Old Dec 01, 2012, 10:24 AM
AlanGold is offline
Find More Posts by AlanGold
AlanGold's Avatar
Joined Oct 2012
Originally Posted by AtGame7 View Post
After reading the entire thread, I have to say I am an utter noob when it comes to FPV and GoPro. Thank you all for the education. If you don't mind a noob question, what it "jello"?
Jello is when parts of the movie begin to look liquified to some degree. As if it is oozing somewhat. The reason for this is these types of cameras record at 30 or 60 frames per second but do not capture a complete "frame" or photo at a time. Instead thy have what is called a "rolling electronic shutter" that scans each frame line by line. So when there is vibration or quick movement, the scanning is uneven because the image has changed positions on the sensor during the actual scan of a single frame.
AlanGold is offline Find More Posts by AlanGold
Old Dec 01, 2012, 11:58 AM
bcollydas is offline
Find More Posts by bcollydas
bcollydas's Avatar
Canada, QC, Laval
Joined Apr 2008
Thay are crystals that you poor hot water and voila "jello"
bcollydas is offline Find More Posts by bcollydas
Old Dec 01, 2012, 12:59 PM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
Yes and more explanation on http://en.wikipedia.org/wiki/Rolling_shutter
eyesonsky is offline Find More Posts by eyesonsky
Old Dec 01, 2012, 03:48 PM
S9coldfire is offline
Find More Posts by S9coldfire
S9coldfire's Avatar
Littleton, CO
Joined Nov 2009
Originally Posted by S9coldfire View Post
I just got my first GoPro, a hero 3 black, and it's great! But when I charge it with my computer I've left it plugged in for about 2-3 hours (a bit longer than the charge light shows but not too excessive), but when I unplug it the battery indicator only shows two bars. Is this normal or is there anything I can do differently?
And yesterday I took video at 1080p, 30fps and it shut off after a little over an hour of recording. I heard that the battery is small, but is this typical?
One other question. I plugged it back in and got it to charge all of the way. I have a 32 GB card in there and I took an hour and a half worth of video at 1080 48 fps. But when I downloaded it to my computer, I had two 3.66 GB files at ~17 min each and a 26 MB file and that was it. Why did it stop taking video? (I never told it to stop). And why does it break it up into separate files? Is that because it's a FAT 32 file system?
S9coldfire is offline Find More Posts by S9coldfire
Old Dec 01, 2012, 05:16 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
Good question.
Sorry can't answer it but I had the issue. 2 hour record but only I thing two fifteen minute clips and a bit.
Would also like to know why
mudlark is offline Find More Posts by mudlark
Old Dec 01, 2012, 06:46 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
yup, you've hit the fat32 file limit, so it breaks it up into chunks.
Your only choice to prevent this is to record at lower rates / resolutions, that'll keep the clip lengths longer. Also, check the 'loop recording' setting on the camera to force it to restart recording once the file limit has been reached.
CrashAffinity is offline Find More Posts by CrashAffinity
Old Dec 01, 2012, 06:49 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Hitting the FAT32 limit isn't either of their problems.
It should just roll over to the next file and keep going until the card is full. They're saying that
it simply stopped recording early. I haven't done any recordings long enough to see that yet.
ian
Daemon is online now Find More Posts by Daemon
Old Dec 01, 2012, 06:52 PM
Canada, AB, Calgary
Joined Nov 2012
Originally Posted by Daemon View Post
They're saying that
yup, that's what the loop recording setting is for.
Old Dec 01, 2012, 07:12 PM
mudlark is offline
Happy Days
mudlark's Avatar
Joined Mar 2001
I would assume the loop recording is a bit like a security HDD. it'll keep recording and once full record over the starting recording
Old Dec 01, 2012, 07:29 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The loop recording should go back and overwrite earlier files after you've filled up the card.
They aren't filling up the card.
ian
Canada, AB, Calgary
Joined Nov 2012
Nevermind, i am totally wrong. the loop recording is to overwrite the oldest video files when your memory card is full (and it doesn't work in pro tune mode). The camera is supposed to write videos in multiple segments, but a 3.66GB file is roughly reaching the fat32 file limit, so if it's not starting a new file right after this is something to look further into.
I haven't reached that file limit yet so can't say, but i will try this in a moment to see for myself.
Old Dec 01, 2012, 09:15 PM
Canada, AB, Calgary
Joined Nov 2012
Ok so i set my gopro 3 silver to record for 2 hours at 1080p @ 30fps. It created a bunch of 1.99GB files at about 17 mins each until i stopped it. I ended up getting 5 files at 1.99gb and one file at 735MB, all separately viewable, each one starting after the other one ended.
Old Dec 01, 2012, 09:57 PM
jolyboy is offline
Find More Posts by jolyboy
Australia, NSW, Sydney
Joined Sep 2012
Similar story here, at 720p 30- pro tune on, split into 14:59 long clips @3.8Gb each. Personally I don't give a damn because 15 min is a pretty long time for one clip.
jolyboy is offline Find More Posts by jolyboy
Old Dec 01, 2012, 11:09 PM
S9coldfire's Avatar
Littleton, CO
Joined Nov 2009
Yeah I definitely wasn't filling the card up. I'll try recording again tomorrow evening and just let it run for an hour or two to see what happens. I only got about 34 minutes of video split between two 3.66 GB files. I'd love to hear what happens to other people at various settings!
Old Dec 02, 2012, 02:34 AM
Kilrah is offline
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
Are you sure your gopro didn't jsut crash in the middle of the recording without you noticing, as some have experienced?
Kilrah is offline Find More Posts by Kilrah
Sold *SOLD* NIB GoPro HD Hero 2 Motorsports Edition plus NIB GoPro Wifi Combo Kit. jbj620 FPV Equipment (FS/W) 2 Jun 11, 2012 11:54 AM
Discussion FPV using GOPRO HD Hero 2 + bacpac WIFI Link69 Multirotor Talk 4 Feb 26, 2012 07:24 PM
Build Log HD FunJet v2 (mini) build log with GoPro HERO HD jbpilot FPV Talk 14 Oct 31, 2010 09:36 AM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
