Old Oct 23, 2012, 06:36 PM
Liteweight is offline
Find More Posts by Liteweight
Dallas, TX
Joined May 2005
Super, thank you. BTW, I obtained a CD with all the Flyline plans from a seller on eBay. I had bought a kit without plans and Kinkos charged $5 for a sheet that was perfect. I am wondering if the .pdf files on the CD can be enlarged 100% and then be printed; worth a try! Thanks again; I will be following your build. Great work so far.
Liteweight is offline Find More Posts by Liteweight
Old Oct 23, 2012, 07:17 PM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
I believe thats how it's done. Call around the reprographics shops in your area. If you're lucky, you won't have to go far. Which model are you thinking of enlarging?
phillip57 is offline Find More Posts by phillip57
Old Oct 24, 2012, 06:06 AM
Dallas, TX
Joined May 2005
Flyline plans
Not sure which one yet, maybe the Luton Minor or the Robin. The CD is at the office downtown and there is a Kinko's a short walk from there. Last time I e-mailed it and picked it up. Thing is, some of the files are very large so need to keep that in mind. I'll sure let you know how that turns out. Thanks.
Old Oct 25, 2012, 10:04 AM
S/E Michigan
Joined Jun 2010
The plans call for a solid balsa trailing edge on the wing. I figure a built up one will weigh less. Light balsa was chosen for the ribs, scale spacing as well. The rear spar is light, while hard balsa was chosen for the main.
Old Oct 25, 2012, 10:55 AM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Nice work!
Pat Daily is offline Find More Posts by Pat Daily
Old Oct 25, 2012, 08:00 PM
Sam Agassiz is offline
Find More Posts by Sam Agassiz
Joined Mar 2005
FWIW, sez 'ere that the prototype used Clark Y, i.e. no undercamber.
http://www.google.ca/search?hl=en&si....1.mynjLDLLrng
An old maxim from free flight days long ago: "Make it fly - use Clark Y"
Sam
Sam Agassiz is offline Find More Posts by Sam Agassiz
Old Oct 26, 2012, 07:01 PM
S/E Michigan
Joined Jun 2010
It's not crystal clear in my mind how to proceed with the wing center section, so I'll do the leading and trailing edge sheeting, then set the right half aside. I'll wait until the fuselage is roughed out before proceeding with the wing center section.
Old Oct 28, 2012, 10:03 PM
S/E Michigan
Joined Jun 2010
The wing tips are soft balsa.
Old Oct 29, 2012, 05:25 PM
otrcman is offline
Find More Posts by otrcman
Joined Mar 2009
Sam
An interesting story about the Clark Y airfoil and its origins: Virginius Clark was an aeronautical engineer in the WWI era and beyond. Among the early work that he did for NACA was to develop a series of airfoils which were named for him. There was a Clark W, a Clark X, a Clark Y, and a Clark Z. All the airfoils were similar in appearance and performance from our perspective. When Donald Hall (Chief Designer for Mahony-Ryan Aircraft) chose an airfoil, he selected the Clark Y from among the available state of the art sections.
When the Spirit Of St. Louis successfully flew the Atlantic, many new commercial aircraft and models came out loosely based on the same layout. The other Clark airfoils received far less notoriety even though they were nearly the same.
Since that day, modelers have gravitated to the airfoil that the Spirit used. Over the generations most of us have forgotten why we are still using it. It is a good airfoil, but it's popularity is due mostly because that's what Lucky Lindy used.
Dick
otrcman is offline Find More Posts by otrcman
Old Oct 29, 2012, 05:31 PM
S/E Michigan
Joined Jun 2010
Thanks for the history lesson! Anything thats relevant, feel free to kick in.
Old Oct 30, 2012, 02:07 AM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Cool story about Clark Y!
gupi is offline Find More Posts by gupi
Old Oct 31, 2012, 01:53 PM
S/E Michigan
Joined Jun 2010
We're excited... this aluminum tape was found at the local hardware. A section was applied to the metal jar top, Then a wire brush in the dremmel did the burnishing. Z-Poxy ought to seal, and firm up the surface of the balsa blocks which will make up the nose of the model, which will then be sanded smooth. The aluminum tape applied and burnished. Such is the plan....
Old Oct 31, 2012, 01:59 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Why not use actual aluminium and burnish it? For my Guillows conversion I used beer/pop cans turned inside out. You have to sand off the varnish. I replicated the burnishing with a pencil eraser in a drill press.
Grejen is offline Find More Posts by Grejen
Old Oct 31, 2012, 02:14 PM
S/E Michigan
Joined Jun 2010
That's a good idea, I'd thought about it. Just looking at options.
Question Spirit of St Louis Hossinarizona Scale Kit/Scratch Built 5 Sep 21, 2012 07:03 PM
For Sale Spirit of St. Louis SC Johnson Aircraft - Electric - Airplanes (FS/W) 0 Aug 26, 2012 01:31 PM
Discussion Spirit of St. Louis / Cub STRINGFLY Scale Kit/Scratch Built 1 Aug 04, 2012 01:08 PM
Sold Spirit of St.Louis by Graupner jricchio Aircraft - Electric - Airplanes (FS/W) 2 Jun 18, 2012 07:28 PM
Wanted Flyline Spirit of St. Louis apage Aircraft - Fuel - Airplanes (FS/W) 1 Jun 05, 2012 08:31 AM
