Old Oct 17, 2012, 10:10 PM
eng30 is offline
Find More Posts by eng30
Nashville TN
Joined Jan 2007
Looking for a 3 meter glider Stepping up from a Radian
What would be a good glider to step up to from a Radian, I will still keep and fly the Radian, but would like to try a 3 meter ship. All recommendations are welcome...I fly in middle TN Thermals are small-medium on most days.
Thanks, Eng30
eng30 is offline Find More Posts by eng30
Old Oct 17, 2012, 10:23 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Are you looking for another foamy? Or do you want to try a woody? Glass? Home built, ARF or RTF? How much flying experience do you have?
The more we know about you and your want's/abilities the better the suggestions.
Fly Wheel is offline Find More Posts by Fly Wheel
Old Oct 17, 2012, 10:33 PM
eng30 is offline
Nashville TN
Joined Jan 2007
Hi, flying gliders about 2 years... Foamy or woody......can build.....no glass....ARF's or RTF's would be ok.. My main focus is getting a good flying glider.....the Radian was a very good value and flying glider. I also fly a 2 meter Spirit .
Eng30
Old Oct 17, 2012, 11:41 PM
tkallev is online now
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
You might want to consider the new Mystique 2.9 offering from Horizon. There's a big thread on this bird over in the Electric Sailplane forum:
http://www.rcgroups.com/forums/showthread.php?t=1716172
tkallev is online now Find More Posts by tkallev
Old Oct 18, 2012, 12:42 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Do you want RES or ailerons?
I know people who like the J K Thermic, and it's available both ways:
http://www.rcgroups.com/forums/showthread.php?t=491036
I realize it's only 2.5 meters, but it ought to perform a lot better than your Radian anyway. Has a wide speed range.
If you go over to Skybench.com, there are a bunch of gliders around 3 meters, most of which seem suitable. The Paragon has an excellent reputation as a slow floater.
The Mirage is supposed to be a good flyer and very simple, is at Isthmus Models.
The Ava is a VERY good flyer, and also easy to fly. Floats as well as just about anything, but with more speed range and nice handling. Assuming your budget goes that far. It does have a tendency to break into small pieces if you do something dumb and crash it really hard, where some other gliders might break into medium sized pieces.
lincoln is offline Find More Posts by lincoln
Old Oct 18, 2012, 08:56 PM
kilwein is offline
Find More Posts by kilwein
kilwein's Avatar
Joined Jan 2007
Second the AVA.
Have the AVA-E at 51oz AUW and it does very good with small to big thermals.
It is one you will not regret getting, if it fits your requirements.
Have the Paragon and it is a slow floater, mine is a little on the heavy side.
A BOT is not to shabby when built light.
kilwein is offline Find More Posts by kilwein
Old Oct 18, 2012, 10:08 PM
eng30 is offline
Nashville TN
Joined Jan 2007
They all look good.....but I seem to go back to the Skybench site....so many choices
Old Oct 20, 2012, 01:06 AM
lincoln is offline
Joined Dec 2001
If you're slightly more ambitious, there's always the Bubble Dancer. Even better than an Ava if done right.
Old Oct 20, 2012, 04:19 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Thanks, Eng30
Eng30
Pure or electric?
Thermal or slope.
$200 or $2000?
If a molded FG fuse is out of the picture then you are pretty much restricted to RES wood kits.
www.skybench.com
Olympic 3 or Skybird would be good choices.
www.mmglidertech.com
Marauder
aeajr is offline Find More Posts by aeajr
Old Oct 20, 2012, 08:54 AM
eng30 is offline
Nashville TN
Joined Jan 2007
A molded FG fuse is out of the picture, sad to say.....budget is for a total build is 600-750 dollars. Need a Thermal ship. A ciub member just sold a Oly 3 but I missed buying it.
Still scratching my head on the decision......we have a big swap meet Nov. 3 will look there and if I don't find anything I will buy new .
Eng30
Old Oct 20, 2012, 09:30 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
So, do you hate fiberglass fuselages or are you under the miss impression that they are expensive?
Molded FG fuse is not expensive, relative to your budget. So many moderate priced planes come with molded FG fuselages. You simply knocked out a lot of excellent models based on material rather than price.
Since you mentioned an OLY, I presume that a RES glider is an option as you have not specified anything about control surfaces.
So $750 for the build. Does that include the servos, receiver, battery?
Is this an electric glider or a pure glider? You have an e-glider. Should we assume e-glider?
If a FG fuse is OK then we have a LOT of planes to recommend.
I am going to assume an e-glider that can be RES or full house.
Budget:
$750 - $250 for electronics ( I still don't know that that includes ) = $500 I will consider this the working target for the e-glider alone.
Kits:
www.skybench.com
Semi Kits - Most of the work is done but you still have to do some building type work
Oculus - a lot of the build is done for you
http://www.mmglidertech.com/oculus.php
Art Hobby - Wide selection in the 2.5 to 3.1M range
http://www.arthobby.com/index.php?pa...ub_category=50
ARFs -
Dragon Fly Strong E - 3.5 meters $650 - pushes your budget but a great value
http://www.soaringusa.com/DragonFly-Strong-E.html
Avia - 2.5M
http://www.icare-rc.com/avia.htm
Albatross - 2.75M -
http://www.espritmodel.com/albatros-2-75s-e-arf.aspx
Albatross - 3M -
http://www.espritmodel.com/albatros-3se-arf.aspx
Gracia - 3.1M
http://www.espritmodel.com/gracia-31e-f5jales-arf.aspx
http://www.icare-rc.com/gracia.htm
Mystique 2.9M - New glider - we don't know much about how it thermals yet
http://www.horizonhobby.com/products...9m-arf-EFL4905
That should be enough to get you started, now that we put FG fuselages back into the mix.
Old Oct 20, 2012, 09:18 PM
lincoln is offline
Joined Dec 2001
http://www.vintagesailplaner.com/SmoothGeniePro.html
Old Oct 21, 2012, 08:27 PM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
Lots of good recommendations and models to choose from, but if you keep going back to the Skybench website, I think you can guess what my recommendation is.....
ok, ok, I'll say it........
PARAGON!
LVsoaring is online now Find More Posts by LVsoaring
Old Oct 21, 2012, 10:32 PM
ray foley is offline
Find More Posts by ray foley
volare est vivere
ray foley's Avatar
United States, OH, Toledo
Joined Jan 2005
hi there from Toledo
How about a Houston Hawk? How much of a builder are you?
ciao -rjf
ray foley is offline Find More Posts by ray foley
Old Nov 04, 2012, 08:55 AM
eng30 is offline
Nashville TN
Joined Jan 2007
Well I bought a Olympic 3 ......will start the building soon .
Thanks for all of the info.
Eng30
For Sale 3 meter V-tail Cohen F3F glider up for grabs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! speedster Aircraft - Sailplanes (FS/W) 3 Jul 05, 2012 10:23 PM
For Sale slope racer 3 meter glass V-Tail like new RTF DEAL (Cohen glider) up for grabs!!!!!!! speedster Aircraft - Sailplanes (FS/W) 0 Jun 12, 2012 03:49 PM
Discussion 6mm Bullets: Next Step Up From 3.5mm Bullets? roo_ster Power Systems 6 May 25, 2012 10:00 PM
Question Stepping up from WhiteWings gliders to something......? jmccollough Free Flight 20 Mar 08, 2012 08:01 PM
Discussion Lifelike Glider: step up in power from 2x edf-50 motor with 3/2 prop? mike93 Pusher Prop Jet Models 2 Apr 24, 2006 09:48 AM
