Old Jan 19, 2013, 10:51 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Originally Posted by AeroVideoUS View Post
Sorry, just trying to help... Sounded just like what happened to me and I was able to recover the video, but maybe not the same.
Ha, that happen again!
Sorry, this really was framed bicycle icon... But selecting this option does not help :/
So, from beginning - i got to field, flew few times (~20 mins of video), ~-16C outside. Then short pause (camera was in a car, so temperature was around 0C), took cam again, mounted on copter. Flew a bit (smooth flight, no acro, no sudden movements, etc), landed. Turned off camera. Turned on again after few minutes and this bicycle icon appeared. This time i pressed "OK" and turned on recording...
Earlier videos are OK
Later videos are OK.
One in middle - completely corrupted (400+ MB file, with correct headers, but no data in h264 stream).
That shouldn't be due to cold environment - i was flying at lower temps without problems. I was using different mode (first time it was 1080p@60FPS Wide, this time it was 1080p@30FPS Medium), only copter is the same (but last flight was completely smooth, and camera produces good videos even on shaky flying wing, etc).
I do not trust my gopro anymore... Going to buy old good GP2 :/
ABLomas is offline Find More Posts by ABLomas
Old Jan 19, 2013, 11:18 AM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Maybe it's a bad micro SD card? I think that icon appears as a result of the connection to the SD card being interrupted.
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Jan 19, 2013, 11:27 AM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Using sandisk Class 10 32GB card (recommended by GoPro). Re-formatted it (after previous incident) using gopro, tests using h2testw shows no problems (and write speed is allways > 10MB/s), so doubt that card may be issue...
Do not have other big Class 10 card, and smaller ones cant't fit my videos ;-)
Old Jan 19, 2013, 11:36 AM
sickwitit is offline
Find More Posts by sickwitit
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
I assume you contacted GoPro about this. What did they say? They should have no problem replacing it.
sickwitit is offline Find More Posts by sickwitit
Old Jan 19, 2013, 11:51 AM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Not yet, but will try.
Too bad, i purchased gopro not locally (this isn't that "no-serial" camera, i got full pack), so won't be easy to arrange replacement.
Will try to ask support, maybe they will help. Strange, that nobody else expierenced such issue, maybe i'm alone flying in cold? =)
Old Jan 19, 2013, 04:29 PM
aka Helidaho
Joined Jun 2010
I fly in the cold and that has only happened to me once. I too have a sandisk 32GB class 10 card.
Old Jan 28, 2013, 10:07 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Sent my H3 Black back to GoPro about 2 1/2 weeks ago, got the replacement today.
Only had to pull the battery 3-4 times so far after locking up while working
through the menus and once while trying to take a still (to get the firmware version).. *sigh*
Have yet to see if it locks up on the charger like the old one did.
ian
Daemon is offline Find More Posts by Daemon
Old Jan 29, 2013, 08:25 AM
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
ian
Wow, that's crazy. Mine has never locked up on me yet. But I'm sure you use yours a lot more than I do. Or maybe it's how quickly we surf thru the menus? Or maybe your replacement camera is also defective?
Are a lot of people still having their cameras lock up while going thru the menus, or taking pictures/video?
Old Jan 29, 2013, 08:54 AM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
New issue for me, i made a simple usb cable to charge the camera from 5v, it works perfectly on my GoPro 1 but on the 3, the camera icon appears and the camera is frozen,
any idea ?
bakchos is offline Find More Posts by bakchos
Old Jan 29, 2013, 11:38 AM
ABLomas is offline
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Still had no time to contact gopro support, but was flying a lot ;-)
I tested - if i let camera to cool before flight (turn it on when all components are already at approx 0C) - video won't work, it will stop after few seconds (photos OK, you can navigate trough menu and turn video ON again, but it will turn off soon).
If you keep it warm (for example, in pocket), attach, turn it on and fly - it will work OK without glitches. Did ~40GB of videos during last days, issue could be reproduced 100% (ok, let's keep it down - 95% :P )
Probably internal components heating is enough to keep camera warm, and it won't work at low temperatures (even at -3C)... I did some "heat-insulation" box on gimbal, seems it could help a bit.
Old Jan 29, 2013, 11:45 AM
yosemitez is offline
Find More Posts by yosemitez
yosemitez's Avatar
United States, CA
Joined Nov 2010
still trying to get gopro to replace my hero3. mine would also lock up all the time in the video icon but stills would work for a bit, and my camera is at room temp. now it is doa, no lights nothing
gopro keeps ending this which i have done hundreds of times and always with class 10 cards
"- Remove SD card and Battery.
- Press and Hold Shutter Button (it will need to be kept pressed
throughout the whole process)
- Insert the Battery
- Click the Power/Mode Button.
The camera should power up. After it powers up, make sure you insert a
recommended micro-SD card and update the camera's firmware through
gopro.com/support."
i got mine to come back to life 2 other times by putting in a different card.
yosemitez is offline Find More Posts by yosemitez
Old Jan 29, 2013, 12:14 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The problem is, I'm usually doing 2-3 things in there like, turn Protune on or off
and change the video res and framerate (usually forced to do both together) and
every 3rd time or so I do it, it locks up somewhere in the menus. It also, often
just exits whatever sub menu I'm in and returns me to normal shoot mode
on any random button press almost anywhere in the menus. Locking up while
taking a still was a first for me. If I had it in the full housing or was trying to operate it
in a wet environment it would be intolerable.
On a positive note, this one doesn't lock up with the light stuck on at end of charge cycle.
ian
Old Jan 29, 2013, 12:17 PM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
mine always locks if i use motorolla charger but when i use the usb cable with the charger from my samsung phone, no problem.
i dont know what is the difference between different usb charger.
Old Jan 30, 2013, 05:24 AM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Well what a surprise!, no wonder its good!, should be interesting when Sony brings out there Action Cam 2!
http://www.ifixit.com/Teardown/GoPro...ardown/12457/1
http://www.chipworks.com/blog/recent...sports-camera/
*Relinked!
koolkiwikat is offline Find More Posts by koolkiwikat
Old Jan 30, 2013, 05:36 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Second link is broken, so is the first, but still manages to find the teardown.
Edit: Ah, here's the 2nd link from within the ifixit teardown: http://www.chipworks.com/blog/recent...sports-camera/
And the first if the broken one doesn't work for you: http://www.ifixit.com/Teardown/GoPro...ardown/12457/1
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Sold *SOLD* NIB GoPro HD Hero 2 Motorsports Edition plus NIB GoPro Wifi Combo Kit. jbj620 FPV Equipment (FS/W) 2 Jun 11, 2012 11:54 AM
Discussion FPV using GOPRO HD Hero 2 + bacpac WIFI Link69 Multirotor Talk 4 Feb 26, 2012 07:24 PM
Build Log HD FunJet v2 (mini) build log with GoPro HERO HD jbpilot FPV Talk 14 Oct 31, 2010 09:36 AM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
