Old Dec 06, 2012, 09:08 PM
Kaikokid is offline
Find More Posts by Kaikokid
New Zealand, Northland, Kaikohe
Joined Aug 2011
Originally Posted by mrittinger View Post
Generally , if you draw a line from the CG down , at about 15 degrees forward, thats where your wheels shold end up....on taildragger anyhow.
That's with the plane sitting on the ground ??
Kaikokid is offline Find More Posts by Kaikokid
Old Dec 07, 2012, 09:30 AM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
Getting the uc and support struts roughed out was a high hurdle for me. Didn't know how it was to be done when the project began. Should be all downhill from here!
phillip57 is offline Find More Posts by phillip57
Old Dec 12, 2012, 09:04 AM
S/E Michigan
Joined Jun 2010
I've hit the mid-project doldrums.... fantasizing about the next build, a WWI project.
Ahhh...... I've laid out the plans for the left wing, have some ribs to cut.
Received the graphics from Callie, it was a pleasure working with her!
Old Dec 12, 2012, 10:08 AM
Thayer is offline
Find More Posts by Thayer
Owner - Flying Models
United States, CT
Joined Aug 2003
Well, it wouldn't be a fun hobby if there weren't a slug of projects worth dreaming about. On the other hand, you are well along with the NYP yet still have some enjoyable building ahead. You did a great job with the landing gear struts. It seems nearly all of the personality of this plane happens at the front end and getting the gear right is a hurdle. The dummy engine and turned finish for the cowl are pure cosmetics but the landing gear has a job to do. You'll get back into it. FWIW, I would be surprised if you go past the 5-lb mark. While there are a lot of pieces, none are very big. Even at 5 pounds though, you will have a modest wing loading. I can't think of a good reason to go more than 350 watts on this model. You won't need it and having more only means carrying more weight. Not that this design wasn't about carrying weight...
Thayer is offline Find More Posts by Thayer
Old Dec 12, 2012, 11:55 AM
S/E Michigan
Joined Jun 2010
Having the power 25 means a little more weight, however, I really like swinging a big prop at low rpm. The sound of a big fan on "low" as it flies by under my nose...
Old Dec 12, 2012, 01:12 PM
Thayer is offline
United States, CT
Joined Aug 2003
No question, a big prop is key, but that can be done with a low Kv setup. Don't be afraid to do some testing with one cell less than you might normally spec. Years ago Jim Collin out in Ca did some fantastic large scale electrics using monster props and about half the recommended cell counts.
Thayer
Old Dec 12, 2012, 01:32 PM
S/E Michigan
Joined Jun 2010
Sounds interesting... I have the Low KV version of the power 25, swinging a 14 " prop, planning to use 3S.
I did some experimenting with the little DV Albatros. A park 450. 3S 850 mah, and a 10" prop. She'd pull a wide loop on that set up. Very Aerobatic. With 2S 850 and 11" prop, she flew more scale like. The motor warmed more with 2S, it needed more throttle. An ounce less AUW too, but a passer by wouldn't know the difference. I usually use 3S with that model, I have 2 of them, and I like having the extra juice. The dynamics must be all together different on large scale models.
Old Dec 17, 2012, 08:12 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Gear placement is with the datum of the fuselage LEVEL.
Found a pic from the EAA Spirit when it was at Detroit City Airport in 1977....
mrittinger is offline Find More Posts by mrittinger
Old Dec 17, 2012, 09:04 PM
S/E Michigan
Joined Jun 2010
I've not seen a pic of the original with the gear splayed out like that. Must be an intentional deviation from the original plans, like the minimal dihedral.
Old Dec 17, 2012, 09:22 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Pictures of the original SoSL clearly show zero dihedral. If fact the gear and strut geometry often makes it look like there is anhedral.
Great reference site I used:
http://www.charleslindbergh.com/plane/index.asp
The gear splay is also not seen on the original
Grejen is offline Find More Posts by Grejen
Old Dec 17, 2012, 10:34 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
The wing is Flat check the photo
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Dec 17, 2012, 11:35 PM
Grejen is offline
IAMCANADIAN
Grejen's Avatar
Joined Jul 2002
Wasn't an EAA replica lost due to a gear strut failure?
Old Dec 18, 2012, 05:45 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
All I know is that the replica pic shot from the front shows obvious slight dihedral, somehow maybe after they put the struts on? It appears there are several replicas out there, EAA made two. Specs are different on each one....span, length, etc. It's possible they tried different dihedral. This article says a ryan NYP Replica is a nightmare to fly: http://www.charleslindbergh.com/plane/spirit.asp
Gear, I dont know. Maybe differnt geometry,maybe weight?
http://www.airventuremuseum.org/coll...%20Replica.asp
Old Dec 19, 2012, 08:29 AM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Nice work on the motor and cowl. I would suggest light glass on the outside of the cowl too.
Pat Daily is offline Find More Posts by Pat Daily
Question Spirit of St Louis Hossinarizona Scale Kit/Scratch Built 5 Sep 21, 2012 07:03 PM
For Sale Spirit of St. Louis wildskies Aircraft - Electric - Airplanes (FS/W) 0 Aug 26, 2012 01:31 PM
Discussion Spirit of St. Louis / Cub STRINGFLY Scale Kit/Scratch Built 1 Aug 04, 2012 01:08 PM
Sold Spirit of St.Louis by Graupner jricchio Aircraft - Electric - Airplanes (FS/W) 2 Jun 18, 2012 07:28 PM
Wanted Flyline Spirit of St. Louis apage Aircraft - Fuel - Airplanes (FS/W) 1 Jun 05, 2012 08:31 AM
