Old Nov 28, 2012, 01:49 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by Ian Davidson View Post
Love that audio!
You should try and capture this phenomenon.
https://www.youtube.com/watch?v=eCMmmEEyOO0
I did capture that phenomenon.
Daemon is offline Find More Posts by Daemon
Old Nov 28, 2012, 02:38 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
Errr, oh yeh!
Ian Davidson is offline Find More Posts by Ian Davidson
Old Nov 28, 2012, 12:19 PM
pgregg is offline
Find More Posts by pgregg
9x Transmitters Freakin' Rock
pgregg's Avatar
Joined Dec 2011
Opinions on optimal Hero3 config for high quality flight videos?
Let's put the "should you pilot FPV through the Hero3" discussion aside for a moment and talk about how to get the best flight video quality on your Hero3. I'd really like your opinions.
On the Hero3:
- What is the best capture resolution from a quality AND battery performance perspective for fixed-wing flight? 1080p/30fps, 720p/60fps? Is there a benefit to going with 24/48fps rather than 30/60fps? What are the benefits of higher frame rates for flight videos, other than slow motion?
- How do environmental conditions effect your Hero3 configuration decisions?
- Is Protune the way to go? If so, what do people use for the external color correction? Cineform? Other software products? What is your video post-processing process? Is there another thread that discusses how to get the best protune results?
- What are other important considerations to maximize your flight video success rate?
- Are UV filters useful?
- Anything else?
I look forward to your feedback.
Preston
pgregg is offline Find More Posts by pgregg
Old Nov 28, 2012, 12:32 PM
yosemitez is offline
Find More Posts by yosemitez
yosemitez's Avatar
United States, CA
Joined Nov 2010
i use the 60fps to reduce the jello and from what i have read protune creates larger files. i tried cineform and you create large mov or avi files to work with in your editor. you can also then tweak those large files in cineform and convert them to mp4's but you have no real control over bitrate,etc output
i am currently using sony vegas pro 11 and it works fine with the raw gopro files and will even work with the 2.7 and 4k. i tried the cineform route of converting to avi and then importing that into sony and then rendering for youtube.
here is some footage from 2 days ago shooting at 1080 60 fps. imported raw gopro and rendered for youtube in sony vegas, no cineform. i cant see any real difference between cineform to vegas or just raw gopro to vegas
Flights 24, 25 (0 min 51 sec)
yosemitez is offline Find More Posts by yosemitez
Old Nov 28, 2012, 12:36 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
1080p/30 Protune off is probably the best for keeping composite video latency down and
ensuring reasonably reliable operation. Any other frame rate has to be converted
in camera to 30fps (29.97) for NTSC composite output.
Same but with Protune on, if you want to fly in low light conditions, but bitrate is very high
so higher potential latency and must have large, fast uSD card.
Using higher frame rates at night, will make the video darker as exposure time is reduced.
Most photographers treat UV filters as nothing more than lens protection, which Hero already has.
A polarizing filter could be useful in sunny or snowy conditions.
Color correction is not necessary with Protune unless you set the white balance manually
to a specific temperature, or turn it off. You will need to adjust Levels (contrast/brightness)
if you use Protune regularly in well lit conditions, otherwise you'll end up with a somewhat washed out look.
ian
Old Nov 28, 2012, 01:03 PM
Neo360 is offline
Find More Posts by Neo360
Joined Jul 2009
MultiWii with GoPro Hero 3 (3 min 28 sec)
Neo360 is offline Find More Posts by Neo360
Old Nov 29, 2012, 02:21 AM
PinDuke is offline
Find More Posts by PinDuke
I can fly this plane
Kingdom of Sweden, Gävleborg County, Sandviken
Joined Jan 2012
GoPro 3 user might find this helpfull.
http://rcexplorer.se/diy/2012/11/diy...deo-out-cable/
PinDuke is offline Find More Posts by PinDuke
Old Nov 29, 2012, 08:11 AM
lougedo is offline
Find More Posts by lougedo
lougedo's Avatar
Spain, GA, Corunna
Joined Jan 2011
Yes, David is the boss
lougedo is offline Find More Posts by lougedo
Old Nov 29, 2012, 10:30 AM
S9coldfire is offline
Find More Posts by S9coldfire
S9coldfire's Avatar
Littleton, CO
Joined Nov 2009
I just got my first GoPro, a hero 3 black, and it's great! But when I charge it with my computer I've left it plugged in for about 2-3 hours (a bit longer than the charge light shows but not too excessive), but when I unplug it the battery indicator only shows two bars. Is this normal or is there anything I can do differently?
And yesterday I took video at 1080p, 30fps and it shut off after a little over an hour of recording. I heard that the battery is small, but is this typical?
S9coldfire is offline Find More Posts by S9coldfire
Old Nov 29, 2012, 11:52 AM
JForbes is offline
Find More Posts by JForbes
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
Hey all... I have read through MOST of this thread, and still haven't found the exact answer i was looking for... so I thought I'd post and see what you all have to say. If I should be looking elsewhere, I understand, and sorry for the bother....
I do not have a GoPro camera yet, but would ilke one to fild some of my four wheeler riding and flying my planes/heli. Being as I have never owned one, I don't have much to go on for comparison, other than the video our $200 Canon camera and my smartphone capture. I see there are now three levels with the GoPro 3 version. Will the White edition make me happy, or do I need the Silver or Black to be able to be satisfied with the video quality and performance? Thanks for any input you may be able to share with me.
Jason
JForbes is offline Find More Posts by JForbes
Old Nov 29, 2012, 11:55 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
White Edition is equivalent to original Hero HD + Wifi + better lens
Silver Edition is equivalent to Hero2 + Wifi + better lens
Black Edition is all new. Better high sensitivity, lower noise sensor, faster processor.. etc.
Can't tell you which version will make you happy, but size/weight shouldn't
be a large factor on a ground vehicle so presumably you could purchase
an original HD or Hero2 for less than an H3 White or Silver and be just as satisfied.
ian
Old Nov 29, 2012, 01:30 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
I don't know if I could help you with the cams, but you sure gave me a new perspective on Velma
carguy1994ca is offline Find More Posts by carguy1994ca
Old Nov 29, 2012, 01:42 PM
JForbes is offline
Parkfly Padawan
JForbes's Avatar
Joined Aug 2011
Originally Posted by carguy1994ca View Post
i don't know if i could help you with the cams, but you sure gave me a new perspective on velma :d
:d:d
Old Nov 29, 2012, 05:54 PM
yosemitez's Avatar
United States, CA
Joined Nov 2010
some gopro hero3 2.7k footage edited in cineform. will try sony vegas next as it will edit the 2.7 and 4k.
select "original" to see the 2.7k
gopro hero3 2.7k (0 min 19 sec)
Old Dec 01, 2012, 08:11 AM
AtGame7 is offline
Find More Posts by AtGame7
United States, PA, Ellwood City
Joined Aug 2011
After reading the entire thread, I have to say I am an utter noob when it comes to FPV and GoPro. Thank you all for the education. If you don't mind a noob question, what it "jello"?
AtGame7 is offline Find More Posts by AtGame7
Sold *SOLD* NIB GoPro HD Hero 2 Motorsports Edition plus NIB GoPro Wifi Combo Kit. jbj620 FPV Equipment (FS/W) 2 Jun 11, 2012 11:54 AM
Discussion FPV using GOPRO HD Hero 2 + bacpac WIFI Link69 Multirotor Talk 4 Feb 26, 2012 07:24 PM
Build Log HD FunJet v2 (mini) build log with GoPro HERO HD jbpilot FPV Talk 14 Oct 31, 2010 09:36 AM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
