Old Oct 16, 2012, 12:44 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Data
Tools For Building Balsa Planes And More
You can't build without tools. So here is a list I started putting together many moons ago. If you see something I am missing, please feel free to post it and I'll add it to the list. Of course you don't have to have all of these, but I have found many of these tools to be very useful.
I was also thinking about bolding the "must-haves" but not sure if I need to worry about that.
Frank
Acetone
Allen (Hex) Wrenches (Metric)
Allen (Hex) Wrenches (SAE)
Band Aides
CA Tips (Pipette)…
CG Tool…
Clothes pins
Covering Iron
Cutting Mat
Dental floss
Dial Calipers
Dremel Tool (Cordless)
Fourmost Miter Cut
Fourmost Miter Sander
Great Planes Easy-Touch Bar Sander 11"
Great Planes Easy-Touch Hand Sander 5.5"
Great Planes Easy-Touch Sandpaper 150 Grit
Great Planes Easy-Touch Sandpaper 220 Grit
Great Planes Multi-Sander
Great Planes Pro Building Board 16x36x3/4"
Hayes Large Clamp 4"
Hayes Small Clamp 1-3/8" (2)
Heat Gun
Heat shrink tubing, multiple sizes
Hot Glue Gun
House of Balsa Upright 90 Degree Alignment Jig
Infrared Thermometer
Jeweler's Files
Levels, small
Magnifying glass
Masking tape various widths
Master Air Screw Balsa Stripper
Master Air Screw Razor Plane
Metal straightedge 36"
Mircobubbles or sawdust
Multimeter
Paper towels
Parchment paper, Saran wrap, Wax paper
Pin Vise
Pro-Edge Speed Clamp 4"
Prop Balancer (used between two magnets)
Q-Tips
Rubber bands
Rubbing Alcohol
Rulers 6" 12" and 24"
Sanding blocks (Permagrit is top of the line)
Scalpel with #23 blades
Scotch tape
Screwdriver Set
Seam binding/ Hinge tape (3M Blenderm)
Small Drill Bits
Soldering Iron or Soldering Gun
Soldering Jig
Square
Syringe
Third Hand
Thread or fishing line
Toothpicks, round and flat
T-pins
Tweezers large and small
Vise
Waste basket
Watt Meter
Weights; sandbags, steel plates, lead shot, etc
Wire Bender
Z-Bend Pliers
Zona Berna Clamp Small
Zona Miter Box
Zona Razor Saw 42T/in
Murocflyer is offline Find More Posts by Murocflyer
Old Oct 16, 2012, 01:16 PM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
When you buy Exacto saws,or Zona saws......Get the ones with the teeth set to cut when PULLING toward you.
You can cut much straighter,with less force...'Tear out" is reduced to a minimum.And it's just easier to do.
Use a handle whenever possible,which gives you more control,also.And give the saw a chance to cut....too much pressure is harmful to a smooth cut..Let the saw work it's way through,without force.
A HOT GLUE GUN ? Really,Frank ? A HOT GLUE GUN?...l o l.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Oct 16, 2012, 01:22 PM
Murocflyer's Avatar
Joined Nov 2005
Yup, they come in handy for a number of applications.
Frank
Old Oct 16, 2012, 03:32 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
That's some list... I'm proud to say I don't use half of it But it is complete...
Where's the power tools???
Thermalin is offline Find More Posts by Thermalin
Old Oct 16, 2012, 04:30 PM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Pretty complete list. Have a lot of that stuff.
Thought my xacto saw was funky only worked when pulling it I actually prefer it that way works great.
I have used a glue gun to hold wires, servos for added support etc. It does come in handy sometimes. Besides I like the spider web strings it makes
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Oct 16, 2012, 04:38 PM
epoxyearl's Avatar
Joined Oct 2011
I'm here to learn.....I thought hot glue was frowned upon,from it's use in the imported aircraft...So do we use it for any permanent use ?
By the way,Frank...Do you also have a list of adhesives ?
With your excellent listings of kits and tools,I can't wait !
Old Oct 16, 2012, 04:43 PM
Mr_McGlue's Avatar
Joined Sep 2011
I don't but I haven't been building as long as you guys. Of course used it on foam planes too but mainly for the same thing. Wires, servos etc.
On fuel planes not so sure as I would worry about the vibration.
Robert
Old Oct 16, 2012, 04:53 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Frank
How the can you repair and ARF without a hot glue gun??
Oh, OH.... Looks like some one is cheating and assembling ARF's.
kenh3497 is offline Find More Posts by kenh3497
Old Oct 17, 2012, 02:56 AM
Murocflyer's Avatar
Joined Nov 2005
That's a good idea Earl and sadly, I do not. Right now I am working on all-time favorite RC vendors so I kinda backed up for time. Would you or anyone like to start a thread on adhesives? I think that is a good thread idea.
Frank
Old Oct 17, 2012, 09:53 AM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Great idea for a separate thread with a comprehensive list of adhesives and tips on their selection and application.
BTW, another tool for your list is a tip from EJ: an infrared thermometer for precisely setting the temperature of adjustable covering irons.
And I didn't see sandbags.
loNslo is offline Find More Posts by loNslo
Old Oct 17, 2012, 10:26 AM
eliworm is offline
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
Where's the laser cutter?
Jim
eliworm is offline Find More Posts by eliworm
Old Oct 17, 2012, 11:21 AM
Murocflyer's Avatar
Joined Nov 2005
Got it. Thanks!
Frank
Old Oct 17, 2012, 11:22 AM
Murocflyer's Avatar
Joined Nov 2005
Jim
I wish.
Frank
Old Oct 17, 2012, 03:52 PM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Add this important tool to the list.
Wax paper, it's important to cover your plans.
dedStik is online now Find More Posts by dedStik
Old Oct 17, 2012, 04:45 PM
no1isnormal is offline
Find More Posts by no1isnormal
United States, FL, Edgewater
Joined Nov 2010
+1 This seems to be consumed nearly faster than #11 or scalpel blades
no1isnormal is offline Find More Posts by no1isnormal
Discussion I need a plane that: is hard to brake, wingspan not more than 600mm, can do 3d coMix Parkflyers 6 Aug 24, 2012 11:18 PM
Discussion av8n.com says that a wing produces lift by yanking air downwards, can we trust av8n? aeronaut999 Modeling Science 4 May 31, 2012 11:17 AM
you're not about to say "New Jersey", are you? lymon Life, The Universe, and Politics 5 Feb 20, 2002 10:38 PM
