Old Jan 22, 2013, 11:56 AM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
Time to figure where the servos are going to be. Can't finish covering the elevator until the pull-pull configuration is complete.
phillip57 is offline Find More Posts by phillip57
Old Jan 22, 2013, 02:25 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Originally Posted by phillip57 View Post
Here's a tricky part.... this is what I couldn't visualize after completing the right wing half. How the center section te is going to merge with the fuselage, and end up looking good. This'll be a challege.
Near as I could tell the TE of the wing is fared into the fuse with three or four long forms. the shape is very slightly concave. You need a diagonal across that last fuse bay on the top. I'll see if I can dig up pics of mine....
Ah.. even better.
Grejen is offline Find More Posts by Grejen
Old Jan 22, 2013, 04:45 PM
S/E Michigan
Joined Jun 2010
Thanks for the pics! The rear view is especially helpful, there are not many from that perspective. I find that the Flyline plans are not exactly scale. I'll do what I can with what has been built to get the best effect.
Old Jan 23, 2013, 05:08 PM
S/E Michigan
Joined Jun 2010
Gotta love Callie Graphics... The "Manufactured by Ryan Airlines", which goes under the NYP, was too small. I'm going to give shot at hand lettering that with graphite, then possibly painting over it.
Old Jan 23, 2013, 07:52 PM
S/E Michigan
Joined Jun 2010
Heck with the graphite, I was thinking easy to erase in case of mistakes. The original was loosely freehanded, so I picked up a fine tip archival ink pen from the art supply.
Old Jan 23, 2013, 11:09 PM
Robert R is online now
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Brushed Humbrol over Doculam makes for very convincing brushed doped fabric. Nice hand lettering.
Robert
Robert R is online now Find More Posts by Robert R
Latest blog entry: Hidden Kit Built Projects
Old Jan 23, 2013, 11:31 PM
S/E Michigan
Joined Jun 2010
Robert
Thanks Robert, the paint is a metallic aluminum, it looks coarse under a magnifying glass. The finish is very scale like.
The geen tape used for linear reference pulled up a few specs of paint. I'm lucky the graphics didn't peel up.
Old Jan 25, 2013, 07:58 AM
S/E Michigan
Joined Jun 2010
Horizontal fin detail. In my early zeal to keep weight off of the tail, three holes were routed in the center section. It was soon realized that the vertical fin had little to mount to. Balsa was subsequently fitted and ca'd to have more for the fin to adhere to. Light filler is the white stuff to either side of the of the former holes.
Old Jan 26, 2013, 02:42 PM
S/E Michigan
Joined Jun 2010
Elevator pull cable detail.... The original probably had a pulley wheel for the cable to ride on. A tiny plastic tube works good for me.
Old Jan 28, 2013, 12:08 AM
S/E Michigan
Joined Jun 2010
This model is heavy in the nose, the 2 oz cowl, the aluminum spinner, long nose moment, light tail feathers. So the rudder and elevator servos will be mounted aft.
Old Jan 28, 2013, 03:31 PM
S/E Michigan
Joined Jun 2010
Both rudder and elevator servos. The screws pass through plywood which is ca'd to balsa spar sections, which are ca'd to longerons. The balsa spar sections "sandwich" the longerons. The longerons are reinforced where they are glued to the fuselage sides.
Old Jan 29, 2013, 08:30 AM
sarkantyu is offline
Find More Posts by sarkantyu
sarkantyu's Avatar
United States, MI, Lake Orion
Joined Feb 2004
great build!Learning a lot.Thanks Joe
sarkantyu is offline Find More Posts by sarkantyu
Old Jan 29, 2013, 12:13 PM
Grejen is offline
IAMCANADIAN
Grejen's Avatar
Joined Jul 2002
It's looking great. Love all the little details your adding like the cable exits. Noticed in your picture that the Smithsonian hung SS1 right next to the NYP. How very appropriate. The two have much in common.
Old Jan 29, 2013, 01:42 PM
S/E Michigan
Joined Jun 2010
Hey, I bet you fly over at Bald Mountain..
Did you ever finish the Bellanca, Miss Columbia build?
Old Jan 29, 2013, 02:22 PM
S/E Michigan
Joined Jun 2010
An oval piece of solartex cut to shape, and sliced down the middle, makes a good looking reinforcement.
Question Spirit of St Louis Hossinarizona Scale Kit/Scratch Built 5 Sep 21, 2012 08:03 PM
For Sale Spirit of St. Louis wildskies Aircraft - Electric - Airplanes (FS/W) 0 Aug 26, 2012 02:31 PM
Discussion Spirit of St. Louis / Cub STRINGFLY Scale Kit/Scratch Built 1 Aug 04, 2012 02:08 PM
Sold Spirit of St.Louis by Graupner jricchio Aircraft - Electric - Airplanes (FS/W) 2 Jun 18, 2012 08:28 PM
Wanted Flyline Spirit of St. Louis apage Aircraft - Fuel - Airplanes (FS/W) 1 Jun 05, 2012 09:31 AM
