Old Oct 18, 2012, 07:31 AM
glassfox is offline
Find More Posts by glassfox
glassfox's Avatar
Tianjin, China
FOXTECH Glyder 600 Quadcopter, Ready for shipping!
Test Videos:
GLYDER 600+GOPOR 3 (2 min 36 sec)
GLYDER 600 Cam Tilt Mod Test (2 min 10 sec)
FOXTECH Glyder 600 Quadcopter (4 min 41 sec)
GLYDER600 feature introduction (3 min 45 sec)
How to adjust the Glyder 600 gimbal in 5 mins (9 min 58 sec)
HOW TO USE GLYDER 600 (5 min 39 sec)
FOXTECH- GLYDER 600 FLYTEST1 (2 min 45 sec)
Glyder 600 in huge wind (1 min 33 sec)
Foxtech Glyder 600 Test footage 1 (2 min 39 sec)
glyder 600 test footage 3 (0 min 54 sec)
Glyder 600 Raw Video Demonstration (1 min 51 sec)
GLYDER 600 test Footage 4 (1 min 4 sec)
Glyder 600 raw video footage 5 (2 min 11 sec)
Glyder 600 is a special quadcopter frame with the best self-balancing gimbal in the world
( working principle based on ECILOP(ECILOP.TV, Aleksey)). It features strong structure,Fully suspended gimbal,
3-stage shock absorbing system ,adjustable cam mounting plate and counter weight position,
detachable landing gear and other cool features.
While using this frame ,the battery acts like a counter weight to the camera ,
so its Inertia makes the gimbal stabilize itself, apart from that ,
two gyro controlled servos controls the gimbal make it even more stable.
In most cases, the shock and vibration from the frame are totally isolated from the gimbal due to its special structure,
so a zero-vibration & shock video taking experience can be guaranteed.
Parameter:
diameter: 600mm
max flying weight: depending on the motor and propeller,3-4kg
Material: Aluminum and carbon fiber
Recommended setup:
1x Glyder 600 frame with gimbal
1x DJI NAZA controller(Optional adding a NAZA GPS)
4x T -motor 2216 KV800 motor
4x Hobbywing 30A ESC
4x 1038 Carbon Fiber Propeller
2x Gyros
2x 27g metal gear digital servo
Preorder enjoys 14% discount on the frame .
http://www.foxtechfpv.com/glyder-600-quadcopter-series-c-141.html
ATRF Version:
http://www.foxtechfpv.com/glyder-600...set-p-694.html (With DJI NAZA)
http://www.foxtechfpv.com/glyder-600...set-p-735.html(No main controller)
Full PNP version:
http://www.foxtechfpv.com/glyder-600...set-p-695.html (Only need to add Radio and battery)
BETA MANUAL:
http://www.foxtechfpv.com/product/gl...anual v1.4.pdf
Final look of Glyder 600:
Carbon fiber tube
7075 Aluminum Frame
CNC gimbal
New shock absorbing springs and screws.
Note: The following photos contains old version fly test photots.
All parts in the prototype frame
If you had any question, please feel free to leave it in this thread.
or contact us by "live chat"
or Write emails:
Technical support: technicalsupport@foxtechfpv.com (Alex Liu)
Distributor inquiry: foxtechfpv@gmail.com (Fu Xing)
glassfox is offline Find More Posts by glassfox
Site Sponsor
Old Oct 18, 2012, 10:20 AM
Snoopyboy is offline
Find More Posts by Snoopyboy
Joined Sep 2012
Any parts support?
Snoopyboy is offline Find More Posts by Snoopyboy
Old Oct 18, 2012, 04:16 PM
FPVlarsen is offline
Find More Posts by FPVlarsen
Norway
Joined Jul 2009
Looks good!
What is the weight of the frame?
What is the length and hight of the cameramount?
What is the maximum camera weight it can handle?
What is max propeller size?
FPVlarsen is offline Find More Posts by FPVlarsen
Old Oct 19, 2012, 07:57 AM
neato4u is offline
Find More Posts by neato4u
neato4u's Avatar
Malaysia
Joined Feb 2012
Fu, I sent you PM and email yesterday, still waiting for your reply
neato4u is offline Find More Posts by neato4u
Old Oct 21, 2012, 08:54 PM
glassfox is offline
glassfox's Avatar
Tianjin, China
Originally Posted by Snoopyboy View Post
Any parts support?
of course, since the gimbal part will be changed to CNC type, the part list is not ready yet, but so far in the tests, we didn't find any vulnerable part yet.
the part will be available soon.
thanks
Fu
Site Sponsor
Old Oct 22, 2012, 06:53 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
Originally Posted by FPVlarsen View Post
Looks good!
the weight is around 800g including the gimbal
it can carry a camera less than 400g
you can use up to 12inch propeller on this frame.
we offer a setup of T MOTOR 2216+ 1038 propeller.
acceptable efficiency, stable fly performance.
thanks
Fu
Site Sponsor
Old Oct 22, 2012, 09:42 AM
neato4u is offline
neato4u's Avatar
Malaysia
Joined Feb 2012
can the gimbal turn the camera downwards facing the earth?
Old Oct 23, 2012, 02:03 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
if you'd like to do that ,you can adjust the cam to point downward before taking off,
we may offer an upgrade kit to make it possible to control by a servo .
thanks
Fu
Site Sponsor
Old Oct 23, 2012, 02:12 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
the new gimbal part is under construction,
here are some samples.
this makes the assembling of gimbal part really easy.
thanks
Fu
Site Sponsor
Old Oct 23, 2012, 03:45 AM
panos2408 is offline
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
The Raw video looks very stable good work on the frame. It would be nice if it could accomodate a small fpv camera without many mods since most of the new Mirrorless dslrs do not offer av out option.
It would be nice to list some weight ratios between battery and camera in order to achieve some nice stabilisation.
panos2408 is offline Find More Posts by panos2408
Old Oct 23, 2012, 03:51 AM
glassfox is offline
glassfox's Avatar
Tianjin, China
we are preparing the user manual, and most information will be included,
in my first video ,a horyzonhd camera was used, the counter weight is very small in that way
thanks
Fu
Site Sponsor
Old Oct 23, 2012, 03:56 AM
Quadframes is offline
Find More Posts by Quadframes
Quadframes's Avatar
Joined Jun 2011
Fu what are you making this from Aluminum ?
Quadframes is offline Find More Posts by Quadframes
Old Oct 23, 2012, 04:09 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Fu,
Max prop that can be installed on the frame is 10"? do the T motors you sugest can handle 14.8v spinning a 10" prop?
Old Oct 23, 2012, 07:05 AM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
Would be interested to see how this glyder system performs with the YS-X6 system.
fajar is offline Find More Posts by fajar
Old Oct 23, 2012, 07:32 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
shouldn't be suppose to be working the same way with a Dji naza?
Sold Foxtech 5.8ghz Vtx/Vrx & Sony 600 TVL cam Viper82 FPV Equipment (FS/W) 6 Jun 07, 2012 05:32 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 07:14 AM
Discussion Quadcopter, where to start? Ischim0n Coaxial Helicopters 1 Apr 12, 2012 06:30 AM
