Old Oct 16, 2012, 02:36 PM
igotit is online now
Find More Posts by igotit
United States, LA, Houma
Joined Jun 2008
need suggestions for motor setup.
im running a sv27 hull on 2s lipo with ep-1 outboard....stock she can hit 15-18 mph.
im wanting more from it.
i have a seaking 180 amp esc,i think ive found the motor and prop i want to run.im going to post up what im looking at.
give me your thoughts on this setup,post your setup reccomendations.
im on a budget....arent we all.
motor
http://www.hobbyking.com/hobbyking/s...ess_Motor.html
prop....this prop is a 5mm shaft...i need to find it in 3mm.
http://www.hobbyking.com/hobbyking/s...e_Crusher.html
igotit is online now Find More Posts by igotit
Old Oct 18, 2012, 06:28 AM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I think that's about all the power you'll get the EP-1 to handle, the bottom gears aren't very strong and piling on power will probably just strip them faster.
If you want a powerful outboard, look at the Stiletto lower unit, or a K&B or OS 3.5cc based lower leg, they'll take more power. You're going to need to run 4s and a motor around 1800-2000kv to wake the SV27 up, 2s just isn't enough voltage for the size of the hull.
wparsons is online now Find More Posts by wparsons
Old Oct 18, 2012, 08:32 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
Why not run an inboard . Less expensive , faster , more reliable . I've set up two OB conversions to date both were very expensive to do . The OS lower leg was 150.00 and the conversion kit for the motor is 36.00 . And you still need a motor . The stock SV27 is capable of high 30s to low 40s . You can find a used SV27 for less then what it will cost for a fast and reliable OB conversion . Just my two cents .
highflyerbill is offline Find More Posts by highflyerbill
Old Oct 18, 2012, 10:15 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Check out his other thread, he just made a power trim system for the outboard on the SV27.
Old Oct 18, 2012, 06:36 PM
Joined Jun 2008
I have harder gears for the ep-1,the gear maker is running 3300 kv motor on 3s lipo with a 37 mm prop,no problems sofar.
And yes i built up power trim....the ep-1 is staying alive on my sv27.im not looking to break speed records,just a reliable 30 or so mph scale outboard.
Thanx for the other suggestions though,im gonna find the right motor prop combo for my current rig.
Old Oct 19, 2012, 10:11 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You'll have a hard time getting 30mph out of it on 3s without drawing a lot of amperage.
Old Oct 20, 2012, 09:30 AM
Joined Nov 2009
I tried power trim on one of my tunnel boats this was many years ago .A lot of guys tried it and every body went back to no power trim. Just to much trouble in race water . For what you want it will work .I am not familiar with the EP1 out board unit . Do you have to run gears or can you run it with no gears and with a 3665 or 3674 2000kv motor and 4s lipo . That would get you into the high 30s or low 40s . Just don't know if that unit can take that kind of power ?
Old Oct 21, 2012, 12:13 AM
Joined Jun 2008
The ep1 runs 1:1 gear ratio,my friend is running his with 3300 kv on 2s and 3s,he can hit
35.his boat is pretty big.
Its on youtube 4.7 zodiac i think.
I think ill try ....maybe a 33-3900 kv with various props on 3 s.
Old Oct 22, 2012, 12:24 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If this is the one you mean, it's pretty quick, but that's not 35mph.
RC 4 7 ZODIAC GI JOE (1 min 7 sec)
Old Oct 22, 2012, 03:21 PM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
[QUOTE=wparsons;23070063]If this is the one you mean, it's pretty quick, but that's not 35mph.
It might be 35 scale mph
bill34207 is online now Find More Posts by bill34207
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old Oct 23, 2012, 12:18 AM
Joined Jun 2008
Lol....scale mph,i cant pull up the vid,but it must be it.i spoke with the guy lastnight,he says he should beable to put a bigger battery in it and get up to 35.
His english isnt quite up to par,hard to understand.i misunderstood what he said.
He does have upgraded gears and brushless though.running 2s and 3s lipo in that gi joe zodie.
Old Oct 26, 2012, 08:46 AM
Joined Nov 2009
I hate to discourage people but you will never see 35MPH with that combination .That much kv with 3s is not going to swing much prop.
Old Oct 26, 2012, 10:51 AM
Joined Jun 2008
What is reccomended
Old Oct 26, 2012, 02:24 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You also have to consider how big of a prop will even fit on the outboard unit...
Old Oct 26, 2012, 05:25 PM
Joined Jun 2008
I can fit a 37-38 mm nicely
Question ImmersionRC 5.8Ghz setup suggestions needed nscheffer FPV Talk 0 Jun 24, 2012 02:33 AM
Discussion Need suggestion for the setup redblur Multirotor Talk 0 Jun 10, 2012 10:44 AM
Discussion need motor help and suggestions Hypnotic Large Electric Helis 2 Mar 16, 2012 05:18 AM
Discussion 1/4 Scale Airplane motor suggestions needed John Boren Power Systems 3 Feb 29, 2012 03:38 PM
Need suggestions for proven setup for Kadet LT-40 conversion Peter Khor Sport Planes 1 Aug 14, 2004 05:32 AM
