This thread is privately moderated by cyberhoops, who may elect to delete unwanted replies.
Old Oct 16, 2012, 06:41 PM
cyberhoops is offline
Find More Posts by cyberhoops
cyberhoops's Avatar
Seattle
Joined Feb 2006
Nerf Chronograph
I was playing around with a couple Nerf guns, and reading some of the posts about people modifying Nerf guns for better performance. One thing led to another and I could not resist the idea of making a chronograph, or velocity sensor, for Nerf darts.
I had all of the hardware I needed already lying around - mainly an Arduino controller, and an LCD display. Add to that a pair of infrared LED light sources and detectors from Radio Shack and I was good to go.
The idea was to place the two sensors in a PVC tube spaced 4 inches apart. Then time how long it takes for a dart to trip the two sensors and compute speed. Since the Arduino can do timing in microseconds it is more than capable of doing accurate speed for a dart moving around 100fps.
The Arduino 5v output is connected to the transmitter led through a 270 ohm resistor and to ground. Two analog input pins are connected to the receivers and then a 270 ohm resistor to ground. Very simple circuitry. The LED's are mounted 4 inches apart in a 1 3/8 inch PVC tube. About the only thing I did wrong was not mounting the LED's to be flush with the inside of the tube. My mounting has them sticking into the tube about 1/8", which means the dart can hit them. That means I have to be slightly more careful in settup up the shot to go down the middle of the tube.
Once the speed is calculated, the display is a Sparkfun LCD-09395 serial LCD with 2 lines of 16 characters. That just takes 5v power, ground and a single digital output pin from the Arduino which makes it very simple to use. After the picture was taken I also added a second line to the display for the average velocity of the previous 5 shots.
It did not take long to get it all working - 30 minutes to get the first breadboard version working and a couple days to put it all together.
It anyone is interested in the code (Arduino sketch), or the circut diagram, let me know and I can make that available.
cyberhoops is offline Find More Posts by cyberhoops
Old Oct 28, 2012, 05:06 PM
Pablar is offline
Find More Posts by Pablar
Joined Oct 2012
Source code
Hi.
I'm very interested on making a Arduino based chronograph.
So, could you give me the source code for this?
Send it to: mil_ndollars2008@hotmail.com
I'll be very grateful if you help me.
Pablar is offline Find More Posts by Pablar
For Sale Seiko Men's Alarm Chronograph Watch #SNA061 Final Price Drop $100 shipped!!! russainred95 Non R/C Items (FS/W) 4 Aug 14, 2015 05:43 AM
Sold Nerf guns platnuim1 Non R/C Items (FS/W) 2 Jul 02, 2012 07:10 AM
Discussion Nerf Stampede Motor Replacement (Non-RC, help a noob!) stoph Chit Chat 8 Mar 13, 2012 09:58 PM
For Sale Swiss Legend Commander Chronograph Watch jafo216 Non R/C Items (FS/W) 2 Jul 07, 2009 04:49 PM
