Old Nov 13, 2012, 12:09 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Originally Posted by Jumpy07 View Post
Nothing stopping you.. if you have one make senses..
However MinimOSD and attopilot is a cheap combination.. and integrates with Arducopter.. including the GCS.. so you loose a lot of functionality with a seperate OSD..
, No, I dont want to use the whole OSD, only the current sensor since I have that already. it is like this one:
Derek_S is offline Find More Posts by Derek_S
Old Nov 13, 2012, 01:33 PM
jmkirsch is offline
Find More Posts by jmkirsch
United States, NY, Rochester
That looks like an Attopilot. What exactly is it?
jmkirsch is offline Find More Posts by jmkirsch
Old Nov 13, 2012, 02:14 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
It is a skylark FPV Tiny OSD
Old Nov 13, 2012, 04:06 PM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
I guess you could get it to work.. depending on the output voltage from the shunt.. but ArduCopter is allready configured for the Attopilot.. you would need to be careful that the voltage from the shunt didnt exceed safe levels for the APM 2.5 and you would need to edit the code in Arduino to get the amps rights for the voltage measure.. ie: calibration....a lot of grief if you ask me.. .. I am a great advocate for the KISS principle..
3DR are about to release a new voltage/amps bridge from what I have read btw.
Jumpy07 is offline Find More Posts by Jumpy07
Old Nov 13, 2012, 08:46 PM
RaySuave is offline
Find More Posts by RaySuave
United States, MI, Dearborn Heights
Joined Dec 2009
Should work ok, the Crius extend board connector extends S1, S2 & S3 to the board... you will to make a cable from the serial on the Telemetry Port and the Serial from the GPS port on the APM to the extend port.. (S2 GPS and S3 Telemetry)
I got the APM2.5 board today and currently deciding on exactly how to hook up the crius extend board to the APM2.5 board. Before I start cutting the connector harness, I would like a suggestion on which APM2.5 port should I use to power the extend board, since the GPS port or the 3DR port will provide +5V?
Also, I have an xbee adapter like the one in the picture, should I just use the adapter to connect to the 3DR port instead of combining the two ports into one plug for the extend board?
RaySuave is offline Find More Posts by RaySuave
Old Nov 14, 2012, 06:09 AM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
The Crius extend board uses the cable from the S1, S2 and S3, the GPS is on the S2 port, the Xbee pins use the S3 Port.
The APM 2.5 has one telemetry port, one GPS port.. there are other I/O ports but haven't used them.
So the cable will need to connect S3 from the extend board to the Telemetry port on APM.... and S2 on the extend board to the GPS Port on the APM.
Both ports have 5V supply.. so either one will be fine. (Xbee tends to use 3.3v which is supplied by the regulator on the Crius Extend board btw).
Old Nov 14, 2012, 09:06 AM
RaySuave is offline
Joined Dec 2009
Is there a chart showing the pin out definitions for the APM2.5 telemetry and GPS ports?
Old Nov 14, 2012, 03:43 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Found this.. might help..
Old Nov 14, 2012, 03:57 PM
RaySuave is offline
Joined Dec 2009
I looked at this before but the connector labels are kind of confusing. Well, based on process of elimination, the 5 pin connectors are for GPS and telemetry, and the 4th pin is not used which makes sense because all the other boards use 4 pins for GPS and telemetry. I will go with that and see what happens.
Old Nov 14, 2012, 04:05 PM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Yeah just been checking my RCtimer board, and this does not seem to be the same.... this is how my GPS is currently wired and working.. (first version of board)
Would be good to double check the latest versions that come with the double ended cable.. if the diagram I posted for the APM 2.5 is right.. then the Rctimer port pin outs look different.. can anyone else confirm ?.. I don't have a genuine board to check..
Old Nov 14, 2012, 06:35 PM
geotete is offline
Find More Posts by geotete
Joined Mar 2011
Rctimer website is down.
Attack or out of business?
Geotete
geotete is offline Find More Posts by geotete
Old Nov 14, 2012, 06:48 PM
kc10kevin is online now
Find More Posts by kc10kevin
Lt Col, USAF, Retired
United States, IL, Swansea
Joined Jan 2010
Geotete
It was down for several hours last night. Maintenance.
kc10kevin is online now Find More Posts by kc10kevin
Latest blog entry: KKNG Rename
Old Nov 14, 2012, 08:22 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
It was down last week also.
Mike Freas is offline Find More Posts by Mike Freas
Old Nov 15, 2012, 01:17 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
The wiki works for me:
http://code.google.com/p/arducopter/...board_Overview
http://code.google.com/p/arducopter/wiki/APM2RC
Kev
Truglodite is offline Find More Posts by Truglodite
Old Nov 15, 2012, 01:18 AM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Still down.
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Multirotor (FS/W) 4 Oct 01, 2012 09:32 AM
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2012 10:58 PM
Sold Apm 2.5 and Gps Panzlflyer FPV Equipment (FS/W) 2 Sep 26, 2012 08:30 AM
Sold APM 2.5 with Ublox Gps Panzlflyer Aircraft - Electric - Multirotor (FS/W) 0 Sep 25, 2012 07:03 PM
Discussion APM 2.5 clone - MegaFlight 2.5 ralphwu Multirotor Electronics 1 Sep 24, 2012 01:18 PM
