| Thread Tools |
| This thread is privately moderated by prodriverex, who may elect to delete unwanted replies. |
Electrical: DIY Power Distribution Board
I am copying and pasting the following info from my entire build log just so to focus on the PDB alone.
The objective is to hard mount all the ESCs for the multirotors on a single plate of PDB, double sided. Since there is none in the market to handle the higher than expected current and power, the only way to test the idea is to build one, out of acrylic and copper sheet. So here goes. --------------------------------- Now that the frame and motor mount and motor is done.. time to move up the base and think of how to mount the ESC. My design believe in having a low CG and all components should concentrate to the middle as much as possible. Even my base plate is very small at 100x100mm for a 750mm Quad. So to reduce wire and cable clutter, I want to formulate my own PCB to carry those power. So the idea came from http://hackaday.com/2008/07/28/how-t...gle-sided-pcb/ Its interesting to learn that one can laser print onto practically any flat surface, literally.. But instead of meddling with pungent chemicals, i decided to adopt my own method.. Here's the PCb plan on drawing: ![]() S that means, we can employ the same manner to transfer these lines onto a sheet of copper! Voila! But which paper or foil to use? I suppose using the aluminum foil looks better as I can see how the print out will turn out.. But before I can do that, I think it may sense to reverse the color like this: ![]() Reason is simple. the track should be clear of any printing so we do not need to clean it off later. The portion to be cut away will be printed instead. Then off to print direct onto the aluminum foil.. I tried out both dull surface and shiny surface, the effect is the same.. ![]() ![]() Now cut away those tape that held the foil to the paper and remove slowly taking care not to crisp the foil. I realise to print it very nice, always use a super nice and flat foil without any lines.. try.. The foil i had in hand was a lousy one, it was thinner than usual.. Now slowly flip it over and lay the foil with the printed side, down to the copper sheet. You can see the print did almost an embossing on the foil.. this is before ironing.. ![]() Tips. Now, you gonna move that iron around so better tape down the foil too. But do not use plastic tape. I happen to have aluminum film tape so it came in useful.. Then I place the sheet on a flat surface like an acrylic sheet top with a thick but firm cardboard.. I lay a smooth cloth like a shirt over it so that my iron can slide smoothly.. ![]() Turn the iron to the hottest and lets do it! ![]() After 3-4 minutes of moving the iron around making sure it covers all the area.. Remove the hot iron.. remember to turn it off.. wait for the copper sheet to cool.. you can put it in front of a running fan to cool it faster.. And once cool enough to work on, peel the foil away slowly. Here's are the results: This is with less than idea flat foil without lines.. ![]() This is from a nicer foil, almost perfect without lines. ![]() You can see the importance.. I will cut the bull short, than i just trim the printed portion with a big strong pen knife..
While waiting for the epoxy to dry, started to work on the ESC mod.
I removed all the cables that came with it. This is the Turnigy TRUST 55A SBEC. ![]() The bullet I replaced with is Zero Loss 5mm from Astro Flight. They are expensive stuff because Mil grade UAV uses them too. You can find the link here: http://www.astroflight.com/index.php...index&cPath=18 After finishing the soldering, place it on the template to check the height balance. ![]() And alignment: ![]() ![]() Here's why this connectors are so expensive. ![]() Double wall female socket to make sure the slide in and out is so precise and smooth that no sanding, no powdering is required. |
Now we proceed to solder all 4mm bullets around the concentric location.
That done, progress to create bore hole to expose just enough copper to solder the zero loss bullet. ![]() ![]() Another view of the bullet inserted. The hole above need to be increase to 4.3+mm so lucky I have imperial sized drill bit set.. [IMG] http://i41.photobucket.com/albums/e2...t/IMAG1809.jpg [/img] ![]() Here's when all of one ESC connection is done up. ![]() The 3phases bullets have their soldering done on the underside. Remember where there was suppose to be the punched out copper sheet dots? The plan was to bore a hole on top of it too, and let enough copper exposed so the top part of the bullets can also have solder flow over them.. Alas, its only a 4mm dot, there wasn't much left when we drilled a 11/64 hole through it although not on the centre of it, just a tiny wee bits of left over copper dot. The moment if we bore a 6mm square shoulder hole over it, I'm afraid the copper dot will be spun off and come out. So we ditched that idea and left it alone. The solder on the underside should be good enough and strong enough. We ate anyway, going to flow another layer of epoxy over the power track to insulate the exposed thinned out portion. Here's another look on the underside where the solders are. ![]() As for the +ve and -ve bullets, we did the boring too, just deep enough to expose the copper. There is no need to be precise, just eye balling will do since there was no need to drill a through hole for this. So anywhere close to the bullet's diameter will do. The bore drill size is 6mm, so there's a little room for off centre. You can see the 2legs dropping down from the ESC are the power connectors. The one closer to the edge of the plate is the -ve one. ![]() See the off centre causing the solder to bob out on one side rather than a nice shape which ideally should look like Mount Fuji! Lol.. anyway, that was too much solder in a haste.. will correct it if have time. |
So I should clarify this in my blog too.. I have foot print of 100x100mm to play with. Much larger than any in the market. After some drawing, it was extended to 114x114mm. And this copper sheet is already thicker than 1oz or even 2oz copper found in most PCB. Definition of 1oz of copper: Means it is rolled out to 1 square foot, which yields 1.4mils or 0.03556mm thickness. I just measured the copper sheet in my hand, 0.15mm. That's about 5.9mils. Coming from a Mil-Spec definition, as a guide to Mil Std 275E - Trace Current Carrying Capacity of Copper, http://www.armisteadtechnologies.com/trace.shtml every 1/2oz thick of copper PCB, under 0.2" wide track width, can carry 7.5A. My average track width is 5mm minimum, ie. 0.19685", close to 0.2" definition. I have 5.9mils, so that makes it 63A if it travels for one long foot! Since it is shorter, it can take in much more. Hope this help in theoretical planning at least. No, I dun intend to put it through any bench test to see how high it can take.. I dun have a 2nd piece yet..
| Thread Tools | |
| Discussion DIY Power distribution board for quadcopter | Lars81 | Multirotor Electronics | 4 | Oct 02, 2012 04:42 AM |
| Discussion Are there any power distribution boards for 36mm boards? | machina | Multirotor Talk | 1 | Apr 18, 2012 11:41 AM |
| Discussion Power distribution board for Heavy lift Octo Needed | gtxkid | Multirotor Talk | 4 | Mar 04, 2012 02:21 PM |
| Discussion Power distribution board for Heavy lift Octo Needed | gtxkid | Power Systems | 5 | Mar 01, 2012 01:43 PM |
| Sold Power distribution boards 100 amp | Anarchy1 | Aircraft - Electric - Power Systems (FS/W) | 0 | Feb 28, 2012 05:25 PM |
