Old Oct 18, 2012, 08:20 AM
hondarc51 is offline
Find More Posts by hondarc51
Joined Oct 2012
Servo motor controls
Hello all, I am new to the forum and was hopping to be able to pick some brains about an idea I had using waterproof servo motors. What I am trying to accomplish is using servo motors to control the throttle and choke on a gasoline engine thats on a power unit in the bed of my truck. I would like to have it wired though, aka non wireless. I'd like to be able to control the servo motors with a toggle switch for easy adjustment of throttle and choke inside my truck cab. Also the servos I found are 6v and the system I have is 12v but I believe that is solved using a Bec. I hope someone can point me in the right direction!! Regards, Tom.
hondarc51 is offline Find More Posts by hondarc51
Old Oct 26, 2012, 09:03 AM
zanek is offline
Find More Posts by zanek
Agressive driver
United States, CA, Santa Barbara
Joined Jun 2011
I think it would be do able. You can solve the step down with a BEC, wiring it directly to the servo. as far as controlling the servo you would need some sort of servo tester I am not sure how big I servo you would need to control what you are talking about. You can't just control a servo with a swtich, but I believe you could use something like this http://www.hobbyking.com/hobbyking/s...vo_Tester.html
I believe that you plug the servo in and control it with a knob
zanek is offline Find More Posts by zanek
Discussion Using old servo control boards as actuator driver/motor ESC for PROPORTIONAL control EQMOD Electric Power Cars 13 Dec 30, 2014 05:51 AM
Help! Push button Servo controller for digital servo ? garrcass Electric Plane Talk 3 Jul 28, 2012 04:49 AM
Prog. JR8103 for motor control+4 servo wing nadt770 Electric Sailplanes 8 Feb 22, 2002 06:14 PM
Servo Tester ccts for motor control steve lewin Control Line 1 Apr 26, 2001 07:40 AM
