Old Dec 07, 2012, 01:58 AM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Originally Posted by view27 View Post
Hi Joe,
Sorry I didn't get back to you sooner.
I checked again exactly the same way as you did with my Plane radio which is a JR X2720 fitted with a 2.4ghz Frsky hack module and V8FR2 Receiver, with exactly the same results. This was on a Channel that has never been used. The only Throttle Mixing I use is for the Helicopters and Powered Gliders. I also checked the photos on the first post with my Android Tablet and zoomed the area in. I checked the circuit board with a magnifying glass and to me, the tracks both top and bottom appear to be identical so I really don't know what is going on. That is why I asked the question as to which diagram to follow. HK's, Yours or Mission Planner.
I am sorry if I have caused you a bit of a headache but this board and principle is all very new to me so I don't think it is anything I have done in the programming.
Regards
Bruce
Bruce,
No need to be sorry, I really don't mind, if there is a problem it is best solved ASAP.
The question I want to ask you
If you disconnect all receiver channels from HK Mega board J11 header pins
You ONLY connect 1 channel to A8 on J11 header of HK Mega
In Mission Planner Radio Calibration which channel shows any movement ?
I am not being funny, a lot can be misinterpreted in words, and I want to rule out all other variables.
Joe
jabram is offline Find More Posts by jabram
Old Dec 07, 2012, 02:03 AM
view27 is offline
Find More Posts by view27
Australia, TAS, Ulverstone
Joined Oct 2009
Joe,
Just thought I would let you know that both my Receivers use:-
1 = Throttle
2 = Aileron
3 = Elevator
4 = Rudder
5 = Gear
6 = Aux1
7 = Aux2
8 = Aux3
I understand some Receivers are different. I had Hitecs when I first started and they are totally different to the JR's.
Bruce
view27 is offline Find More Posts by view27
Old Dec 07, 2012, 02:06 AM
view27 is offline
Joined Oct 2009
A8 J11 shows Throttle only.
Originally Posted by jabram View Post
Bruce,
Joe
Old Dec 07, 2012, 02:34 AM
jabram is offline
Joined Jul 2012
Words are sometimes not enough.
Imagine your receiver is a PWM simulator, so we do not care what its ONE signal output is called.
We apply that NO NAME PWM signal to A8 - all other cables removed from J11 -
We observe movement on one channel in Mission Planner Radio Calibrate.
Under those exact circumstances do you see the Throttle channel bar moving in Mission Planner ?
Old Dec 07, 2012, 02:49 AM
view27 is offline
Joined Oct 2009
Joe,
Yes I am running the same version..All seems weird to me also..After checking the traces on the new board and comparing them to your photos, it appears that it is still the same board..
I suppose as long as you take notice of Mission Planner in what it reports, things will work out. It would still be nice to know why this is happening.
Bruce
That is weird. you are running MPNG 2.7 R4 ?
Based on the photos the board hasn't changed yet you get different results, anyway so long as one checks in Radio Calibration all is good.
Old Dec 07, 2012, 02:54 AM
jabram is offline
Joined Jul 2012
Joe,
Bruce
Thanks Bruce, weird no doubt about it, so long as it is verified in Radio Calibrate all is good.
Old Dec 07, 2012, 03:17 AM
view27 is offline
Joined Oct 2009
Joe,
Just a final question. How do you think this HK Mega Board or the Crius board would go handling a large machine. Say a Hex 1500 mm across with an all up weight of around 7 - 8 Kg? I know that the board wouldn't care less as to what sort of motors are attached to it. What I am more worried about is a large machine going to test it's capabilities of keeping it stable but still responsive?
Bruce
Old Dec 07, 2012, 04:11 AM
jabram is offline
Joined Jul 2012
Joe,
Bruce
Bruce,
Apart from the older barometer on HK Mega they are all fairly equal, including the the Crius ArduFlyer which is an APM 2.5 clone.
The reason I got involved was to build a frame that I could use for Aerial Video in outback Australia, I started on that project about 5 months ago, now I have a large collection of 32 bit and 8 bit controllers and a thinner wallet, IMHO none of the current 32 bit controllers are good enough YET, they are all work in progress, quickly ported to a faster 32 bit processor that is wasted because of unfinished firmware, AeroQuad 32 is a good example, it can barely do what a HK KK v2 can do!!.
I have avoided Naza and Zero because I do wish to be at the mercy of greedy people flogging a fairly ordinary CLOSED SOURCE product marketed as the best thing since sliced bread, reading the user's threads posts from those that are not easily led by marketing quickly becomes apparent they are far from perfect.
There is also AutoQuad 6, great idea, woeful CLOSED hardware design and not really fully open firmware, again the greed factor mixed with a touch of deceit. I do have a burnt out AQ6, $700 worth of junk and 2 months wasted. Great learning experience. Eventually I was openly refused any support because of my "attitude". Obviously I am no good at all at grovelling or being "diplomatic" about junk and I have an extremely low [below zero actually] tolerance to pure BS.
