Joined Oct 2009
Which part number heli was it? There are a few but the prices don't match. Is this OK?
HK do a FBL head for $23 Sheesh!! The shipping charges are $36!!! for a head, a heli kit and 4 sets of C30 blades Is this right?
Cheshunt, Hertfordshire
Joined Aug 2009
Lazygit,
The heli you linked was the right one. I ordered it from the UK warehouse and it came in 48hrs for £23 Pounds Sterling the head I got from ebay. I'll find the link hang on. http://www.ebay.co.uk/itm/Flybarless...item46085a2da6 Try that |
Joined Aug 2009
I this picture is my method of giving the blades the ability to cone. the hinge material is 2 Laminations of glow fuel container plastic( 5 litre) sandwiched between 1.5mm fiberglass sheet. This gives a nice snug fit between the blade grips.
On the HK cierva three blade head there is a 15 degree 'hinge line' I have incorporated this in the blade holder as shown. |
Joined Aug 2009
Pic 1 shows the general layout of equipment. The glass fibre board frames attach to the metal heli side frames using existing holes in the metal. This view shows the rake angle of the shaft in relation to the keel tube (datum) 8 degrees.
Halfway up the GF frames 6mm holes were drilled, 6mm CF tube cyanoed in to provide a base for another horizontal GF board between the sides. This board houses the 2 ESC's and the RX (underneath) also seen here is the butchery to fit the motor mount The bottom of the GF side frames are drilled to take the 8mm axle support. The 6mm axle slides into that and is cyanoed. the two cyclic servos can be seen in this pic too Pic 2 shows the minimum heritage tailplane Pic 3 shows the motor and amount of offset Link for 4 blade head http://www.ebay.co.uk/itm/Flybarless...item46085a2da6 try that |
Joined Oct 2009
Thanks for the links. Does the UK warehouse have the blades? I'll have to try navigating the HK system, I haven't used it yet as I refused to pay the shipping costs and may as well buy from UK suppliers when that is factored in.
One thing that will have to go is the heli canopy doesn't have the autogyro appeal. (And it covers up some, what looks like, luxury cnc machined FG sheet )I think with the swash plate it is much more sensitive as you are actively altering the incidence angle of the blades. I might be wrong. A very short servo arm might help and allow you to have better resolution of control movement. |
I believe that one of your problems "may" be in the fact that you attempted the ROG like "a scalded cat ". I have found over the years that these models can be very twitchy at a higher speed, in fact my two blade Minimum flipped on its back several times as I was testing it.only to find that it was stable at a lower speed,
Happy Landings Chris... And yes I have been watching with interest ,but only make a comment when I think it is applicable. |
Joined Aug 2009
![]() Chris, I don't have enough experience with Autogyros yet but I will take on board what you say in the next trial. I think I may have had too much forward trim on in the first place. My main fears with this model were that: a) it wouldn't have enough power and: b) the blades wouldn't have enough lift Both of these fears have evaporated. I guess I just need to learn to fly it |
| Thread Tools | |
| Discussion My autogyro with pre-rotator | Axbri | Auto Gyros | 0 | Jul 07, 2010 01:50 PM |
| Yippee! Poor Man's Pre-Rotator for Autogyro! | jodini | Auto Gyros | 23 | Sep 06, 2009 12:41 PM |
| Video Minimum v4 autogyro prototype | JochenK | Electric Plane Talk | 3 | Oct 30, 2007 06:01 PM |
| Video Minimum autogyro | JochenK | Electric Plane Talk | 2 | Sep 13, 2007 11:34 AM |
| Video autogyro Minimum | JochenK | Electric Plane Talk | 4 | Sep 26, 2006 07:23 PM |
