Old Jan 14, 2013, 12:09 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Or can I use the Feiyu Tech FY30A ? as I have a spare unit unused
Im about to order the Glyder frame kit only
koolkiwikat is offline Find More Posts by koolkiwikat
Old Jan 14, 2013, 04:29 AM
panos2408 is online now
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
You can always try and then tell us your results... I can't express an accurate opinion since i have never had any experience with 2 axis plane stabilization systems. If it doesn't work then you can simply go with the gyros which is a sure thing.
panos2408 is online now Find More Posts by panos2408
Old Jan 14, 2013, 05:43 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Is anybody using a Naza combined with the new Foxtech motors, Hobbywing 30A esc and 11"+ props here?
Old Jan 14, 2013, 02:38 PM
nineu is offline
Find More Posts by nineu
nineu's Avatar
Joined Nov 2010
Hi guys!!
My problems with pitch control are practically solved, It was no gyro problem as I initially thought... I connected a channel of the receiver to the Naza's X1 and adjusting a potentiometer from the Tx I got Pitch movement, I had not read anything about it (or I read it but I forgot) but finally Pitch movement is alive in my Glyder!
The trouble is that in previous tests I broke a gear (the only one that is plastic) in the Pitch servo so I have to get another similar servo in my local store...
Test video in the mirror is not quite good yet but I have a larger analog servo tied badly in the pitch so I'm not too concerned with it...
Regards!
nineu is offline Find More Posts by nineu
Old Jan 14, 2013, 04:13 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Well i have some bad news... I crashed my glyder today... I was flying with my naza in gps hold when it decided to develop artificial intelligence and start to fly away... I had to kill motors to save the worse cause i was flying beside a not very busy main road... Dropped it from about 25-30 feet. It had a couple of rolls on the ground since it also had some forward speed... From a first look the only damage was a bended battery tray and bottom part of both landing skids is bended... Ironically it was the first flight with the gimbal on... And the best part??? I also locked my self out of the flat... My dad had to drive 1 hour to open the flat for me
I think i had enough with the naza... I am gonna give it away... Gonna start finding buyer from tomorrow... Going for the ys x4 or the x6...
Old Jan 14, 2013, 04:41 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Fu you sell everything individually apart the bottom part of the landing skids... My crash test showed that the vertical legs are very strong but the bottom part is very weak... Most of us will need only the bottom part on a hard landing so it would be nice if you could split the 2 parts of the landing skid to save us some money and space
Old Jan 14, 2013, 04:44 PM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, Blackpool
Joined Dec 2005
that sucks dude... strange problem,,, if your giving the naza away feel free to send it my way :P
would be great to try it with some other esc motor combo's to try figure the problem out on a small quad for my mates to try flying.. i jus dont have enough money for this hobby :P
AliB is online now Find More Posts by AliB
Old Jan 14, 2013, 04:50 PM
Tetley is offline
Find More Posts by Tetley
AKA 3DJIM
Tetley's Avatar
Bournemouth Great Britain (UK)
Joined Jun 2004
Unlucky Panos sorry to hear you crashed, You must just have a bad naza, I love all my nazas and they seem to work very well. I would send it back rather than give it away.
Jim.
Tetley is offline Find More Posts by Tetley
Old Jan 14, 2013, 05:11 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Yes i ll write a second email to my seller and see if he is gonna answer this time... I have read a lot about dji naza these days... Everybody seems happy with the but to be onest i would like to put my hands on the ys x4.
Old Jan 15, 2013, 01:36 AM
nineu is offline
nineu's Avatar
Joined Nov 2010
I'm sorry to hear bad news about your Glyder, Panos! I hope you can have it flying soon...
Regards!!
Old Jan 15, 2013, 06:54 AM
neato4u is offline
Find More Posts by neato4u
neato4u's Avatar
Malaysia
Joined Feb 2012
guys i had my glyder setup today and finally got esc and throttle calibrated with the Zero UAV YS-X6.
I mounted a gopro2 with a 2200mah 3s 25c lipo.
Upon full throttle the quad doesnt even lift! Do I require a 4s minimum?????
neato4u is offline Find More Posts by neato4u
Old Jan 15, 2013, 07:49 AM
nineu is offline
nineu's Avatar
Joined Nov 2010
3S Lipo and GoPro is not too much weight ... What engines and propellers have you mounted ??
Old Jan 15, 2013, 08:19 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Can you provide motor specc and prop size?
You ll need atleast 11" props with a motor around the class of 850+ kv to lift your copter sufficiently with that setup... Your Glyder must comes down to about 2.3kg AUW if i am not mistaken... Mine was lifting up at about 2.7kg AUW running on 4s. It is lifting off at about 60-65% which is not that healthy... I use 690kv and 10" props but heavier battery than you... 4s 5A
Old Jan 15, 2013, 11:09 AM
neato4u is offline
neato4u's Avatar
Malaysia
Joined Feb 2012
nineu - Yeah that is exactly what I thought of.. gopro2 and a 2200mah is considered damn light for a 600 sized quad.. even my 450 can lift with ease.
panos - I bought the PNP version. It should already be at it's optimum / most efficient configuration (that is what I thought of)
4x T -motor 2216 KV800 motor
4x Hobbywing 30A ESC
4x 1038 Carbon Fiber Propeller (10")
I just bought a 4s, will test remaiden tomorrow.. if it's still underpowered, something must be wrong and I hope Fu can help
Old Jan 15, 2013, 11:56 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
You need a 4s configuration that's all. My 880kv motors can lift up to 1.7kg with 10" on a 3s... Glyder weighs about 1.62kg without any elecctronics installed not getting it airborne is basically the logical situation.
Sold Foxtech 5.8ghz Vtx/Vrx & Sony 600 TVL cam Viper82 FPV Equipment (FS/W) 6 Jun 07, 2012 06:32 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 08:14 AM
Discussion Quadcopter, where to start? Ischim0n Coaxial Helicopters 1 Apr 12, 2012 07:30 AM
