Old Oct 23, 2012, 07:42 AM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
Originally Posted by panos2408 View Post
shouldn't be suppose to be working the same way with a Dji naza?
Yes because the stab would rely on the supplied gyros and no because YS-X6 has a lot more features than Naza GPS. Would be interesting to see how the glyder performs in a waypoint flying mode.
fajar is offline Find More Posts by fajar
Old Oct 23, 2012, 08:22 AM
glassfox is offline
Find More Posts by glassfox
glassfox's Avatar
Tianjin, China
Originally Posted by Quadframes View Post
Fu what are you making this from Aluminum ?
hi,
do you mean why I make it with Aluminum?
for light weight and stronger frame,
and most Aluminum part doesn't get broken during a crash,
you only need to change the 11mm arms ,saving cost.
thanks
Fu
glassfox is offline Find More Posts by glassfox
Site Sponsor
Old Oct 23, 2012, 08:25 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Fu,
Max prop that can be installed on the frame is 10"? do the T motors you sugest can handle 14.8v spinning a 10" prop?
MAX is 12 '' propeller.
with 1038 propeller, 2216 KV800 T motor gets best effiency with 14.8V lipo
you can also try 2814 KV700, 1238 propeller.
but in our test, that combination got less stability,
so that's why we finally choose 2216 motor.
why we use naza is because of the cost of course.
NAZA could be the only choice to get good fly performance with lower cost.
you can use YS-X6 of course or other controller like WKM etc.
thanks
Fu
Site Sponsor
Old Oct 23, 2012, 10:31 AM
jamac is offline
Find More Posts by jamac
United Arab Emirates, Dubai
Joined Aug 2012
Fu, what do you think about using 2212 KV920 + 10x5 props on it?
Any videos in a bit more windy conditions available?
we may offer an upgrade kit to make it possible to control by a servo
This is a must for anything more than fpv
400gr limit is acceptable but did you try balancing it with something having longer lenses?
jamac is offline Find More Posts by jamac
Old Oct 24, 2012, 12:58 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Can't remember I mentioned 400g payload, the recent test shows 600g is no problem.
with 5000mah 4S lipo.
you can adjust the battery position to compensate the camera with longer lens.
I will show more setting videos soon.
thanks
Fu
Site Sponsor
Old Oct 24, 2012, 04:58 AM
panos2408 is offline
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
thanks
Fu
Wow 600g is very good. You did mentioned somewhere 400g. But you can always take it back and prove a better result This frame sounds like a real deal. The videos posted already showing good results. Especially the one with the windy conditions. However since you are making changes on the frame it would be nice to have videos with the final version of the frame.
panos2408 is offline Find More Posts by panos2408
Old Oct 24, 2012, 05:14 AM
milouze is offline
Find More Posts by milouze
Registerer Used
milouze's Avatar
Paris
Joined May 2010
the weight is around 800g including the gimbal
it can carry a camera less than 400g
you can use up to 12inch propeller on this frame.
we offer a setup of T MOTOR 2216+ 1038 propeller.
acceptable efficiency, stable fly performance.
thanks
Fu
You mentioned it here.
But this is good news anyway, that it could carry more than 400g. Nice.
milouze is offline Find More Posts by milouze
Old Oct 24, 2012, 11:53 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Fu,
I am planning to go with a nex 5n which weighs around 300g with the lens i am planning to use. Does that mean my battery needs to be also at 300g to have a good counterweight ratio? I will just answer my own question here for others with the same question... The battery tray is adjustable it can slide up and down to in order to balance the steadicam camera mount.
Also till when do you offer pre order discount?
And lastly what servo size is used? (Standard , park, micro?)
Old Oct 25, 2012, 08:35 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
yes , we will do ,the change will make the tilt performance even better, since you can find on the old frame design, the tilt spring holding poles are not in the middle of the gimbal.
thanks
Fu
Site Sponsor
Old Oct 25, 2012, 08:37 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Fu,
not exactly, like I mentioned in the video, the counter weight pole can be adjusted, so you can put on battery with around 400-600g weight,
just make it totally balanced , then it should be ok.
thanks
Fu
Site Sponsor
Old Oct 25, 2012, 08:39 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
also, bigger motor makes it with bigger payload, but I think 500-600g camera weight is quite enough ,since we designed it carry cameras up to Sony 5N only.
Site Sponsor
Old Oct 25, 2012, 09:20 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Fu,
PM sent.
I still don't know what size of servos does the Gimbal accommodates.
Old Oct 26, 2012, 03:07 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Fu,
PM sent.
the futaba 9257 sized, 27g servo.
we use spring RC servo.
thanks
Fu
Site Sponsor
Old Oct 26, 2012, 03:40 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Is it possible to configure into a X8?, I prefer the redundancy of a X8
Cheers!
koolkiwikat is offline Find More Posts by koolkiwikat
Old Oct 26, 2012, 04:17 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Cheers!
With a 4s 8A battery and the Tmotors suggested you should be getting out of it about 6 minutes of flight time given you ll not exceed 75% throttle stick but the weight of that battery is about 850g which will make it hard to balance the steaicam. Foxtech suggested a battery weight between 400-600g for balancing with the Sony Nex 5n. I guess going with a little heavier camera might do the trick bbut i don't know if the frame can support it.
Sold Foxtech 5.8ghz Vtx/Vrx & Sony 600 TVL cam Viper82 FPV Equipment (FS/W) 6 Jun 07, 2012 05:32 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 07:14 AM
Discussion Quadcopter, where to start? Ischim0n Coaxial Helicopters 1 Apr 12, 2012 06:30 AM
