Old Oct 27, 2012, 08:03 PM
panos2408 is online now
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
The answer was referring to a question whether the mount can turn 90 degrees and take nadir shots. It should be able to go up to at least 60 degrees. All of these steadicam frames (ecilop Glyder 600 etc...) do not offer nadir shots which translates to 90 degrees tilt.
panos2408 is online now Find More Posts by panos2408
Old Oct 27, 2012, 08:59 PM
jamac is offline
Find More Posts by jamac
United Arab Emirates, Dubai
Joined Aug 2012
Guess I misunderstood the question and the answer. I thought that we can set the tilt angle only before takeoff.
So you're saying that it offers a manual tilt control with certain degree ? That'd be good news.
Fu?
jamac is offline Find More Posts by jamac
Old Oct 29, 2012, 03:57 AM
glassfox is offline
Find More Posts by glassfox
glassfox's Avatar
Tianjin, China
the rumor is true, the gimbal will have a servo slot that makes it possible to control the camear tray 's angle ,so it's possible to point the camear vertical to the ground by a channel.
the part is still in construction ,so the camera tilt upgrade kit will be available after Glyder 600.
a load test was made too, the total payload is 1.4kg including battery.
a test video will show soon.
thanks
Fu
glassfox is offline Find More Posts by glassfox
Site Sponsor
Old Oct 29, 2012, 11:37 AM
neato4u is offline
Find More Posts by neato4u
neato4u's Avatar
Malaysia
Joined Feb 2012
s6100021, I guess you are right. If the frame parts are hard to find / get or (for me) too expensive, then I will be concerned too if the frame broke.
Fu, I am still waiting for you to respond back to my email. It's already been 3 days without answer.
neato4u is offline Find More Posts by neato4u
Old Oct 29, 2012, 12:10 PM
Wideopen is offline
Find More Posts by Wideopen
Bermuda
Joined Dec 2004
Fu, What is the recommended battery size, 3s or 4s and how many Mah.
What will be the flying time with each battery.
Wideopen is offline Find More Posts by Wideopen
Old Oct 29, 2012, 05:43 PM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Give some details about the motors you plan on mounting on the frame. The typical equation of flight time goes something like this.
Battery Capacity divided by Total consumption of the Multirotor multiplied by 0.6 to end up with minutes.
So given the fact I have a quad that hovers at a 20A running on a 5A battery the equation will go something like this
5 divided by 20 = 0.25
0.25x0.6= 15 minutes.
However you need to subtract the 20% of the total battery capacity prior doing this equation in order have a healthy battery cycle and good long life battery status
Old Oct 30, 2012, 08:52 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Glyder 600 payload test (1 min 46 sec)
payload test video is here.
Site Sponsor
Latest blog entry: Foxtech Wishes You A Merry...
Old Oct 30, 2012, 08:54 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
errr, I may missed it , you email name is ?
anyway I will check ,if I don't reply ,you can talk to Doris on livechat.
thanks
Fu
Site Sponsor
Old Oct 30, 2012, 08:56 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
I use 5000mah 4S in my setup, it should be enough for most applications
thanks
Fu
Site Sponsor
Old Oct 30, 2012, 11:26 AM
neato4u is offline
neato4u's Avatar
Malaysia
Joined Feb 2012
thanks
Fu
Email name is Wan Kay, neato4u@gmail.com
Prefer to talk with you directly, as easier to finalize.
Hope to hear from you soon. Thanks
Old Oct 31, 2012, 07:36 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Fu
I asked earlier if it can support a X8 config? if so can you offer a X8 kit option, Just the extra hardware? Ill hit the buy button if you do, I really want the redundancy a X8 offers( I fly APM2 and Cirus Pro FC's)
Cheers!
koolkiwikat is offline Find More Posts by koolkiwikat
Old Oct 31, 2012, 09:46 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Originally Posted by koolkiwikat View Post
Fu
Cheers!
there is no X8 config at present ,and if you use X8, NAZA should not be the choice as a main controller.
under current conditions , quadcopter should be suitable for most applications
X8 will be the next step, extensive tests must be done before releasing it.
thanks
Fu
Site Sponsor
Old Oct 31, 2012, 09:47 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Glyder 600 test Footage 7 (1 min 49 sec)
footage 7
Site Sponsor
Old Nov 02, 2012, 05:04 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
one email vanished without reason, I got the second one though
many guys are asking the gyro and servos,
and we will put it on the site in next week.
so it will save your time to find suitable gyros
thanks
Fu
Site Sponsor
Old Nov 02, 2012, 05:50 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Fu,
It would be nice to offer a couple of solutions both expensive and cheap. To be honest not many people will go for expensive gyros. Also will your design need a ubec for the receiver servos gyros? I was planning on using the flight battery to do that... On the other hand I guess using a 4s Battery will require a second battery for AV TX since not many (atleast not mine) are running on 4s. Can you post some ideas how to power things on the Glyder 600?
Sold Foxtech 5.8ghz Vtx/Vrx & Sony 600 TVL cam Viper82 FPV Equipment (FS/W) 6 Jun 07, 2012 06:32 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 08:14 AM
Discussion Quadcopter, where to start? Ischim0n Coaxial Helicopters 1 Apr 12, 2012 07:30 AM
