPo's today can be charged with up to 5C but I would check the specifik brand and model of LiPo You have before any atempt at these higher (above 2C) charge rates. If they say it is OK to charge with 5C in Your case then You can pump in 25 amp ( 5 x 5000 mA) while charging if You want.
Probably most mid quality LiPo today can be charged at 5C.
I usually charge at 2C since I'm not in that much hurry when charging.
/Bo
bossee is online now Find More Posts by bossee
Old Oct 18, 2012, 05:53 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I'll chime in that yes that's true, except for smaller batteries. A lot of 1000mah or smaller, especially the under 500mah I still often see with 3C ratings. However the Nanotech 3S 45C 1300mah batteries I just got claim 10C charge rate!
grimbeaver is offline Find More Posts by grimbeaver
Old Oct 18, 2012, 06:12 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
THANKS
I charge at high rate all the time and have not noticed any decrease in battery life. The newer generation of LiPo batteries are designed for faster charge. LiPo technology just keeps getting better and better.
The only disadvantage is that you need a high powered charger and power supply. I just got a Turnigy 1080W 60A 18V power supply to use with my Power Lab 8 V2 so I can charge my large packs faster.
RC Man is offline Find More Posts by RC Man
Old Oct 18, 2012, 06:45 PM
nj
Joined Jan 2004
Thanks for the input guy's
I am using a hi tech 2 port X 400watt charger
My packs are the gens ace that say 5C capable now i have older lipos they say 1C should i just use 1C on these or is 2C fine?
Old Oct 18, 2012, 07:07 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
I have older "1C" lipos also and they get charged at 3C. I like flying more than I like waiting for my batteries to charge.
t.edwards is offline Find More Posts by t.edwards
Question Does charging a battery at a higher rate shorten it's life? astronaut Batteries and Chargers 20 Jun 27, 2012 09:16 AM
Discussion Lipo Packs - Charging Rate At The Flying Field? itsme2 Batteries and Chargers 1 May 03, 2012 04:23 PM
Discussion Performance benefits of charging at higher rates? silencery Batteries and Chargers 8 May 02, 2012 05:13 AM
Poll Leave Charged overnight or charge at higher rate? Munch Batteries and Chargers 25 Jun 14, 2011 12:06 PM
Higher C rate charge for Li Poly's on the horizon? bipeflyer Batteries and Chargers 10 Sep 12, 2003 08:16 PM
