Old Dec 10, 2012, 08:17 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Description: Name: ImageUploadedByTapatalk1355192231.152072.jpg
Description:
TheFernMan is offline Find More Posts by TheFernMan
Old Dec 10, 2012, 09:03 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Thanks odccopter and fernman.
It is a MTK-3329 ?
What is the default baudrate and update rate as shipped?
It does look identical except for the sticker
jabram is offline Find More Posts by jabram
Old Dec 10, 2012, 10:09 PM
oddcopter is offline
Find More Posts by oddcopter
Quadcopter Addict
Joined Nov 2011
It is a MTK-3329 ?
I assume it is, dunno the defaults, I just ran it through Multiwii_dev_r1240 and it works fine. Also, the packaging says it is an MTK.
oddcopter is offline Find More Posts by oddcopter
Old Dec 10, 2012, 10:36 PM
jabram is offline
Joined Jul 2012
Thanks.
Old Dec 11, 2012, 12:25 AM
jabram is offline
Joined Jul 2012
Originally Posted by JimJones View Post
I did within Mission Planner as well calibrate my TX (Futaba FF10). All channels seem to work fine and in the correct direction.
What I fail to do is however to get the quadcopter up and running. When I connect my battery to my quad the status LED flashes, and a few other LED's on the board.
Moving the throttle stick to full down left/right did not do any good
Moving Throttle to the lower right corner did the trick on my old cheap HK FlightController.
Anyone got an idea how to actually arm this Flightcontroller ? Documentation on the HK website did not get me any further.
Any help/hint would be greatly appreciated
Kind regards
Timo
Hi Jim,
Arming is hold Throttle down and over to the right for about 5 seconds the first time you do that there is a about a 4 second delay before the motors will spin. Next arming without disconnecting Lipo motors spin straight after they are armed.
If that doesn't work, it is most likely [make that ALWAYS] to do with calibrating each ESC.
I know it is tempting to do the easy easy ESC calibration doing them all at once BUT that is not a really good idea [never works for me] as you can end up with some that are not calibrated correctly.
If you have calibrated your ESCs before DO THEM AGAIN one at a time. Specially if you already had the ESC working and calibrated with Multiwii as they will be incorrectly calibrated for MP NG. Multiwii can send out a much lower PWM than MP NG does for arming the ESCs. End result is your ESC is waiting for that lower PWM before arming and it will not get it from MP NG, calibrating the ESCs as per my notes below will calibrate your ESCs for use with MP NG and they will then arm correctly.
Zero all trim and sub-trim on your transmitter set end points or as some radios call it "travel" to +100 and -100 or use the Radio calibration in Mission Planner and tweak your transmitter end points/travel so that you see PWM values in Radio Calibration between 1000 and just a tad short of 2000, like 1996 or so, the reason for staying just under 200 is that SimonK flashed ESC sometimes cut out if you apply more than 2000 and you don't want that to happen..
Then use the receiver Throttle PWM output connected directly to each ESC signal line one at a time and calibrate each ESC one at a time.
Make sure you have done Radio Calibration in Mission planner.
And please DO REMOVE PROPELLERS BEFORE DOING ESC CALIBRATION, we want to see around for a lot longer
Old Dec 11, 2012, 03:33 AM
JimJones is offline
Find More Posts by JimJones
Joined Jun 2006
Thanks Jabram,
I indeed did not recalibrate the ESC's by now. Did it once for the other HK board.
I will try to figure out how to do it. This has nothing to do with the HK programming card that I own, has it ?
I am using Turnigy Plush 10A ESC's, not sure if they are with Simon K firmware, did built them in out of the box.
For the time being all the Platform does when attaching the battery is a ticking sound like three times a second with all four props just moving a little bit, rather a vibration than a real movement.
Regarding my fingers, if you would see the size of my quad you would not be to worried
JimJones is offline Find More Posts by JimJones
Old Dec 11, 2012, 04:02 AM
jabram is offline
Joined Jul 2012
Thanks Jabram,
Ok, we are on the right track, it is your ESC calibration that is holding you back.
Go back to the first post in this thread and find the section detailing how to calibrate your ESC, unless you yourself flashed your ESC then they are NOT SimonK flashed. Don't worry about Simonk for now, get this thing to work first.
Old Dec 11, 2012, 06:28 AM
JimJones is offline
Joined Jun 2006
Ok, calibrating the ESC's was quite easy.
The platform flies now. Hmm more or less. It wobbles very fast around the roll axis, nearly uncontrollable. I will have to stick my nose a little bit deeper into Mission Planner to find the value which I have to change to stop the quad from wobbling like crazy.
First I thought the reason could be that I never balanced the props, they are balanced now but did not change anything. Quad behaves exactly the same.
