i flew control line in the mid 70's, after initially building simple kites at ~age 10, then small self designed gliders i moved on to peanut scale and larger free flight gliders, and then built a drifter 2 which saw me then segue to a series of scratch built gliders loosely based on the flinger (a very early r/c handlaunch glider - back when javelin launch was the go) i sorta dropped out between parenthood and other distractions (overclocking computers from early amd socket a, through 939, and then jumped to the dark side with the core2duo series) - in fact i had a break from the pitts because i found a quad core processor in a "dead" computer at the very recent council e-waste pickup here, and have upgraded my desktop for free - a yorkfield q8400 that is rated for 2.66ghz that is happily humming along as i type this at 3.33ghz on stock volts i can sell the dual core e8400 it replaced for enough to buy another aeroplane ![]() but i digress... i got into electric a few years back with a slow V; that inspired me to buy a lipo for it and then i needed a charger, so i had the basics - as a trainer it was only so-so, and had a brushed motor, but i could feel the potential for electric at the local park, only a short walk down the hill i was vacillating about getting a radian pro, and bought the spektrum dx8 in anticipation, but the radians were out of stock, so i bought a hobbyzone champ as an interim measure the best toy ! i very quickly got more proficient, and still love it that was only about a year ago.. and then i discovered hobbyking and started a shopping spree since then i have had the mini-stick (amazing fun!), the bonsai - same! and have a canary and the binary 900 pending me getting onto the projects; the pitts is close to finished, and i have a cuckoo that is almost done too there's also all the carbon and glues and various electrical gizmos; there's a huge stash of orangeRx receivers and servos and lipos; i can scratch build with my remaining balsa from last century, and i am seriously considering importing a big stash of depron from usa, plus sourcing some contest grade balsa and jap tissue locally god bless the interweb ! my blog tells the story of my obsession returning - sadly i killed the spitfire (beautiful, but not a clever choice for the park, as it is relatively fast, and weighs enough to injure people) the pitts will be a great addition to the line up, and other than my gliders is the most dangerous member of the squadron but still thankfully pretty benign whew! time for breakfast. then back to building hope the flying is good for you
almost there
back into it today; the weather here has been windy and then pouring, but moderated enough this arvo to take the bonsai out for another sortie after the building - i still need to get the cross rigging and aileron links organised
i couldn't resist fitting a satellite receiver - i have a spare, and i though "why not?"just because i could... initially it was going to go in obove and behind the wing, but then i realised it was way easier to gouge a thin receptacle and slice a slot for the aerial to run along (as per the photo) so the two aerials are essentially at 90º for best reception... equally, it means i have glowing bits in the fuselage in two spots because i can i put a depron "roof" on the area, and sealed the top of the aerial slot, so there wasn't going to be a mess of glue in there when i added the wing i gouged a bit more space to feed up the wiring with the aileron cables, and then dug a further hole behind the servo to stash all the excess from the other wires; the aileron leads were just long enough, as i had used the distance available to space the sevos in the wing as far as possible, but the rudder / elevator / throttle (and satellite) has a dross to spare it all worked out tidily enough, as you can see the canopy sits perfectly over the top and hides everything while still allowing the ruder and elevator to work without hitting anything, although the elevator won't run full range without binding, but still has deflection aplenty... if i decide it needs some help i can couple the flaps like a control liner - and i am curious how that would be in the air epoxied the top wing after fitting the aileron link mounts under all the ailerons with epoxy as well, lining them up with the aileron horn for maximal transmission of the control movements i hope... dunno if the ailerons will need stiffening, but the available throw looks like it is severe overkill., and i have the radio programmed for 2 stage flaps which i will activate once i get too sure of myself and likely discover i am not that competent with 5 channels, although i am now getting pretty confident with full house i added a skid that looks way slicker than the sad half moon they supplied - the parts will be recycled as motor mounts for something small i expect final details were some black dvd marker to complete the colour scheme on the struts and bottom of the bottom wing where there is a gap, and whipped out the yellow marker for the same reason under the lower wing if i'm going to be obsessive then why shouldn't i go the whole way ? ![]() the last few shots show the receivers lit up when it's on ![]() work again tomorrow and into midweek, but thereafter i am hopefully good to go if the weather holds out, and i can convince myself to cut a hole for the battery - it looks too cute and streamlined to whack another hole into
finally some more spare time, and the weather has gone all windy
![]() ah well... i used the supplied fibreglass rods for the cross bracing, using the holes in the struts as the positioning; the fuselage to top wing one went in first, which i aimed for the wing / fuselage intersection at a point 6cm behind the back of the undercarriage reinforcement using that as the guide of the other bracing brings it to hit the top wing just in front of the rear of the baldachin, which rakes it forwards like the struts, and suits my aesthetic sensibilities i'd like to take it out in the calm (when there is some) with the battery simply velcroed in the place i reckon it belongs, to confirm the trim is close to perfect before i cut a recess for the final resting place; weighs in at just shy of 520gm fully loaded (sans velcro) still waiting to hear the outcome of xmod's pathfinding missions
Australia, QLD, Mountain Creek
Joined May 2012
Sorry Scruffy, up here its either been blowing or raining or I've been working.
