Old Oct 31, 2012, 03:37 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
It was way lighter than the Guillows plastic which isn't saying much. Did it in 6 pieces per the actual SoSL but simply taped the pieces together from the inside rather than flush riveting.
http://www.rcgroups.com/forums/showt...=3#post2602773
Grejen is offline Find More Posts by Grejen
Old Oct 31, 2012, 11:32 PM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
The aluminum tape would be lighter, with a model this size does it really matter? If I was really concerned about weight , why weren't 1/8 stringer stock used for the longerons.... well, the model ought to have some substance. Wouldn't want it to blow away in a breeze. The 54" tiger moth flipped over in a breeze taxiing back to the flight line after a landing.
The aluminum can sheet would be great if it could be shaped to the curves of the scale model. I want to get the shape of the front end as close to scale as is within my means. I read that the burnishing of the aluminum sheeting on the original was intended to disguise the hammering, and other marks that were required to get it to conform to the design.
I never saw the "Spirit" as being an aesthetically beautiful aircraft. It's the history that captures my imagination. Form follows function, there is beauty in that. There are different kinds of beauty.
phillip57 is offline Find More Posts by phillip57
Old Nov 01, 2012, 10:42 PM
S/E Michigan
Joined Jun 2010
Spending a lot of time just staring at the plans... thinking and rethinking things through. I figure the uc mounting blocks don't need to be the width of the fuselage.
This build is very much like the Sig Clip Wing Cub, which was my first RC build, and the model that taught me to fly. She was over engineered by modern e-flight standards, but she may yet see a conversion. I'm through with ic engines.
Old Nov 02, 2012, 02:54 AM
Chompwat is offline
Find More Posts by Chompwat
Tally Ho Chaps!
Chompwat's Avatar
United Kingdom, England, Ipswich
Joined Mar 2012
That's a lovely cub. E conversion & FPV? There's a thought!
Chompwat is offline Find More Posts by Chompwat
Old Nov 02, 2012, 01:38 PM
S/E Michigan
Joined Jun 2010
The Power 25 ought to give her plenty of reserve.
Old Nov 04, 2012, 12:53 AM
Grejen is offline
IAMCANADIAN
Grejen's Avatar
Joined Jul 2002
In six pieces there are no large compound curves so it wasn't difficult to shape. Yes it does have it's own beauty.
Old Nov 04, 2012, 01:49 PM
S/E Michigan
Joined Jun 2010
Moving along a bit at a time...
Old Nov 04, 2012, 11:35 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Just remember, you'll need 10000mah to replicate the flight time, in scale, for your airplane!! Hehehe. Just kidding. Great start. I've been coming back to see the progress when I can. Truly an historical plane. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Nov 05, 2012, 09:25 AM
S/E Michigan
Joined Jun 2010
There will be a compression spring in the shock assembly. The uc will be heavier than I'd like, I'm thinking it needs to be, since it will be integral with the airframe. Won't be able to remove it for straightening or replacement.
Old Nov 05, 2012, 10:53 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Hurst Bower's plans were always seemingly over complex.
Lovely models, I have built most of his over the years.
But one does need do a lot of extra parts.. the 'sprung' suspensions, so typical of his dwgs and genuinely seductive to be fair about it, could be simplified though...IF.. you want to venture beyond the printed paper.
Bare is offline Find More Posts by Bare
Old Nov 05, 2012, 11:00 AM
S/E Michigan
Joined Jun 2010
I don't know how much more simple the sprung suspension could be... I am not an engineer.... The original kit could've gotten by without suspension. This model, about 1/8 scale weighing between 5 and 6 lbs can use it.
Old Nov 05, 2012, 10:34 PM
challenger_i is offline
Find More Posts by challenger_i
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Fisher County
Joined Mar 2005
Not sure how large a swirl you need, but the erasor on the big-honking First Grader pencils, dipped in fine polishing compound, make an excellent swirling tool.
We're excited... this aluminum tape was found at the local hardware. A section was applied to the metal jar top, Then a wire brush in the dremmel did the burnishing. Z-Poxy ought to seal, and firm up the surface of the balsa blocks which will make up the nose of the model, which will then be sanded smooth. The aluminum tape applied and burnished. Such is the plan....
challenger_i is offline Find More Posts by challenger_i
Old Nov 05, 2012, 11:32 PM
S/E Michigan
Joined Jun 2010
Thanks for the suggestion Challenger_i..... i like the swirl the dremmel brush gives. It's very close to the first grader pencil eraser.
Question Spirit of St Louis Hossinarizona Scale Kit/Scratch Built 5 Sep 21, 2012 07:03 PM
For Sale Spirit of St. Louis wildskies Aircraft - Electric - Airplanes (FS/W) 0 Aug 26, 2012 01:31 PM
Discussion Spirit of St. Louis / Cub STRINGFLY Scale Kit/Scratch Built 1 Aug 04, 2012 01:08 PM
Sold Spirit of St.Louis by Graupner jricchio Aircraft - Electric - Airplanes (FS/W) 2 Jun 18, 2012 07:28 PM
Wanted Flyline Spirit of St. Louis apage Aircraft - Fuel - Airplanes (FS/W) 1 Jun 05, 2012 08:31 AM
