Joined Nov 2001
Thanks Bob |
Joined Feb 2008
![]() I have an inventory order going out on December 10th Delivery in the US will be December 18th Pre-Orders accepted www.uavobjects.com Send me a PM and I will see what I can do
Joined Nov 2001
Bob |
I have updated my Guide.. current version V1.3
http://www.rcgroups.com/forums/showa...5&d=1354993533 |
HAve you tried it at all? With a little googling I cant find your answer, but it looks like it shouldnt be too hard, and some posts I see imply people are doing it successfully. I just wonder if it can connect to the telemetry port or if you need to have a breakout harness form the usb port.
. So bear over me if this is totaly wrong.I was also thinking of doing that, but it seems like uart0 and uart2 are the same. But there is a AutoMUX uart0 there which i hope'd i could solder to split those uarts and use uart0 pins for the MinimOSD. A drawing to a novice would help if this came out bad ![]() J |
New Fatshark predator V2 and minimOSD
Hi
I'm planning on buying the New Fatshark predator V2, and wonder if anyone has tried to connect them with the APM2.5 and the MinimOSD? I found a post over at diydrones which had an issue not seeing whats on the lower part of the screen, but that was in january and could have been fixed by now. J |
I have the new SD Attitudes...and they work fine.. There are some issues with MinimOSD v1.0 with hires cameras.. which I think displays the problems you describe.... I have to reset the MinimOSD after power on to get OSD overlay with my 600tvl WDR This is quite a common problem.. but not one that seems to exist if you use a 520tvl or lower camera.. |
I have the MinimOSD 0.1 from China. I've followe your APM2.5 manual setting up my APM, with 433Mhz telemetry and now maked the cable from APM to MinimOSD. Your manual is easy to follow when youre a newbie. J |
| Thread Tools | |
| Sold 3DR APM 2.5 + Ublox Gps | Zenonic | Aircraft - Electric - Multirotor (FS/W) | 4 | Oct 01, 2012 09:32 AM |
| Sold 3DR APM 2.5 + Ublox Gps | Zenonic | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 28, 2012 10:58 PM |
| Sold Apm 2.5 and Gps | Panzlflyer | FPV/RPV - Equipment and Vehicles (FS/W) | 2 | Sep 26, 2012 08:30 AM |
| Sold APM 2.5 with Ublox Gps | Panzlflyer | Aircraft - Electric - Multirotor (FS/W) | 0 | Sep 25, 2012 07:03 PM |
| Discussion APM 2.5 clone - MegaFlight 2.5 | ralphwu | Multirotor Electronics | 1 | Sep 24, 2012 01:18 PM |