![]() With the two 1000mah batteries i am balancing at 15mm or so behind the lower wing edge. How can you balance there with one?????? As a side issue, can we buy sheets of epp foam in Oz? I have been having a look at the F22 profile models with the mid engine mount . Cut my own and i already have the spare hardware! Sounds brilliant.
you can thank the now dead hobbyking spitfire for being the wheel donor
i don't have a local source for epp (yet), but if you find one let me know because i am very definitely interested strikes me i might have to ship in a big batch of mixed depron from here and i just noted that they do epp too, so that might be part of an even bigger stash as my christmas present to me ![]() as for balance, i am packing a 1300mah turnigy 1.3 into the hole shown in the photo, which adds an alleged 115gm (actually ~113 on my scales) bringing the loaded weight to 515gm |
Joined May 2012
Hi Scruff,
http://www.rcfoam.com/product_info.p...0c6906a98c9570 Wow the land of the free and the home of the cheap foam! Thate six EPP F22s for $70 us. Did amyone say combat? http://www.rcgroups.com/forums/showt...&highlight=f22 australian Epp http://www.rcgroups.com/forums/showt...lian+epp+price Ok sorry for the hijack, Did you have a test fly with the batteries strapped on before you cut? The Turnigy nano tech 1400mah 3s i bought for the plane has been pinched for the wing. I really need to get the Pitts in the air to sort out what i am goong to do with the battery. I bought a 50 pack of # 1 lead weights from BCF but am reluctant to add weight, even to fix CoG issues. This weekend should be interesting |
but i have put an ounce of lead under the lipo to be decidedly nose heavy for the test flight, and the batteries are almost done and the wind speed is <5 knots i also have a 9 gram weight as the next step down, and if it looks good then i'll go "naked" for the third battery ![]() news here within the hour... |
well, a short sortie and a few lessons... but no catastrophes so it's all good
for reasons unknown the right aileron which had been trimmed with a lot of "left" to zero it seems to have rediscovered its neutral point and needed to be re-trimmed to near zero on the sub-trim i compensated for that with the normal aileron trim, which probably added to the "zoom" by effectively adding the equivalent of a degree or two of flaps. because even with an ounce of lead it needed some down trim on the plus side it cruises at about walking speed at half throttle, but isn't quite "unlimited vertical" at full throttle, which will likely change if i bump the prop up an inch - will check the current if i own that option later today and report back here turns with ailerons definitely benefit from rudder, which has huge authority - getting the spitfire to stall turn was always somewhat hit and miss whereas this turns 180º instantly in any climbing attitude ; even did a tiny bit of knife edge, which i had never attempted successfully beforethe counsel of flypaper2 in this post finally made more sense; i couldn't see why the landing gear mount would be a weak spot but on the very first "arrival" i was less than gentle, and on the next flight the undercarriage jettisoned like i was a messerschmitt 163 ![]() that increased the climbing tendency no doubt, but luckily i had already thrown in the extra 9 gms for good measure ![]() on landing (which i did remarkably gently - into the wind, cut the motor and stall about 6" off the grass, and plop! ) i realised that the ply had split in an obvious plane vertically so the mount could open like jaws ![]() this will be glued and i like the idea of some fibreglass on each side and across the gap underneath - fly's idea of a ply triangle is sensible, but the aesthetics of his solution is against my design brief of beautiful toy not until i walked home that i noticed the left aileron linkage rod had vacated - the nut holding the metal fitting to the plastic on the bottom aileron link had obviously come undone, and the top aileron was free of any control... easy to replace, as i have some spares from the original aileron linkages given i used the spitfire fittings there's some blue thread locker in transit in my pending order, but i might just add a drop of either epoxy or cyanoacrylate as an interim measure, because rogue ailerons might be problematic - seemed to land okay anyway six minutes of erratic flight left me with 11.27v and took 417mah to charge up to 50% in the 1300mah - comparing to the spittie seems that 6 minutes w.o.t. would be a "safe" flight time leaving 20% residual, but more research required and of course meantime, wind speed has kicked to > 10 knots, and this plane looks like a still air specialist short summary :
