Old Dec 03, 2012, 06:16 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Originally Posted by Truglodite View Post
Chris, your foam is a lot farther back. I put mine farther forward to help block air flow from the inputs, since it's exposed on top of a quad.
FYI, I played with shining a powerful light through many different felts & foams in my garage. Neoprene was the only suitable material (no pun intended) that didn't let a single pinhole of light through. The material Joe used on his baro also looks like neoprene. Neoprene is non-porous. So without a thin fabric sheathing between it an the baro, the holes may get sealed shut.
BTW, on a related note, I like the idea of pressing dense foams against the PCB. Helps with vibration as well as protects the baro.
Kev
You do not want to push it hard against the holes and block them completely.
I did find some open foam that also works, it is black, I can see the tiniest amount of light coming through when I hold it up to a bright light, the source well, it is from ED in a hospital, it was originally used to hold small glass ampules in holes in the black foam.
Some grey colored open foam that seems to be the same except for color doesn't work. Yellow colored open foam doesn't work in the tests I have performed, which is why I was thinking light Pink foam with LED shining up into it was not a good idea.
The test is, get a really bright light and shine it toward the baro while observing VSI in APM Planner, if it swings really wildly as the light hits it then try something else because it is not working.
You know you found the right foam when the readings don't' change at all hen the the light is suddenly directed toward the barometer.
If you use closed foam, you need to test that the foam isn't completely blocking the holes which it will do if you press it down hard, so test by observing altitude in AP Planner and raising and lowering APM 2.5 board ensuring altitude is in fact changing.
You want to keep out light and prop wash yet measure atmospheric pressure accurately, it is a juggling act.
Another consideration if you are using a food container or CD case to protect the electronics, drill some holes to let air out of the container so it cannot become pressurized and lead to incorrect baro readings, for example, if the container only has holes underneath for the cables and the top is sealed you will have incorrect atmospheric pressure readings when the frame descends rapidly..
jabram is offline Find More Posts by jabram
Old Dec 03, 2012, 06:52 PM
jabram is offline
Joined Jul 2012
Originally Posted by zlite View Post
Chris Anderson from DIY Drones/3D Robotics here. I'm a little confused by this comment. When properly positioned in the case, the foam doesn't cover any LEDs.
Hi Chris, I don't have one of your cases with pink foam, my comment was based on testing I did with various colors of open foam, grey, green, light yellow, white.
The only open foam that I found works is black almost shinny black instead of the usual dull appearance of open foam, I sourced it from ED in a Hospital, discarded packing.
The holes in the black foam are used as packing to protect Testing Solution glass ampules for a HEMACUE 201 machine used for testing 3 ranges of Hemoglobin.
In this photo, on the left, you can see a piece of ordinary grey open foam holding up the LED, that foam will NOT work to keep light out of the barometer. The black foam from Hemacue packing which I have covering the barometer held in place by a cable tie works very well, it is open foam so there is no risk of blocking the barometer holes if it presses hard against it.
Old Dec 04, 2012, 05:39 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
Be careful and ground yourself ...as static discharge will almost certainly destroy the board.....
Akcopter is offline Find More Posts by Akcopter
Old Dec 04, 2012, 05:56 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
How will the anti-static foam that comes with the KK2 board from HK do if used to cover the baro??
Old Dec 04, 2012, 08:21 AM
zlite is offline
Find More Posts by zlite
Chris Anderson
San Francisco/Bay Area
Joined Mar 2007
AKocpter: Thanks! We'll look into switching the foam color to black.
zlite is offline Find More Posts by zlite
Old Dec 04, 2012, 09:50 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Anyone have any tips on getting the Minum OSd to work?
I have connected it and it is just showing the "Waiting For Heartbeats" notification.
It has all current firmware, and I have configured it as per here:
SR0_EXT_STAT,2
SR0_EXTRA1,15
SR0_EXTRA2,10
SR0_EXTRA3,3
SR0_PARAMS,50
SR0_POSITION,3
SR0_RAW_CTRL,0
SR0_RAW_SENS,25
SR0_RC_CHAN,3
SR3_EXT_STAT,2
SR3_EXTRA1,15
SR3_EXTRA2,5
SR3_EXTRA3,3
SR3_POSITION,0
SR3_RAW_CTRL,0
SR3_RAW_SENS,25
SR3_RC_CHAN,0
Change accordingly an
Assuming the green wire is the TX-------->RX line (from APM to MOSD), it is all connected correctly. I didnt connect the tx, and am not using telemetry.
Derek_S is offline Find More Posts by Derek_S
Old Dec 05, 2012, 02:55 AM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
If you are not using Telemetry then connect TX and RX and MinimOSD will inititate Mavlink.
If Telemetry is connected then only one can be a "Talker", you therefore need to initiate a Telemetry session to force Mavlink data to be sent to the MinimOSD, or you can make these changes to force data to be sent..
