Feb 05, 2013, 04:09 PM
Canada, BC, Squamish
Joined Jul 2002
Originally Posted by skcope
Have you tried a pencil eraser? Chock a pencil in an electric drill eraser side down and you can make swirls that way. A drill press is great if you have access to one. I have also glued small swatches of Scotchbrite pads to the end of a dowel with epoxy and had decent results.
-Scott
That's what I used. However you may have to try several types. My pencil eraser worked very nicely but went missing before I finished and I could not find exactly the same eraser again. The pink ones are too soft. Some white ones are too hard. Also your scale is quite a bit larger so a pencil eraser might be too small.
Originally Posted by phillip57
Was all set to iron the covering to the bottom of the fuselage when I remembered these things.... they're distinctive, and easy enough to install without adding hardly any weight. Can anyone tell me what they are?
Those are indeed flare tubes but I believe they were added for the Guggenheim tour after the plane was returned to North America. Similarly, the carb heat box control cable, cowl louvres, and the flags painted on the cowl were not present for the flight to Paris. If you're modelling the plane as it was for the crossing then omit the flare tubes. I do see that you've not yet framed in the periscope.