i fixed all the details listed that were minor irritations really
chose to fill the gap in the undercarriage mount with 5 minute epoxy and microballoons - light, flexible and strong, so we'll see how that works out; and i cyano'd the aileron connector nuts flashed the firmware in the dx8 for good measure and programmed the esc which kept losing the throttle settings - my mistake as i hadn't done it quite right first time round, and now it is faultless ![]() reset the throttle curve to sit at ~50% from 25-75% i suspect the ailerons either need differential or some mixed in rudder, but haven't got any coherent clues about that yet ![]() i'll see how much nose weight it can do without by and by if the weather co-operates; failing the ability to dispense with the 30gm of ballast i am looking at the 1500mah sibling of my current lipo, which apart from length is very close in dimensions, and conveniently adds 200mah for 30gm difference - if i have to carry 30gm to trim the balance, it may as well pay for the ride with added duration
woke up early to blessed calm and clouds lit from below by the sunrise
by the time i'd scoffed a banana and had a coffee the sun had risen above the overcast and the batteries had been topped up to full, the stig had donned his lucky helmet, and we were all systems go... perfect ! still air and minimal glare down the hill i limped (dropped the vtr250 on my left leg on thursday, still got huge grazes and some bruises as well) with the machine what a great toy ! didn't help i had the elevator throw reversed, but could have been worse - my rotation for take off became a nose-over (teach me to reflash the radio and not double check the servo directions ) - easy fix with the dx8 and then tally ho ! ![]() 3 batteries later i am home and smiling ![]() the sun is now well up and the nor' easter is picking up as i type; that'll give me a chance to epoxy the rigging braces where they cross, as the left one is again loose - don't know if it matters at all, but the cyanoacrylate is too brittle for that task despite a few bumps on landing, filling the undercarriage slot with epoxy and 'balloons has been great as reinforcement with just the right amount of tolerance to the vicissitudes of challenging arrivals ![]() the final flight i dropped the nose weight to 29 grams from the 32 grams (ooh ! brave !) and it flew well, but unsurprisingly needed more down trim - the photos show the details i suspect that with practice the nose weight can go lower, but it is already very responsive, and the extra cargo appears inconsequential so i will ease the cg rearward with maybe 20 grams as the next step, then 10 if i don't freak myself out flight notes from today :
probably a little flitty for a beginner, but if you can fly ailerons confidently, this biplane is highly recommended !
Joined May 2012
Up for the maiden flight of both Pitts and the wing at 5.30, otherwise the winds pick up pretty soon after that.
The pitts, even with two 1000mah 3s batteris flew like there was a brick tied to the tail. Added nearly 80grams of lead and it was still unstable and I got it down in one piece, minus a prop. Have a look at the photo, It is balancing at 15mm from front of lower wing with a 2200mah 3s battery!!!!! ![]() ok. flight times should be good, but this little porker now had 615g AUW. The plane is dead stock and built to the guidebook. Any ideas??? |
Joined May 2012
Almost forgot, yes the ply landing gear support promptly fell out, only 3 drops of ca holding it in looks like. Considering one of the landings was really more of a slo-mo cartwheel the plane is very resiliant.. The wing flew..... Suspect it maybe is faster and a lot more agile than i am
....how do you keep track of a sky blue wing scruffy? Mine is orange and i had to guess up from down a few times
| Thread Tools | |
| Video Biplane PITTS-EPP from Hobbyking | derfnam01 | Electric Plane Talk | 4 | Oct 21, 2012 06:42 AM |
| Video Pitts-EPP from Hobbyking - some little aerobatics with this nice biplane | derfnam01 | Electric Plane Talk | 0 | Jun 13, 2012 08:32 AM |
| Sold HobbyKing Pitts EPP w/Motor NIB | sgomes | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2012 08:38 AM |
| For Sale HobbyKing Pitts EPP Kit - Plus extras $110, conus | sgomes | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 10, 2012 10:06 PM |
| For Sale Hobbyking Pitts EPP listed below | sgomes | Aircraft - Electric - Airplanes (FS/W) | 2 | Mar 06, 2012 09:24 PM |
