Old Feb 10, 2013, 06:50 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Re-tested the same sandisk class10 32GB card on another gopro black, 2.7K with protune. -2C outside, no way it could overheat.
First clip (3 mins) ok, stopped, started and it stopped recording after ~1minute. So, easy to reproduce with another camera too...
ABLomas is offline Find More Posts by ABLomas
Old Feb 10, 2013, 07:40 AM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
Originally Posted by topgearuk View Post
Mudlark, as you say crazy as its not been out long.. Did you buy yours over in the US? The reason I ask that as I've had one or two probs with mine, not used it enough to investigate what's causing it, but have had serval lock ups and one time a real hot camera and seemed to flatten the battery in no time, so just keeping an eye on what everyone else is doing..
I brought it brand new off a member on here as he had 2 of them, but he lives in the US.. If I have a problem I'm sure I can get the receipt from him.. But not sure where I would stand..
Sounds like your having the same over heating problem as me. Battery shows up as flat but once it's cooled down it's only half empty.
Yes got mine out in the States whilst visiting my fiance.
Turns out that she has the receipt and hopefully she'll fine it today.
I assume that if you can get the receipt of the seller, being in the UK shouldn't be a problem.
I'd try and get it first and then get in touch with GoPro. I had a prompt reply as if they are expecting to get a few of these.
Good luck
mudlark is offline Find More Posts by mudlark
Old Feb 10, 2013, 07:42 AM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
I tried mine in sub zero and it still overheathed
Old Feb 10, 2013, 08:17 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
Joined Dec 2003
Good luck
Cheers, wondered if you had.. That sounds like what happened to mine, it was after I was playing with the settings, then had wifi on did a test record and was flat in no time and pretty hot to the touch.
Also seems to freeze a lot switching on/off wifi and different devices.
topgearuk is offline Find More Posts by topgearuk
Old Feb 10, 2013, 05:49 PM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Found my receipt
Just waiting for GoPro to reply.
Then just need to figure out how long it'll take to post back to the US and then back to the UK.
I recon Three weeks.
Old Feb 11, 2013, 01:24 AM
dziedrius is offline
Find More Posts by dziedrius
Joined Jul 2008
Anyone had overheating problems with silver edition, or is it just black one?
dziedrius is offline Find More Posts by dziedrius
Old Feb 11, 2013, 01:43 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I haven't heard of any big issues with White (HD equiv) or Silver (Hero2 equiv), but then
they don't have all these high bitrate video modes that the Black does.
Did some testing in 2.7k mode tonight with my Sandisk and PNY cards.
Got it to fail many many times with both, but seems to happen more with the Sandisk cards.
It fails most often after only 3-4 seconds, but sometimes after a minute or two. Several
lockups after powering down after a failed record attempt. Got hot once.
Had to remove the battery about a half dozen times. This is my 2nd H3 Black. :|
Did some benchmark testing of the cards, and the PNY card is faster (11-12.5MB/s write speed)
versus the Sandisk (8.9-9.9MB/s write). That was a surprise.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 11, 2013, 01:53 AM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
i got a silver in december, only because the blacks weren't available here yet, and have been pretty happy with it. absolutely no problems, except for the crappy 3rd rate micro sd cards i bought
CrashAffinity is offline Find More Posts by CrashAffinity
Old Feb 11, 2013, 04:24 AM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
My batt on the black ed is very poor i canot charge it and leave bat in and exspect it to hold it charge even if wifi is switch off
Andre6553 is offline Find More Posts by Andre6553
Old Feb 11, 2013, 11:35 AM
quad007 is online now
Find More Posts by quad007
DOLLA DOLLA BILL YALL
quad007's Avatar
United States, FL, Orlando
Joined Oct 2012
i use samsung SD cards and have not had a problem with the black except copying via USB. 2.7k, 1080, everything works
quad007 is online now Find More Posts by quad007
Old Feb 13, 2013, 01:56 PM
yosemitez is offline
Find More Posts by yosemitez
yosemitez's Avatar
United States, CA
Joined Nov 2010
Got my GPH3 replacement today from GoPro after getting a RMA on 1/31/13. Not to bad just 2 weeks. Mine had similar overheating, stop recording issues and sandisk lockups.
yosemitez is offline Find More Posts by yosemitez
Old Feb 14, 2013, 07:45 AM
sickwitit is offline
Find More Posts by sickwitit
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
Anyone use this type of cable to power your Hero3 with the 5V from your Rx?
http://www.rc4y.com/av-output-cable-...ro3-p-533.html
sickwitit is offline Find More Posts by sickwitit
Old Feb 15, 2013, 12:53 PM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
Well I finally got my RMA number from GoPro.
And luckily I only have to send it to Holland.
Got to be quicker than all the way to the States and back.
Old Feb 15, 2013, 04:03 PM
dartmouth01 is offline
Find More Posts by dartmouth01
Joined Oct 2006
I asked this question before but no answer. So I tried anyway and it works fine. It shows on the gopro as charging, but the gopro won't run without the battery, so I think the battery is still being used, just not at as fast a rate. I haven't tested overall bat life yet, maybe ill do a test to see.
dartmouth01 is offline Find More Posts by dartmouth01
Old Feb 15, 2013, 04:46 PM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
I had a weird thing happen yesterday with my GoPro3 Black.
I started recording and went for a flight and came back and only 5 seconds recorded.
The camera would not record again and none of the buttons worked and I had to take the battery out.
Did it a bunch more times and still would still only record a few seconds and then the camera would lock up.
I tried many times with no luck.
I hooked the Scandisk class 10 32gb card to the computer and saw all the files and they were only a few seconds.
I saw a TRASHES file and went in there and that folder had almost 20gb of videos and files.
I though I deleted everything after I uploaded to the computer but somehow things ended up in the TRASHES file.
I emptied that file and now the camera is working again.
So I don't get what's going on.
jasper7821 is offline Find More Posts by jasper7821
Sold *SOLD* NIB GoPro HD Hero 2 Motorsports Edition plus NIB GoPro Wifi Combo Kit. jbj620 FPV Equipment (FS/W) 2 Jun 11, 2012 11:54 AM
Discussion FPV using GOPRO HD Hero 2 + bacpac WIFI Link69 Multirotor Talk 4 Feb 26, 2012 07:24 PM
Build Log HD FunJet v2 (mini) build log with GoPro HERO HD jbpilot FPV Talk 14 Oct 31, 2010 09:36 AM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
