Old Oct 16, 2012, 11:17 AM
k5beason is offline
Find More Posts by k5beason
United States, MI, South Lyon
Joined Nov 2007
Rctimer apm 2.5
They are now available http://rctimer.com/index.php?gOo=goo...8&productname=
I've ordered two, if they work I'll be selling my genuine apm 2.0 and cirrus aio pro
I've also ordered the 915mhz telemetry air module from rctimer and;
minimosd from goodluckbuy.
Will keep you updated once they arrive.
k5beason is offline Find More Posts by k5beason
Old Oct 16, 2012, 11:25 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Which GPS unit will you be using with that clone?
kinderkram is offline Find More Posts by kinderkram
Old Oct 16, 2012, 11:27 AM
k5beason is offline
Joined Nov 2007
I have a mediatek right now so will use it for the time being but will probably go to a ublox lea-6h
It's not really a clone since it is open source simply a cheap alternative.
Old Oct 16, 2012, 05:02 PM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
does anyone know if the CN-06 works?
http://rctimer.com/index.php?gOo=goo...3&productname=
compuatic is offline Find More Posts by compuatic
Old Oct 16, 2012, 09:31 PM
k5beason is offline
Joined Nov 2007
It does work, you need to make your own cable http://diydrones.com/profiles/blogs/...ting-other-gps
It should work quite well comparable to the lea-6 if I understand everything correctly. In a brief test I was getting 3 satellites while in the garage which has concrete walls and roof. meditek gets 0
other gps options
http://www.goodluckbuy.com/ublox-lea...ublox-5h-.html
http://www.goodluckbuy.com/gps-recei...ontroller.html
Old Oct 16, 2012, 09:50 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
I placed an order for the apm2.5, cn-06 gps, blue tooth module, and minimosd.
Any idea is the bluetooth works? This setup will be going into a long range fpv plane
Old Oct 21, 2012, 05:50 AM
pavn is offline
Find More Posts by pavn
pavn's Avatar
Czech Republic, Olomouc
Joined Sep 2010
Why do you prefer this over crius all in one pro?
Does not crius have better sensors?
pavn is offline Find More Posts by pavn
Old Oct 21, 2012, 05:55 AM
Jumpy07 is offline
Find More Posts by Jumpy07
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Just ordered one as well... easy step from Crius AIO Pro with MegaPirateNG to APM... I think... $20 of a difference.. no brainer for me....
LEA-6 GPS is far superior to CN 06 .. 3DR to a version with their own firmware that cam out tops in tests..
If cost is an issue.. make sure you get the V2 of the CN06.. much bigger antenna, bigger battery and holds settings in flash
Jumpy07 is offline Find More Posts by Jumpy07
Old Oct 21, 2012, 03:53 PM
pavn is offline
pavn's Avatar
Joined Sep 2010
Why it is no brainer when Crius has better sensors?
Why LEA-6 GPS is better than CN 06?
This version looks like V2.
http://www.rctimer.com/index.php?gOo...3&productname=
Old Oct 22, 2012, 02:28 AM
Jumpy07 is offline
Always learning..
Jumpy07's Avatar
United Kingdom
Joined Aug 2012
Comparison of APM2.5 and Crius AIO Pro
LEA 6 has a much better chipset than CN-06.. v1.0 of the CN-06 has limited battery for saving settings..
V2.0 of CN-06 has bigger antenna and flash for saving configs.. hence quicker start up times.
LEA-6 is a much better GPS.. quicker startup, more accurate fixes.. and Arduino code is available for it..
Old Oct 22, 2012, 08:21 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Looks like Accel/Gyros are same.
http://www.invensense.com/mems/gyro/mpu6050.html
Old Oct 22, 2012, 08:23 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
MPU 6000 only supports both IC or SPI bus interfaces.
but MPU 6050 just SPI.
Old Oct 22, 2012, 08:32 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
Regarding difference between MS5611-01BA03 and MS5611-01BA01
http://www.servoflo.com/pressure-sen...31/603/17.html
http://www.servoflo.com/pressure-sen...30/604/17.html
There seems to be only difference in CAP.
MS5611-01BA01 Variometer Module, with LCP cap
MS5611-01BA03 Variometer Module, with stainless steel cap
Other parameters seems to be same.
Old Oct 22, 2012, 08:35 AM
pavn is offline
pavn's Avatar
Joined Sep 2010
What type of Arduino code is available for LEA-6?
Does that mean that CN-06 V2.0 will not work?
What exactly means much better chipset in LEA-6 exactly?
Does that mean CN-06 V2.0 is painfully slow and inaccurate?
Old Oct 22, 2012, 12:31 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Guys, the biggest meaningful difference in my eyes is the direct compatibility of arducopter / arduplane without having to resort to ported versions.
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Multirotor (FS/W) 4 Oct 01, 2012 09:32 AM
Sold 3DR APM 2.5 + Ublox Gps Zenonic Aircraft - Electric - Airplanes (FS/W) 0 Sep 28, 2012 10:58 PM
Sold Apm 2.5 and Gps Panzlflyer FPV Equipment (FS/W) 2 Sep 26, 2012 08:30 AM
Sold APM 2.5 with Ublox Gps Panzlflyer Aircraft - Electric - Multirotor (FS/W) 0 Sep 25, 2012 07:03 PM
Discussion APM 2.5 clone - MegaFlight 2.5 ralphwu Multirotor Electronics 1 Sep 24, 2012 01:18 PM
