Old Nov 27, 2012, 02:55 AM
glassfox is online now
Find More Posts by glassfox
glassfox's Avatar
Tianjin, China
Hi, Fajar,
it's ok, take your time ,
and thank you for the comments on Foxtech,
I attached some working progress photos here,
starting shipping the Glyder 600 now,
but we ordered a bigger box than necessary.
so you may find a lot of foam balls in the package.
glassfox is online now Find More Posts by glassfox
Site Sponsor
Old Nov 27, 2012, 03:12 AM
panos2408 is offline
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Something off topic guys.... I requested a new Forum regarding video post production here
If you would like something like this vote up for it. Cheers.
panos2408 is offline Find More Posts by panos2408
Old Nov 27, 2012, 05:08 AM
Tetley is offline
Find More Posts by Tetley
AKA 3DJIM
Tetley's Avatar
Bournemouth Great Britain (UK)
Joined Jun 2004
FU,
I see all the motor wires are short and have connectors on them, will these have enough wire to run around the frame? my other Tiger motors came with plenty of wire on them for a multi?. Also are these wires crimped or soldered?
Kind Regards
Jim.
Tetley is offline Find More Posts by Tetley
Old Nov 27, 2012, 06:09 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
I am also wondering how to go ahead with a clean Power distribution on the frame... Was thinking sime like the Ecilop which has a main cyclic wire that picks up power from all esc's and deliver it to the battery... I was going to buy it but 75 USD is really a lot of money for a wire...
Old Nov 27, 2012, 06:25 AM
x2001 is offline
Find More Posts by x2001
Australia, SA, Tarcoola
Joined Dec 2004
I think it's for putting ESC directly under the motor like DJI S800
x2001 is offline Find More Posts by x2001
Old Nov 27, 2012, 06:34 AM
glassfox's Avatar
Tianjin, China
actually we cut the wires and soldered connectors on, the connector can be linked reversed to change motor rotation direction easily,
yes, we did mean to put the ESC under the propeller for enough cooling.
thanks
Fu
Site Sponsor
Old Nov 27, 2012, 06:35 AM
glassfox's Avatar
Tianjin, China
Hi panos,
do you mean something like this ?
http://www.foxtechfpv.com/power-dist...tor-p-595.html
Site Sponsor
Old Nov 27, 2012, 08:00 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
No the idea was to have a wire going around the square main frame and possibly have connections so that the ESc's can connect onto it... Something Similar to what Aleksey did with his Ecilop. This will take the space on the bottom side which is basically useless for mounting things not to mention maybe inside CF tubes
Old Nov 27, 2012, 08:19 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
By the way are those black extensions of the landing gear adjustable just in case they get within the field of view of the camera? If they are hats off
Old Nov 27, 2012, 08:54 AM
glassfox's Avatar
Tianjin, China
well, seems a retracting landing gear mod is a good idea?
normally you don't see the landing skid in the video.
you can do modification on the landing skid if necessary too.
Site Sponsor
Old Nov 27, 2012, 09:29 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Retract i don't think so unless you plan on a mod for a 3 axis gimbal on the frame... However having adjustable length of the legs on the bottom would be nice idea. But let's see if it is needed first.. I am pretty sure gopro will be affected since it has a wide field of view but i am not gonna use one so personally I am not worrying.
Old Nov 27, 2012, 09:37 AM
tycoyoken is offline
Find More Posts by tycoyoken
Joined Mar 2011
Something like this would be great, they called that "Retractable Landing Gear"...
Self-made ​​s800 retractable landing gear.
http://www.rcgroups.com/forums/showt...2#post23375597
자체 개발 S800 Retractable Landing Gear (NOT DJI'S PRODUCT!!!) DJI제품 아님 (0 min 44 sec)
DJI ​​s800 retractable landing gear
http://www.dji-innovations.com/produ...skid/overview/
DJI - S800 Landing Gear (0 min 21 sec)
tycoyoken is offline Find More Posts by tycoyoken
Old Nov 27, 2012, 10:07 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Yes i am aware of this and it isn't really rocket science for diy... Just 2 servos that will lift the gear up... Glyder600 can accomodate this mod very easy.... But why? This only helps if you have a 3axis mount and a camera operator and as far as i am aware it will be hard to have a functional stadi 3 axis gimbal...
Old Nov 27, 2012, 11:31 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
Originally Posted by glassfox View Post
milouze is correct,
Glyder 600 is not an innovation , it's a new design with military standard material and many fly tests.
the main point is, glyder 600 is the only frame made in China comes with a patent agreement with ECILOP designer.
and FOXTECH never ignores others invention.
I don't like to talk about other's product, but think twice to use a cheap frame to carry very expensive cameras.
even ABLomas argues in the mini 650 thread about the material they used , looks like carbon, but it's fiber glass.....
and the MR 's credit is not very good in China,
when you crash, you have to wait 1 month or more for spare parts.
so much for now
i like figuring out if people are lying (or deliver misinformation)
here's the mail from Ecilop team
jy0933 is offline Find More Posts by jy0933
Old Nov 27, 2012, 01:16 PM
ibbe76 is offline
Find More Posts by ibbe76
Joined Jan 2012
Hello, how is the two gyros gain cable connect?
ibbe76 is offline Find More Posts by ibbe76
Sold Foxtech 5.8ghz Vtx/Vrx & Sony 600 TVL cam Viper82 FPV Equipment (FS/W) 6 Jun 07, 2012 05:32 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 07:14 AM
Discussion Quadcopter, where to start? Ischim0n Coaxial Helicopters 1 Apr 12, 2012 06:30 AM
