Old Oct 20, 2012, 03:23 PM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
All the wires in brushless motors are coated with some kind of enamel. Water won't get to the conductive copper inside.
WiseDuck is offline Find More Posts by WiseDuck
Old Oct 20, 2012, 03:38 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Garry s View Post
Van - opening sentence: 100% accurate, 100% unhelpful, 50% funny OK, 60% funny
As for the rest of it, I understand that but wonder why the water doesn't short out all the bits of leccy what are coming out of the wires ...but then again I was conditioned by my grandma..'steam irons, mixing electricity and water....it's madness'
The wires have an insulating varnish on them. If the wires were bare and touching each other the motors wouldn't work because the wires would short out. Tthe 'lectricity stays in the wire vs jumping across the varnish because it's easier to flow through the wire. Dunking them in water results in no difference with the insulation...they're still insulated from each other by the varnish coating.
FWIW, water is actually a great insulator. It's the contaminants in the water that creates conductivity. Of course, the higher the voltage the more likelyhood of exposed wire ends being able to 'arc' to each other vs flowing through the wire itself. We run at pretty low voltage, relatively speaking, so it's even less likely any exposed wiring would short out unless they were about touching.
Okay, let's try a little analogy. Take 3ft of rubber tubing. The tube material itself is the 'insulator' and the ID of the tubing is the 'conductor'. Blow thru one end of the tubing and all the air comes out the other end because..why? Because it's easier to flow through the tubing than penetrate the walls of the insulator..so 'what goes in one side comes out the other'. Works good in air, right? Now take that rubber tubing and immerse it in water...keeping the open ends out of the water. Now blow thru one end. Does the air come out the other side or does it all bubble up from the water? It comes out the end because the tubing in 'insulating' the air from the water. The same thing happens with the motor wire windings. The current 'flow' goes thru the wire because the insulation on the wire keeps it there..be it in or out of water. In essence, the wires in the motor are in a closed loop. What goes in one end has to come out the other.
Vantasstic is offline Find More Posts by Vantasstic
Old Oct 20, 2012, 04:22 PM
Garry s is offline
Find More Posts by Garry s
A new day, a new gadget
Brighton, UK
Joined May 2006
Ah, hadn't realised motor wires are insulated. Thank you for that, now I understand.
Garry s is offline Find More Posts by Garry s
Old Oct 20, 2012, 05:15 PM
Jmm_jammy is offline
Find More Posts by Jmm_jammy
United Kingdom, England, Cambridge
Joined Aug 2012
Very interesting read, thanks for all the info!
So after a motor has been in water, surely this will decrease its life span as the water may dry out and cause some kind of friction or even rust? How would you ever know if the wd40 was doing its job properly
Jmm_jammy is offline Find More Posts by Jmm_jammy
Old Oct 20, 2012, 05:40 PM
SeismicCWave is online now
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
You are talking about relatively low voltage and fresh water. Your grandma's iron probably uses 240V.
SeismicCWave is online now Find More Posts by SeismicCWave
Old Oct 20, 2012, 05:42 PM
AMA 46133
Hawaii
Joined Feb 2003
The armature is made out of iron and that will definitely rust. So you need to clean that out. The bearings may or may not be that bad because some bearings are made out of stainless steel. However there are many types of stainless steel alloy and some stainless steel will rust.
You will never know if the WD40 is doing its job unless you check the motor periodically.
Old Oct 20, 2012, 07:12 PM
shdwkeeper is offline
Find More Posts by shdwkeeper
United States, CA, Anaheim
Joined Dec 2011
I'm sure you can do one final run of the day out of the water and everything would be dry on the motor, or when you get home blow the motor out with an air compressor.
shdwkeeper is offline Find More Posts by shdwkeeper
Old Oct 20, 2012, 07:48 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
I like this frame but I dont see the clear one on the website. Is that version not for sale?
epyonxero is offline Find More Posts by epyonxero
Old Oct 20, 2012, 08:17 PM
Flyrobot is offline
Find More Posts by Flyrobot
youtube.com/#/user/flyrobots
Indonesia
Joined Apr 2011
Yes the polycarbonate one doesnt show up on shop website?
John
Flyrobot is offline Find More Posts by Flyrobot
Old Oct 20, 2012, 09:22 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Here's an idea. Buy $10 motors, oil the bearing, fly, dunk, fly, repeat. When the motors start sounding rough buy more $10 motors, oil the bearings, repeat.
Old Oct 20, 2012, 10:10 PM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
the motors are wound with each end joint together to create 3 phase-like ending. and then soldered and joined to 14awg for eg, wire for the length so that you can connect to your esc. Now this part is questionable. I don't think they are conformal coated before shrink-tube covered. spontaneous splashing of water won't get enough inside. soaking in will need a long time to have water lodged in it.
Anyway even if it is shorted, there's no electronic inside the motor, just the ESC is connected.. you get it? I think I do.
prodriverex is offline Find More Posts by prodriverex
Old Oct 20, 2012, 10:20 PM
AquaCopters is offline
Find More Posts by AquaCopters
Joined Oct 2012
John
You are both correct, the clear frame is not up... yet. I have gotten a TON of crap for it. We are trying to get this out as early as we can. If you subscribe to our youtube channel you will be one of the first to know when it is in.
AquaCopters is offline Find More Posts by AquaCopters
Old Oct 21, 2012, 04:13 AM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
These don't look 100% waterproof, but water resistant. The motor screw mounts don't seem to have any kind of seal like an o-ring. I'd imagine if you held it under the water some water would get in, but hopefully someone who buys one can do some real tests.
The Recursion is offline Find More Posts by The Recursion
Old Oct 21, 2012, 04:21 AM
Joined Aug 2012
AquaCopters, have you guys performed any kind of endurance tests on these yet? i.e having the quad fully submerged for a whole flight ( incase someone flew one out too far, flipped it upside down in the water and had to go get a paddle boat to retrieve it..)
And to answer most our questions is there a particular motor you have done research with that would take on water requiring little or no maintenance?
Old Oct 21, 2012, 05:28 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I've been emailed some instructions. It should be 100% waterproof. You need silicone to complete the build, preferably one of the same colour as the shell. You need to drill holes for the motor wires, feed them through to the ESC, then seal the hole with silicone. You also need to put a dab of silicone in every thread where the motor cross mount goes, that'll keep water out.
Discussion Anyone Seen These Before? Bought from Trendtimes.com? scas Dock Talk 2 Jun 14, 2012 09:13 PM
Discussion Anyone seen this before??? F27QFlyer Parkflyers 10 May 11, 2012 03:21 PM
Discussion Anyone seen this before??? F27QFlyer Hot Online Deals 7 Apr 25, 2012 02:43 PM
Discussion never seen these before (pic) Excogitate Electric Plane Talk 6 Apr 03, 2012 02:59 AM
