Old Oct 18, 2012, 10:32 AM
drifter_uk is offline
Find More Posts by drifter_uk
drifter_uk's Avatar
england newcastle
Joined Aug 2009
Question
Rc Boat motor and esc
Hi guys just after some info Ive been an aero modeller for about 5 year now and done a couple of scratch builds and just recentley decided i want to get into boats due to not getting out much with the distance i have to travel etc
Ive just ordered the Orca plans of Pat trittle and trying to get my head around the power system to be used
Ive got loads of spare motors and esc of my planes (the exact ones) and just want to ask if i could get away with using them in a boat my system sofar consists of
Jr propo pcm9x tx with frsky 2.4ghz module (of my planes)
2x 3s 5000mah 20c lipos
A2217-6T 1500kv 250watt motor which is a replacement for a 400/480 size motor
Motor Specs:
* Type: A2217-6
* No. Of cells: 2-3S LiPo/8-10 Ni-xx
* RPM/V: 1500KV
* Max. efficiency: 79 percent
* No load current @10 V: 1.0A
* Working current: 22-26A
* Max Current capacity: 28A (60 seconds)
* Dimensions: D28 x L35mm
* Shaft diameter: 4mm
* Weight: 72g/2.51oz
30 amp esc
Specification:
* Class: Brushless
* Model: 30A Pro
* Application: Aircraft
* Constant Current: 30A
* Burst Current: 40A (for 10 seconds)
* BEC Mode: Linear
* BEC Output: 5V/2A
* BEC Output Capability:
on 2S LiPo - RX + 5 standard micro servos,
on 3S LiPo - RX + 4 standard micro servos,
on 4S LiPo - RX + 3 standard micro servos
* Battery Cell Count / Input Voltage: 2-4S (7.4V - 14.8V) LiPo or 5-12 (6V - 14.4V) NiMH
* Weight: 25.8g
* Dimensions L*W*H mm: 55 x 25 x 9mm
any info and assitance would be greatly appreciated
Thanks Les
drifter_uk is offline Find More Posts by drifter_uk
Old Oct 18, 2012, 11:35 AM
Rob_P is offline
Find More Posts by Rob_P
Rob_P's Avatar
Grosse Pointe, Mi
Joined Jun 2005
Drifter,
Like you I use brushless motors in planes but not boats. My observation is that a lower KV would be helpfull. I'm sure that with a little experimentation you will find a prop that works.
I did once try to use and aircraft ESC in a boat and I was finding that the low voltage cut out was coming in far too early. An airplane will always come down, a boat stuck in the middle of a pond can be more tricky to recover.
In my experience boats need ballast as can be found in Nimh or in larger boats Pb gell cells. These type of batteries do not need the LV cut off that you ESC is probably programmed for.
Hope this helps.
Rob
Rob_P is offline Find More Posts by Rob_P
Old Oct 18, 2012, 03:12 PM
drifter_uk's Avatar
england newcastle
Joined Aug 2009
Originally Posted by Rob_P View Post
Drifter,
Hope this helps.
Rob
Hi rob thats great to know i could get away with using both motor and esc in a boat and as for the Lv cutoff thats easily solved by using a lipo alarm only a couple of quid or turn of the Lv cutoff on the esc and run nihm
Thanks Les
Old Oct 19, 2012, 08:14 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
A 30 mm prop and run on 2s would be fine for the motor you listed, if you want to run 3s use a gear reduction, ive used a Maxx 400 sized box with sucess in the past, they come with three pinions to give 2:1 2.5:1 and 3:1 ratios approx.
Nick
nick_75au is offline Find More Posts by nick_75au
Old Oct 21, 2012, 11:14 AM
drifter_uk's Avatar
england newcastle
Joined Aug 2009
Nick
That's spot on nick I've got an adjustable tx so can set throttle/rate of travel to where I want it so even on 3s it should be alright with tweaking
Thanks Les
Question Questions about RC boat brushless motor, ESC, Props, and building boats. R/C_dude Racing Boats - Electric 50 Sep 27, 2015 04:10 AM
Discussion Can I buy rc boat motor for my rc plane?? zawaprz Electric Motor Design and Construction 2 Aug 26, 2012 10:27 PM
Sold *Sold* Genesis Electric Brushless RC Fiberglass Boat with water cooled motor and ESC. jbj620 Boats (FS/W) 0 Jul 20, 2012 10:39 AM
Wanted Rc boat motor/esc Idriveaboxster Boats (FS/W) 2 Mar 30, 2008 10:37 AM