Connect to Mission Planner > Go to configuration > Locate EEPROM parameters and make sure that you have the following parameters configured:
SR0_EXT_STAT,2
SR0_EXTRA1,15
SR0_EXTRA2,10
SR0_EXTRA3,3
SR0_PARAMS,50
SR0_POSITION,3
SR0_RAW_CTRL,0
SR0_RAW_SENS,25
SR0_RC_CHAN,3
SR3_EXT_STAT,2
SR3_EXTRA1,15
SR3_EXTRA2,5
SR3_EXTRA3,3
SR3_POSITION,0
SR3_RAW_CTRL,0
SR3_RAW_SENS,25
SR3_RC_CHAN,0
Change and save the parameters to APM, then MinimOSD should work ok without having to first connect telemetry.
Jumpy07 is offline Find More Posts by Jumpy07
Old Dec 05, 2012, 04:17 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I followed this guide to setup my parameters for ArduCam 2 and telemetry together (OSD Tx pin disconnected):
http://diydrones.com/profiles/blog/s...ource=activity
That thread is from ArduCam 1.x, and ArduCam 2 is more like MinimOSD-Extra, but mine works without setting the SR0 parameters as shown in this thread for MOextra:
http://diydrones.com/profiles/blogs/...age=3#comments
My SR0 values were set to defaults automatically when I configured my telemetry. My understanding is if you set them higher you may get a smoother display, but if you go too high you can saturate telemetry communications. I don't think that is something to worry about unless you use telemetry though? FWIW, my OSD won't get data until after MP is connected, then it will continue to work even after disconnecting. It works without connecting to MP if I remove the telemetry and connect the OSD Tx pin.
Notes on OSD layout:
1- I discovered if the warning display is placed overlapping the artificial horizon using the OSD config tool, the screen goes really weird when a warning flashes. I almost went crazy trying to figure that one out LOL.
2- If you try to hide unwanted characters by overlapping the red reserved areas in the OSD tool, you will get fuzzy characters. Often the anomalies occur at the overlapped area, sometimes you'll get a white line.
I recently downloaded this small font character file for ArduCam but haven't tried it out:
http://diydrones.com/forum/topics/ne...l-for-minimosd
After playing with CL-OSD the smaller fonts grew on me. So hope that works with ACam 2.0.
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite
Old Dec 05, 2012, 06:37 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
Nope jabram(Joe) deserved the credit.....
Old Dec 05, 2012, 08:06 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Thanks guys for the tips, but I have configured those parameters, and still no love.
I did try reconnecting the TX line (yellow) but still cant get the mavlink.
Truglodite, I also tried (quickly before work) these settings you linked:
and still no luck. I have tried a lot of the other troubleshooting ideas such as testing with USb disconnected, re-flashing the firmware and charsets... It really wants to work, but just wont.
Do I need to in some way enable the telemetry radio in the hardware/3dr radio menus to get that port to start working?
Old Dec 05, 2012, 08:41 AM
jabram is offline
Joined Jul 2012
Darn, I was enjoying the confusion figured I was safe and YOU would get the blame.
You asked about KK2 black box, I did in fact try that weeks ago, the inner part of the lid will exclude light from the Barometer, just don't force it tight up against the holes.
Static discharge, sure. always need to be aware and careful.
Old Dec 05, 2012, 08:56 AM
flyboygaac is offline
Find More Posts by flyboygaac
flyboygaac's Avatar
Portugal, Lisbon, Sintra
Joined Jul 2011
How do I connect a Bluetooth module to APM2.5 and also Telemetry?
Is the 1k resistor needed in BT RXD?
flyboygaac is offline Find More Posts by flyboygaac
Old Dec 05, 2012, 11:17 AM
abuzer01 is offline
Find More Posts by abuzer01
Joined Jul 2012
Hi Jabram, I,2ve received 433mhz telemetry kit but as mentioned in dıydrones forum, isn't it too noisy? my 'air' noise is around 20 (I didn't know the unit,there are just numbers) whereas my ground module's is 80. Is it normal? And it's range is about 30 metre(inside the apartment, walls, laptops etc.) What is your opinion?
abuzer01 is offline Find More Posts by abuzer01
Old Dec 05, 2012, 12:52 PM
colsen2715 is offline
Find More Posts by colsen2715
Sandy Hook, VA USA
Joined Jul 2010
I just received the ArduFlyer? board 2.5 from RCTimer and I am getting an error trying to load the firmware for the ArduCopter V2.8.1 Hexa in MP. The message is Failed download new firmware System.IO.IO Exception : The port ‘COM8’ does not exist.
Under Device Manager Ports(COM & LPT) it shows Arduino Mega 2560(COM8). Mission Planner has COM8 selected with a baud rate of 115200.
I have a Windows XP (32 bit) system.
Can anybody help me get past this error?
colsen2715 is offline Find More Posts by colsen2715
Old Dec 05, 2012, 01:24 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Sounds like a cable or PC problem.. would try another USB cable before doing anything else
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Multirotor (FS/W) 4 Oct 01, 2012 09:32 AM
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2012 10:58 PM
Sold Apm 2.5 and Gps Panzlflyer FPV Equipment (FS/W) 2 Sep 26, 2012 08:30 AM
Sold APM 2.5 with Ublox Gps Panzlflyer Aircraft - Electric - Multirotor (FS/W) 0 Sep 25, 2012 07:03 PM
Discussion APM 2.5 clone - MegaFlight 2.5 ralphwu Multirotor Electronics 1 Sep 24, 2012 01:18 PM
