Decent comparison video, you can download the original file from Vimeo, I would recommend you do that instead of watching it on Vimeo if possible.
And a new overview of camera
It's pouring rain outside here in CA, so no quad test, but here's a low light test in which you can see a clear difference. Both captured at 1080p 30fps. Make sure to watch full screen in 1080p
GoPro 2
GoPro 3 Black
![]() Looks like I'll be $480 in the hole today ($399 + $80 for the 2-year "accidental" warranty that I can almost guarantee I'll be cashing in).
It will not. There's just one output, and it's mini-hdmi. I'm sure there's a way to make a custom mini-hmdi to rca cable, it shouldn't be that hard. GoPro also sells the cable
Btw.. A cool feature I came across is the GoPro3's wifi feature. Even when the camera is totally OFF, if the wifi button is on... you can remotely turn on the camera, change settings or shoot. Looks like live wifi output and control to the GoPro App is coming "winter 2012" |
Best Buy doesn't "have them in stock" exactly. It looks like each store was sent one Black
Edition along with their full stock of the other models. No the 3.5mm A/V plug and cable from RMRC won't work in Hero3. That 3.5mm jack on the Hero HD and Hero2 was fragile anyway. Known to fail if used often. Running A/V out through the USB port should be more reliable as USB jacks are rated for a lot more insert/remove cycles. I'm sure RMRC will eventually build up an A/V cable for the Hero3, but could probably build one yourself once we know the pinout. BTW, I've found VLC pretty much incapable of playing raw Hero3 1080p@60fps mp4s.. It's not hardware accelerated, so it just can't keep up. Windows Media Player handles it, and Sony Vegas Pro 10 did ok in Preview mode. ian |
Latest blog entry: My 2012 FPV year in Review
says it's using the USB port. Quote:
powering the wifi radio (probably every second or so) listening for the power-on signal. Would love to know what the standby time is with this enabled. It is really handy having a full display on the wifi remote so you can look at camera battery status, record time remaining on the card.. etc. ian |
Timelapse test I took a few hours ago. It was warmer colors than previous models, much better white balance and virtually no noise during daylight. Must see in 1080p
For whatever it's worth, the way the stock case is designed, it's not too hard to
pull it apart, and turn the lens protection part into a LayerLens style standalone protector. See attached. The Wifi remote is neat idea, but really flaky. Lost contact with the camera 2-3 times (only a few feet away) and then they seemed to get into some weird mode where camera would turn on and off with the remote, but remote wouldn't display anything from the camera, and couldn't start/stop recording.. etc.. Eventually had to pull the battery from the camera to reset . Tried again, no luck. Turned off wifi function and made a flight. Stopped recording, and then when I went to try to start again, display was blank except for the battery level indicator and couldn't do anything at all. Would power off, but always power back on with blank screen and battery level indicator. Had to pull the battery again. This firmware clearly needs some work. 1080p is stunning of course. 1440p (1920x1440) is pretty worthless. It's just a 4:3 version of 1920x1080. 720p looks better than ever before. 720@120fps is cool, but still don't care for it at full wide angle. Wish other FoV had been made available at 720p. Everyone's eventually going to lose that tiny little pastic door over the USB/HDMI ports. Battery door is a bit fiddly and wouldn't be hard to lose too. Sneeze and those micro SD cards just disappear. I'll have some FPV vid up later. ian |
| Thread Tools | |
| Sold *SOLD* NIB GoPro HD Hero 2 Motorsports Edition plus NIB GoPro Wifi Combo Kit. | jbj620 | FPV/RPV - Equipment and Vehicles (FS/W) | 2 | Jun 11, 2012 11:54 AM |
| Discussion FPV using GOPRO HD Hero 2 + bacpac WIFI | Link69 | Multirotor Talk | 4 | Feb 26, 2012 07:24 PM |
| Build Log HD FunJet v2 (mini) build log with GoPro HERO HD | jbpilot | Video Piloting (FPV/RPV) | 14 | Oct 31, 2010 09:36 AM |
| Cool GoPro HD Hero Wide - 6.3 oz HD video camera | nemo_uk | Aerial Photography | 5 | Sep 27, 2009 09:40 AM |
