Old Oct 23, 2012, 08:27 AM
Lucasberg is offline
Find More Posts by Lucasberg
Certified Crash Artist
United States, CA, Garden Grove
Joined Feb 2011
Well I got home powered it up and the lcd flickered and shut off. It would still take pictures or videos but the LCD was just dead.
I took it back to a different Best Buy they only had one and it was sold. I lucked out and got a store 20 miles away that still had one to hold one for me. I went down there and they exchanged it.
I did notice after updating the firmware and left it plugged in via usb that it was really hot. I didn't get a chance to use it yesterday but I should today.
Lucasberg is offline Find More Posts by Lucasberg
Old Oct 23, 2012, 08:55 AM
BenLimeClouds is offline
Find More Posts by BenLimeClouds
I Like Clouds Made Of Limes?
BenLimeClouds's Avatar
United Kingdom
Joined Jun 2012
Whats the overall thought of the GP3 Then...?
I found the GP2 Okish, My Pc hated it, the LCD add on i brought (well 3 attempts) never worked properly either and someone stole it...
GoPro support IMO was nothing pro atall, so it has left me a bitter taste in my mouth to rush out and buy an GP3
I get the feeling this is like the Iphone 4 & 4s...Some difference, but same old problems?
BenLimeClouds is offline Find More Posts by BenLimeClouds
Old Oct 23, 2012, 10:41 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by lensman82 View Post
It doesn't say anything about too cold. Are you sure your hero 3 is not overheating? (maybe because of some firmware bug that keeps cpu at 100%)
Positive. I actually re-tested it by cooling the camera in the fridge.
When its cold, it powers up, then within 10 seconds it shows the temp warning
and shuts itself down. It has no opportunity to overheat.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 23, 2012, 10:57 AM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
?How does the live view on your smartphone via wifi work ? Doubt it will be good for fpv but what about setting up the shot? Any interference with radio 2.4?
jcmonty is offline Find More Posts by jcmonty
Old Oct 23, 2012, 11:09 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I don't have a compatible phone.
barok is online now
Find More Posts by barok
barok's Avatar
Joined Apr 2006
has some1 use this wifi iphone (any video or links)..
i seen the contour wifi, it was jittery, worth only for framing the shots and adjusting the menu.. .
wonder if the same or better with this new gp3..
ooopps..... some1 has thought of the same..
barok is online now Find More Posts by barok
Old Oct 23, 2012, 11:23 AM
MK3 is offline
MK3
Find More Posts by MK3
MK3
Aerial Loitering
MK3's Avatar
Joined Sep 2011
GoPro3 doesn't have support for the App yet. On their site it says coming "Winter 2012".
Ok so being a camera guy and all I'll give you all my recommendation.
At home, I have a Canon 60D, Canon 350D, a huge array of thousand dollar lens, 4 different camcorders, 2 of them being completely infra-red, a Gopro 1, a GoPro2. So I know cameras well and I'm what some people call a "pixel junkie".
This is not a "4s" vs iphone 4.. the GP3 is leaps and bounds better than it's predecessors. The image quality is drastically better when you see the raw footage at full resolution on your computer. There is virtually NO noise anymore, particularly during periods like sunset.. or heavy clouds. (I had this issue a lot, and if you think you didn't have a noise problem, check your videos again). The white balance is drastically better and the light balance is a huge upgrade.
The 2.7k which is now my favorite shooting mode... is absolutely freaking stunning.
If you hear about any stock at your local stores, run.. don't walk to get one. And if you get a protection plan from best buy, you don't need to worry about putting a $400 camera on your plane. If you destroy it simply use your plan and get a new one.
MK3 is offline Find More Posts by MK3
Old Oct 23, 2012, 11:31 AM
United Kingdom
Joined Jun 2012
MK3...
Thanks for the quick over view!
As some punk stole my GOPro from my backpack, i will butter up the Wife (Birthday Soon)
Old Oct 23, 2012, 11:48 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
So far, I really like what I see in image quality and low-noise sensor, but
the cold thing is really annoying (hope it's firmware fixable) and I've
had a bunch of lockups in almost every possible mode, each time
requiring the battery be removed to reset. This morning I noticed
the red charging light was still on after charging all night (should have
turned off after a couple hours), and again camera was unresponsive
and battery had to be removed to reset.
GoPro's support form doesn't even list the Hero3 yet, although I've already
sent em something about the cold issue.
ian
Old Oct 23, 2012, 11:53 AM
dehicka is offline
Find More Posts by dehicka
Russia
Joined Nov 2007
Anyone else have the same "cold bug" as Daemon? I'm about to pick one up from BestBuy, but it will be hard task to exchange it from Russia.
dehicka is offline Find More Posts by dehicka
Old Oct 23, 2012, 12:15 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
For anyone willing to test for the cold issue, just put your Hero3 in the freezer for 10 min (no longer).
I did it without the battery (battery stayed warm).
Then re-insert battery, power it up with the card in and wait a few seconds. Mine shows
the temp warning within 10 seconds, and shuts itself off.
ian
Old Oct 23, 2012, 12:40 PM
MK3 is offline
MK3
MK3
Aerial Loitering
MK3's Avatar
Joined Sep 2011
There might be an issue with your GP3. I put mine in the fridge for an hour, then turned it on, took video, it worked perfectly fine. The temp was 39F.
Did you upgrade the firmware? Something is very strange with your Gopro, usually the colder the camera, the better.
Old Oct 23, 2012, 12:44 PM
McCleary.11 is online now
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
Tim, at ReadyMadeRC, did some testing this morning on a GoPro3 Silver Edition while I observed. The first attempt was to get video out through the USB by hacking the stock cable. Ground tested just fine, but it currently won't send video signal. More testing is needed and will be done for the USB video out.
He did find that the micro control board, designed for the GP2, will work with the GP3:
http://www.readymaderc.com/store/ind...oducts_id=1091
The biggest problem is latency. We did a side by side test of the GP2 and 3 each equipped with the same control board. The GP3 had roughly double the latency and was very noticeable in direct comparison. The GP3 also had some "stuttering" as we moved the camera around the room as if the frame rate was dropping. Another downside is that the image on screen was darker than the tests with the GP2. These tests were set at 1080 and 30fps.
It is possible that the USB video out may work better once we have it figured out, but the initial results are disappointing. More testing with video out is needed on the GP3. Hopefully some of you can chime on here as well.
McCleary.11 is online now Find More Posts by McCleary.11
Site Sponsor
Old Oct 23, 2012, 12:50 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
While 39F is certainly lower than the 45 degrees it quit on me while testing outside,
when I did the freezer test for 10 min it took it down to about 25F.
I haven't. Looks like there is something on gopro site, so will try that.
ian
Old Oct 23, 2012, 01:10 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Had been unaware that there was a firmware update, but sure enough.
Don't know what the version was before, or is now, but I've gained some
video modes outside of ProTune mode that weren't there before.
Camera is in the freezer for a few minutes right now, so we'll see what happens.
ian
Sold *SOLD* NIB GoPro HD Hero 2 Motorsports Edition plus NIB GoPro Wifi Combo Kit. jbj620 FPV Equipment (FS/W) 2 Jun 11, 2012 11:54 AM
Discussion FPV using GOPRO HD Hero 2 + bacpac WIFI Link69 Multirotor Talk 4 Feb 26, 2012 07:24 PM
Build Log HD FunJet v2 (mini) build log with GoPro HERO HD jbpilot FPV Talk 14 Oct 31, 2010 09:36 AM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
