Old Jan 27, 2013, 10:34 AM
Ayodhya is offline
Find More Posts by Ayodhya
WRX STI V - EJ22 - 35.3 PSI
Ayodhya's Avatar
Malaysia, Selangor, Puchong
Joined Nov 2012
Originally Posted by 1320fastback View Post
It drops in power.
You will notice that it takes 3/4 throttle to hover instead of 1/2 as example.
Also the light on top will stop blinking but this is only usefull if you can see it and are not flying around.
Best advise is like any RC vehie is to set a timer and fly until your cut off and not the batteries.
+1 on the timer.. Mines set to 7mins
Ayodhya is offline Find More Posts by Ayodhya
Old Jan 27, 2013, 07:44 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Gents,
+1
Additionally as with other multicotpers, your peak performance levels are at the first 50% of lipo time available. After that you need to lighten up on the aggressive maneuvers and flips if your multicopter can do them and fly a bit less aggressively or you may not have the reserve power to be able to recover from tight turns etc. As it has been mentioned before the RCE1 at this time can't do flips even in the Expert mode.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
It drops in power.
jesolins is offline Find More Posts by jesolins
Old Jan 28, 2013, 10:54 AM
Nerm is offline
Find More Posts by Nerm
Quads Helis Planes Cars
Nerm's Avatar
Canada, ON, Brampton
Joined Aug 2009
A little indoor flying this past weekend.
Rc Logger Eye One (4 min 28 sec)
Nerm is offline Find More Posts by Nerm
Old Jan 28, 2013, 11:06 AM
Adam.RCLogger is offline
Find More Posts by Adam.RCLogger
WWW.RCLOGGER.COM
Adam.RCLogger's Avatar
Joined Mar 2012
@NERM-
Very nice video. Wonderful exhibit of control. I have in the past from take off till dead battery had complete flights while holding full yaw. Endless donuts! It's an awesome way to learn control as you have to input corrections at just the right time to keep the EYE One from bounding off the walls! I think you got what it takes!
Once again +1 smooth operator!
Adam
Adam.RCLogger is offline Find More Posts by Adam.RCLogger
Site Sponsor
Old Jan 28, 2013, 12:18 PM
ricardoliveira is offline
Find More Posts by ricardoliveira
Up... Up... And away !
Portugal
Joined Oct 2010
hi there G.
what is your setup for eye one and what did you used for the canopy ?
ricardoliveira is offline Find More Posts by ricardoliveira
Old Jan 28, 2013, 01:02 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Originally Posted by ricardoliveira View Post
hi there G.
Hi,
This is my VTX http://www.hobbyking.com/hobbyking/s...200mW_FPV.html
For the camera http://www.rangevideo.com/index.php?...4c696a4e2ce6cb
And for the canopy see pic
G-unit is offline Find More Posts by G-unit
Old Jan 28, 2013, 01:44 PM
jesolins is offline
Joined Feb 2007
Hi Gary,
Nice work! I found that when I put on a OEM 16.7g #16 keycam, the RCE1 has enough lift with reserve for about 3 minutes of flight time before it loses enough reserve power to recover and counter any wobble of death(WOD) induced from wind gusts. It would be really nice if the RCE1 had the ability to adjust the PID for added AUW stability by a setup utility or POTI. I found it handled gusts better without a WOD if I mounted the slightly smaller less pitched Mini Pet props too. That effectively is a way of doing a crude mechanical PID adjust Interestingly, there is only slightly reduced lift and flight time with those props and some increased stability probably due to less mass and pitch drag. Note also that the throttle power is reduced in the Sport mode. You have more in the Expert mode to lift,but then you are the self-leveling device It would be nice for the RCE1 to have that extra power in the Sport mode too. Experiment!
Cheers,
Jim
Originally Posted by G-unit View Post
Had some time to put my FPV stuff on "THE ONE", no video yet..
Old Jan 28, 2013, 07:50 PM
Nerm is offline
Nerm's Avatar
Joined Aug 2009
@ Adam
Thanks man!
Old Jan 29, 2013, 03:56 AM
Portugal
Joined Oct 2010
My
I couldnt wait any longer, i want to see it in action outside...
I have only flew 1 minute or 2 indoor in mode 2 with spycam...
Today, with little wind, before going to work i went for a quickie on front garden.
My opinion... it is as descrived, super stable and i only used mode 2...
I stripped a spy cam, added a bigger velcro strap so i could passed throw battery and spycam.
Videos avaiable in 720P:
29.01.2013 - 720P - RC Logger Eye One - 2º Vôo Outdoor - Mode 2 - Spy Cam. (1 min 12 sec)
29.01.2013 - 720P - RC Logger Eye One - 1º Vôo Outdoor - Mode 2 - Spy Cam. (2 min 52 sec)
2m35s you can see me letting down the command and he was solid as a rock.
Counting down time to get the Eye one extreme...
Old Jan 29, 2013, 04:56 AM
symon is offline
Find More Posts by symon
Joined Apr 2007
Great video..as you say,very stable...what model 808 cam were you using?
symon is offline Find More Posts by symon
Old Jan 29, 2013, 05:36 AM
Portugal
Joined Oct 2010
cam
OFFTOPIC - #11... HD720, but the quality from this footage is not good, i dont know why, maybe the lens is dirty, i am going to clean it. You can check other videos on my youtube and see the quality, i use a keychain #11 in most of them with a 180 lens and it records as a go pro).
I already tried mode 3... a hour ago i showed my colleagues from the office the Eye One in action in mode 2... i have some collegues that are also RC pilots, they were... WOW !!! So they challenged me to try mode 3... its a bullet... dont recommend anyone to try it indoors or without completly dominated mode 2, its very sensible and the power is twice as mode 2...
Its a pocket rocket... a bullet... then they were... (WOW)^2. Two of them are already going to order one today and other two are going to wait for the Extreme version.
Old Jan 29, 2013, 05:49 AM
symon is offline
Joined Apr 2007
Hi ,
Ok thank you..i have the 808 #3..its ok....might get the #16
I havent tried my eye one in mode 3 yet!!.....
Old Jan 29, 2013, 06:09 AM
skipper1 is offline
Find More Posts by skipper1
United States, TX, Dallas
Joined Jan 2012
I have the 808 #11 and #16. The 808 #16 has much better quality and if you have video software, you can really make it pop.
skipper1 is offline Find More Posts by skipper1
Old Jan 29, 2013, 07:25 AM
GhostMaster is offline
Find More Posts by GhostMaster
Portugal
Joined Feb 2012
Do the Rc eye one do flips and 3d?
GhostMaster is offline Find More Posts by GhostMaster
Reply With Quote  (Disabled)
Old Jan 29, 2013, 07:29 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Not under control, no.
1320fastback is offline Find More Posts by 1320fastback
New Product RC EyE ONE from RC Logger Adam.RCLogger Multirotor Talk 25 May 13, 2013 07:33 AM
Discussion Eagle Eyes Diversity with one receiver- patch and clover? Lpbug FPV Talk 5 Jul 08, 2012 08:03 AM
Found Rc Logger 107_RC Rc Logger Digital Pitch Gauge ronzer Aircraft - General - Miscellaneous (FS/W) 1 Jul 03, 2011 09:11 PM
Discussion RC Logger All in One Its time to criticize! Almaz Mini Helis 14 Apr 01, 2009 01:55 PM