Currently my best choice is the Rctimer ArduFlyer or APM 2.5 and my reasons are that the firmware has the most features and more continuing development than is heading in direction I am interested in than all the others, APM 2.5 not that different to HK Mega with MP NG except when there is an update I don't have to wait for someone to port it over to MP NG.
There is little difference in price between HK Mega and ArduFlyer and they appear to be almost the same hardware, closer inspection reveals you get a LOT more for that meager increase in price of the ArduFlyer over the HK Mega, things that mean nothing to most people, a bit like insurance seems not important until you find out you really should have opted for it.
Things ArduFlyer or APM 2.5 has that neither HK Mega nor AIOP have, fully OPEN HARDWARE AND FIRMWARE, excellent documentation, full accurate Schematics, revere polarity protection, over voltage protection, current limit protection on all PWM inputs and outputs, nearly all ports on ATMEGA2560 are available on headers, well designed power distribution with well filtered regulated power supplies, buffered interface to sensors, on board magnetometer can be disabled and an external magnetometer can be attached away from all the heavy wiring that affects the compass and position hold, logging to flash memory,
I have a quad and 2 hex frames, largest one is an 800 mm Hex X.
I could use any of the ATMEGA2560 based controller on my Hex and it would not be an issue. Currently I am using the ArduFlyer, keeping an eye on 32 bit flight controllers but I do not see anything exciting happening any time soon.
Attention to ALL SMALL detail during construction, balancing motors and props. wiring arrangement and more importantly TUNING is what will make a real difference IMHO.
Aren't you sorry you asked that question
Joe
Old Dec 07, 2012, 05:44 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
Joe Is One Great Teacher...
Akcopter is offline Find More Posts by Akcopter
Old Dec 07, 2012, 06:09 AM
RYBAT is offline
Find More Posts by RYBAT
FAA Certified Pilot
Joined Feb 2008
Perzactally.....and he's not an arrogant POS...Just a good guy
RYBAT is offline Find More Posts by RYBAT
Old Dec 07, 2012, 07:57 AM
my_vision is offline
Find More Posts by my_vision
Joined Feb 2007
Hi guys, just wonder is it possible to configure at least PID controller over bluetooth like for MultiWii over here http://www.rcgroups.com/forums/showthread.php?t=1428641
Maybe need some tweaks to make it work?
my_vision is offline Find More Posts by my_vision
Old Dec 07, 2012, 10:00 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Ok i checked again.
so i connect just the throttle from my receiver (CH3) to the J11 receiver connections on the board. It this point its JUST usb and throttle from receiver.
As I moved the throttle on my remote, I checked the Radio Calibration screen on Mission Planner.
The is what i get:
A8 Throttle
A9 Roll
A10 Pitch
A11 Yaw
A12 Radio 5
A13 Radio 6
A14 Radio 7
A15 Radio 8
Running MegaPirateNG_2.7_R4 and Mission Planner 1.2.25
TheFernMan is offline Find More Posts by TheFernMan
Old Dec 07, 2012, 10:14 AM
jabram is offline
Joined Jul 2012
Joe,
Bruce
Bruce and others who helped me through my moment of insanity.,
Mystery solved, my fault, I had a setting which changes the mapping and had forgotten about it
A8 = Throttle
A9 = Aileron/Roll
A10 = Elevator/Pitch
A11 = Rudder/Yaw
A12 = Ch5/Radio 5
A13 = Ch6/Radio 6
A14 = Ch7/Radio 7
A15 = Ch8/Radio 8
Is correct
Thanks for you help/sanity check.
Old Dec 07, 2012, 11:21 AM
JNJO is offline
Find More Posts by JNJO
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
Yes and no.
You can use a BT module to communicate wireless with the mission planner and do everything, except flash the firmware.
The thread you linked to is for an android app. and there is no working app for mavlink 1.0 as far as I know.
The closest to that is an app called Copter GCS, but it looks like we'll have to wait for mavlink 1.0 support.
Project home for CopterGCS -> http://code.google.com/p/copter-gcs/
/J
Edit: Somebody claims to have a working clone of CopterGCS -> https://code.google.com/r/xcl0100-copter-gcs/
I'll try it this weekend and report back.
JNJO is offline Find More Posts by JNJO
Old Dec 07, 2012, 01:40 PM
Sudsy is offline
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Mag Var Calculator
Here's a handy link.
http://www.ngdc.noaa.gov/geomagmodel...alcDeclination
Sudsy
Sudsy is offline Find More Posts by Sudsy
Discussion [UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module benybee UAV - Unmanned Aerial Vehicles 418 Nov 20, 2015 07:32 PM
Help! PROBLEM on Crius AIO Pro Y6 With MegaPirate NG 2.7 R4. RQuad Multirotor Electronics 3 Jan 22, 2013 12:13 AM
Found MultiWii PRO Flight Controller w/MTK GPS Module Koo Aircraft - Electric - Multirotor (FS/W) 4 Oct 10, 2012 11:47 PM
Yippee! New AirStudio universal Flight Controller for Mega Pirate NG and MultiWii AirCopter Multirotor Electronics 44 Sep 10, 2012 04:56 AM
