Old Nov 15, 2012, 06:24 AM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Have been looking at the eagles files and the I/O pin outs for the APM 2.5, which def don't match my early Rctimer APM 2.5 board. The GPS and Telemetry port pin outs are different.
Rctimer when they started selling the second batch included a double ended cable, although I don't have one of these (I have another on order) looking at the pictures... the pin outs and wiring looking different and seem to match the genuine APM 2.5
Can someone post decent pictures of the new style cables so I can double check.. the ones I can find are low quality and rctimer is still down at the moment..
Jumpy07 is offline Find More Posts by Jumpy07
Old Nov 15, 2012, 09:12 AM
SiLiKi is offline
Find More Posts by SiLiKi
Joined Mar 2012
APM 2.5 (5wires/pin plug) -> module wires (GPS ou 3DR)4pins plug
Red -> Red
Black -> Green
Yellow -> Yellow
Green -> NOTHING
Blue -> Black
Hope this help for the first batchs of rctimer packs with just wire ended plugs
SiLiKi is offline Find More Posts by SiLiKi
Old Nov 15, 2012, 09:17 AM
RaySuave is offline
Find More Posts by RaySuave
United States, MI, Dearborn Heights
Joined Dec 2009
Originally Posted by Jumpy07 View Post
Yeah just been checking my RCtimer board, and this does not seem to be the same.... this is how my GPS is currently wired and working.. (first version of board)
Would be good to double check the latest versions that come with the double ended cable.. if the diagram I posted for the APM 2.5 is right.. then the Rctimer port pin outs look different.. can anyone else confirm ?.. I don't have a genuine board to check..
I have the RCTimer board that came with the open ended connectors. I tried hooking up he GPS using the scheme from your earlier post, could not get any GPS lock. The Power and GND are correct though. The telemetry port pins are marked on the back of the board (GND, N/A, RX, TX, +5V). I will try to hook the GPS up later today in this scheme which is the same one in the EAGLE files for the connector labeled "DF13-5P-1.25DSA".
RaySuave is offline Find More Posts by RaySuave
Old Nov 15, 2012, 09:57 AM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Is anyone else bothered by rctimers website being down so much?
Mike Freas is offline Find More Posts by Mike Freas
Old Nov 15, 2012, 10:03 AM
kc10kevin is online now
Find More Posts by kc10kevin
Lt Col, USAF, Retired
United States, IL, Swansea
Joined Jan 2010
Yep.
kc10kevin is online now Find More Posts by kc10kevin
Latest blog entry: KKNG Rename
Old Nov 15, 2012, 10:13 AM
geotete is offline
Find More Posts by geotete
Joined Mar 2011
Yep also...
geotete is offline Find More Posts by geotete
Old Nov 15, 2012, 10:23 AM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Red -> Red
Black -> Green
Yellow -> Yellow
Green -> NOTHING
Blue -> Black
Ok, got mine wrong.. had green connected to green on GPS.. still worked as I had set the GPS at 38400 baud.. (was rx line on GP)
Makes sense as matches Eagle files..will update the guide..
Old Nov 15, 2012, 10:27 AM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Ok.... have matched the colors / pins against the Eagle files and added details of the New Style GPS port which was not on the Eagle files for some reason..
Old Nov 15, 2012, 11:11 AM
NEAGRON is offline
Find More Posts by NEAGRON
United Kingdom, Scotland, Aberdeen
Joined Mar 2010
Thanks Jumpy for keeping us up to date your a star,Marty.
NEAGRON is offline Find More Posts by NEAGRON
Old Nov 15, 2012, 11:12 AM
NEAGRON is offline
Joined Mar 2010
Hope rc timer's site is up and running soon,Marty.
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
Originally Posted by geotete View Post
Yep also...
Makes me concerned I'll have to purchase the board from someone else and pay twice as much.....
Old Nov 15, 2012, 11:15 AM
geotete is offline
Joined Mar 2011
That's my problem I was reading more info to buy the RCTimer version, when the decision was ready, the RCTimer website went down...
Geotete
Old Nov 15, 2012, 11:24 AM
Joined Jan 2010
Geotete
Same here....
Old Nov 15, 2012, 11:31 AM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Just tested the 3DR text configuration on the NEO-6 GPS, it was written for the LEA-6 but I can confirm it works on the NEO-6 v2.
You get an error when you load it up.. but seems to configure the GPS in the same was as the LEA-6.. process is exactly the same to load it..
(PS: TX and RX on my NEO-6 were reversed. compared to my LEA-6)
Old Nov 15, 2012, 11:57 AM
Ramnes is offline
Find More Posts by Ramnes
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
APM2.5 vs YS-Xx or?
Hi guys
I have this luxury problem called "cant make up my mind" about what FC to buy for my hexacopters.
I've been looking at the YS-X6, and now the YS-X4, and they both cover what i'm interested in, normal flying, FPV and filming with a HD videocamera. The APM seems to me to be the best choice, but i'v listen to the guys over at the YS-Xx thread, and i think you know what they are recommending me.
I've tried to read about the APM and the problems with it, but cant find very much other than things allready fixed in some code version.
After reading this thread i was introduced to another APM board as well, so what do you guys think?
As a newbie to APM, how long should it take to get me going with the APM board? I've been flying planes and helis, but no acro(my wallet dont like that)
Today i have the KK2 and a Crius MW SE boards. The Crius might be a cameracontroller on the hexa with the KK2 board.
I'm kind of lost in this FC jungel right now, so please help me see the end of this tunnel.
J
Ramnes is offline Find More Posts by Ramnes
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Multirotor (FS/W) 4 Oct 01, 2012 09:32 AM
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2012 10:58 PM
Sold Apm 2.5 and Gps Panzlflyer FPV Equipment (FS/W) 2 Sep 26, 2012 08:30 AM
Sold APM 2.5 with Ublox Gps Panzlflyer Aircraft - Electric - Multirotor (FS/W) 0 Sep 25, 2012 07:03 PM
Discussion APM 2.5 clone - MegaFlight 2.5 ralphwu Multirotor Electronics 1 Sep 24, 2012 01:18 PM
