This thread is privately moderated by ckreef, who may elect to delete unwanted replies.
Old Oct 17, 2012, 04:57 PM
ckreef is offline
Find More Posts by ckreef
ckreef's Avatar
Danville, GA
Joined Aug 2010
Mini Ultra Stick Conversion
This is my Mini Ultra Stick --- EP to glow conversion.
I used a OS .25 LA.
The Mini Ultra Stick comes with 2 fire wall plates for different electric setups. I made a 3rd firewall plate (same size as the other 2) from plywood and covered it in white covering. Drilled the holes for the engine mount and then epoxied that in the proper position. When you get the Mini you'll understand exactly what I'm talking about.. I used a Dave Brown motor mount.
I cut out the battery holder tray from the front compartment and reinforced the 2 sides and floor of what will now be your fuel tank compartment with 1/2" wide strips of plywood. I used a 4 oz flex tank surrounded on the bottom and sides w/ 1/4" foam then velcro'ed in place.
The Rx battery I used was a long, thin, 6v 1100 mah NIMH and installed about 1/2 way between the TE and the horizontal stabilizer inside the fuselage. I had to glue in place a plywood holding tray with a vecro strap in order to hold the battery in place. Battery was installed through the bottom cutout panel. I installed a Rx switch/jack on the left side under the wing.
I used 9 gram metal gear servos for all controls except the throttle. You will need metal gears for the fast, high performance you will get with the Mini Stick.
I added a steerable tail wheel along with 1 oz of lead in the back to get the proper CG.
Start with the control throws on low rate as that seems more then adequate for tight fast aerobatics.
She's a fast little plane and flies good. I fly her for 4 or 8 tanks of fuel every week and she can handle a good bit of wind. Grease her in a little hot to avoid bouncing her down on landing.
ckreef is offline Find More Posts by ckreef
Old Oct 19, 2012, 11:19 PM
ckreef is offline
ckreef's Avatar
Danville, GA
Joined Aug 2010
I've had a few questions asked along the way which is why I did this blog ------------------ here is a few more questions answered ----------------------
There is a bit of right thrust already built into the motor mount. I would leave it as is and NOT add any extra thrust adjustments.
I HAVE DONE SOME EXPERIMENTS. I initially tried 2 washers worth of extra "right/down" thrusts in between the motor mount and the firewall. That was way to much. I now have 1 washer worth of extra thrust and I still think it is a little to much. At some point in the future I will uninstall the motor and remove that extra 1 washer.
The main landing gear is a little weak. I thought about adding a cross member to stiffen it up but ..................................... The week main gear acts as a shock absorber so on a hard landing some of the force is absorbed instead of transferring it all to the frame where the landing gear is attached.
On this note, do NOT use a wooden prop. With a hard bounce you will get a ground/prop strike and break the wooden prop every time. I would suggest a Master Airscrew prop as they seem to take the most abuse without breaking.
Old Oct 19, 2012, 11:23 PM
ckreef is offline
ckreef's Avatar
Danville, GA
Joined Aug 2010
Here are a couple of flight pics -- Hope to one day post a video.
Sold LPU E-Flite Mini Ultra Stick ScottB2 Aircraft - Electric - Airplanes (FS/W) 6 Sep 14, 2012 05:58 AM
Discussion Conver a balsa stick 40 plus FireChief4302 Glow to Electric Conversions 6 Aug 25, 2012 01:41 AM
For Sale Wing and Tail Feathers from Mini Ultra Stick~Free LPU Prescott, AZ keninaz Aircraft - Electric - Airplanes (FS/W) 2 May 26, 2012 10:55 PM
Sold Eflite Mini Ultra Stick-145.00--LPU Cash only brendon33 Aircraft - Electric - Airplanes (FS/W) 0 May 05, 2012 12:29 AM
Sold Landing Gear for Mini Ultra Stick flyandi Aircraft - General - Miscellaneous (FS/W) 0 Apr 09, 2012 12:22 PM
