Australia, VIC, Croydon
Joined May 2011
I have a 3m RCRCM Strega with electric fuse
AUW was originally 3.2 K with 3000mah 4s and rec pack then 2990g with 2700mah 4s and UBEC ---now 2900g ---presently trialing 2200 mah4s (may not last ) Running Neu 1506/1.5y/6.7 CC Ice lite 100 Aeronaut 17 x 11 2 x 2s 2700 mah 65c Nanotech for 4s ( cg purposes) CCUbec 10 amps Also running Hitec telemetry with voice --(unbelievable) for speed and height purposes ![]() ![]() ![]() ![]() Initial take off max amps 125amps 1802 watts 6/7 secs to height then 99/110 amps 1504 watts for 3/4 secs-----then amps dropping away after 3/4 quick climbs. Have found that all holds up ok except for batteries---amp draw is very hard on them---pulls down volts to under 3v per cell if I go a little too long on the " hotlinning" and not enough relaxing themalling. I try not to use up any more than about 60/65 % of capacity. Have already given away a set of Turnigy 45c 3000mah 4s and Turnigy Nanos 65c 2700 4s to friends ( still ok for 50/60 amps) With more practice batteries should hold up better ---eg may just use 2200mah for thermalling ![]() ![]() ![]()
Joined May 2011
Hi Kilwein ----could I have more info of your watts and amp draw----I have a similiar set up but appear to be pulling more amps. If yours is the d type you must be way over the motor specs I thought that Aeronaut props pull more than Graupner ---but according to e -calc that prop will pull more then my setting ? Anyone else care to comment Regards Keith |
| Thread Tools | |
| Discussion Power Set Ups - A tool for the Beginner | GeorgeG97322 | Scale Electric Planes | 7 | Sep 26, 2009 12:53 PM |
| Discussion Post your budget E plane set ups. | txfly | Power Systems | 18 | Dec 05, 2006 04:43 PM |
| Pusher Jet Power Set-Ups...Need For Speed! | Tim H. | Pusher Prop Jet Models | 18 | Aug 29, 2005 06:55 AM |
| Question Aileron differential set ups with E-7 | David McNeill | Hitec/Multiplex USA | 1 | Aug 26, 2005 11:27 AM |
| E-Flight BL Set-Ups? | RICH S | 3D Flying | 5 | Jul 02, 2004 03:14 PM |