Old Dec 11, 2012, 06:30 AM
JimJones is offline
Joined Jun 2006
Does anyone know if there is a way to use MP on a mac ?
Got a windows machine as well but would prefer to run it on my laptop (mac), makes me more mobile for actual testings.
My wife is not to amused with me doing all the flight testings in our home office
For whatever reason (that I absolutely don't get) she is not as passionate about my little quad as I am :P
Old Dec 11, 2012, 06:58 AM
JNJO is online now
Find More Posts by JNJO
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
....into Mission Planner to find the value which I have to change to stop the quad from wobbling like crazy....
Rate Roll P and Rate Pitch P is what you are looking for.
A good place to start with tuning is the ArduCopterWiki
...Does anyone know if there is a way to use MP on a mac ? ...
Yep, sell the mac and buy a PC.
No, seriously, I don't know, but on that wiki page there is a statement a few paragraphs down, indicating Linux and Mac support.
Good that hear that you got the arming and esc-calibration sorted.
/J
JNJO is online now Find More Posts by JNJO
Old Dec 11, 2012, 07:15 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Here is what mine looks like:
My GPS module, order few weeks back from HK, is looking the same.
I did stick to a serial port, and I see ... that it start at 9600bps, but it quickly change back to 115kbps.
It is printing pure NMEA ... so who care if it is MTK or U-block, or whatever ... just a vanilla NMEA 115k configuration and it will work fine with every board or every "vanilla" firmware.
I did not count what is the frequency of the NMEA update, maybe for sure over 5Hz, but I did not check to count if they are 10 ...
My GPS did not lock on any satellite after 1 or 2 minutes from my indoor test ... so I can't say if it is better or worst then other GPS that I own.
One question ... why there is a "paper" adhesive sticker on the antenna ??? It make no sense ... I did remove it on my GPS ... anybody has idea ? Maybe it is for avoid eventual contact with some metal part in the quad
Tchuss
e_lm_70
ps: Maybe this weekend I have time for maiden on my quad this board ... but most probably all will be moved to my Xmass and New Year vacations ... I hope to make a nice waypoint following fly on the snow landscape here
e_lm_70 is offline Find More Posts by e_lm_70
Old Dec 11, 2012, 07:16 AM
jabram is offline
Joined Jul 2012
I have no idea why your wife would not be enthusiastic about the little flying lawn mower, very strange
It will be a miracle if the default PIDs are correct for your frame and motors. SO you will have to perform PID tuning.
Easiest way to tune PID is Using CH6 mapped to a dial on your RC Tx
First - go to this page http://code.google.com/p/arducopter/wiki/AC2_Tweaks
Scroll down to Method 2: Flying Attitude Tuning with CH6: learn how to use a dial on CH6 for tuning.
Then - have a look at this excellent tutorial in which the Author forgets to mention that he is using Method 2: Flying Attitude Tuning with CH6:
http://diydrones.com/forum/topics/ar...r-tuning-guide
Seriously, you should wear long welding gloves when tuning this way as it is very easy for the blades to cut your arm while you hold the frame, Eye Protection is also recommended.
PS, what is a Mac, is that like a burger
Old Dec 11, 2012, 07:18 AM
Quadcopter Addict
Joined Nov 2011
My understanding is there is no way to capture and calibrate my mag from a log with this board.
Also, I don't have telemetry or a USB cable long enough to do the dance.
So, I calibrated my mag by setting the parameter "COMPASS_LEARN" to 1, then flew around a while, then set it back to 0. This seems to work.
Could someone could verify that this is a good approach?
Old Dec 11, 2012, 07:21 AM
JimJones is offline
Joined Jun 2006
Thought so as well, so far under PID setup I only found parameters for yaw etc, but no roll and pitch. Will have a look at the wiki
No way, I'll stick with crApple !
Old Dec 11, 2012, 07:43 AM
jabram is offline
Joined Jul 2012
@e_lm_70
The paper sticker is to protect the thin deposited top layer of the GPS patch antenna during shipping.
Test GPS outdoors with a clear view of the sky all around.
Discussion [UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module benybee UAV - Unmanned Aerial Vehicles 418 Nov 20, 2015 07:32 PM
Help! PROBLEM on Crius AIO Pro Y6 With MegaPirate NG 2.7 R4. RQuad Multirotor Electronics 3 Jan 22, 2013 12:13 AM
Found MultiWii PRO Flight Controller w/MTK GPS Module Koo Aircraft - Electric - Multirotor (FS/W) 4 Oct 10, 2012 11:47 PM
Yippee! New AirStudio universal Flight Controller for Mega Pirate NG and MultiWii AirCopter Multirotor Electronics 44 Sep 10, 2012 04:56 AM
