Old Dec 04, 2012, 05:29 PM
LegendLength is offline
Find More Posts by LegendLength
Australia, NSW
Joined Sep 2006
Originally Posted by jabram View Post
the data flash is not on this board, it is on the original APM 2.5 board, I have one of those, to be honest, I don't find it useful.
I used "Method 2: Flying Attitude Tuning with CH6:" on this page, that makes PID tuning real easy
http://code.google.com/p/arducopter/wiki/AC2_Tweaks
Wow you've done it again, great page I don't know how i missed it.
I will have a 3dradio soon I'll just wait until that arrives before tuning.
LegendLength is offline Find More Posts by LegendLength
Old Dec 04, 2012, 05:55 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Received my board today and the supplied gps cable is different colors than the first post. Then I just remember that gps is rx2 to tx and tx2 to rx
Oh and the gps auto config tip was awesome! Thanks!
TheFernMan is offline Find More Posts by TheFernMan
Old Dec 04, 2012, 06:12 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Thanks, I will edit the first page to refer to the labeling rather than the changing GPS wire colors.
jabram is offline Find More Posts by jabram
Old Dec 04, 2012, 06:26 PM
jabram is offline
Joined Jul 2012
3DRadio is great, definitely not a luxury item, when you receive it pay attention to the setting, refer to the first post in this thread, the default setting are not ideal and can frustrate you to near insanity,
When using 3DRadio be aware that you should always click disconnect on Mission Planner before turning off power to your frame.
Reason for doing that;
Say you have been using Mission Planner connecting via 3DRadio and you just unplug your lipo.
When you reconnect the Lipo you will be convinced something is suddenly wrong with your board as it wont start, the lights don't blink etc.
All you have to do in that case is to go back to Mission Planner and click on disconnect
If mission planner is already connected to the ground station and you then power up the board, the attached air 3DRadio [which has been up and running all the time powered by the PC remains fully connected] sends out data to the HK Mega board's serial port and confuses it as it is NOT expecting data while trying to boot. This doesn't happen with USB as once you unplug it the Virtual COM port no longer exists.
The thing to remember is always click disconnect in Mission Planner before you switch off your board, that way next time you go to use it can't catch you out.
Anyway just be aware, if you get trapped, you will remember reading this post.
Old Dec 04, 2012, 07:50 PM
Clavin01 is offline
Find More Posts by Clavin01
Clavin01's Avatar
USA, MD, Glen Burnie
Joined Sep 2008
Multiwii
Hello
OK here is my problem,
If I load mp 2.7 I can hook up to mission Planner but do not get any thing
working, I can move the board and the indicator does not move.
Tried MP 2.6 and it works tilting the board and the indicator shows it
compass works. However I can not get the gps to work .
When I started with the Multiwii everything worked including the gps.
Any help would be appreciated. Sorry to be such a pain, I have tried
different setting but no Luck.
Thanks Cliff
Clavin01 is offline Find More Posts by Clavin01
Old Dec 04, 2012, 08:28 PM
jabram is offline
Joined Jul 2012
Originally Posted by Clavin01 View Post
Hello
Thanks Cliff
Are you using the HK Mega board or some other board like the whitespy mega?
Does mission planner connect ?
in other words do you see white text on a black background displaying a bunch of file names just after you click on connect, like this
Old Dec 04, 2012, 08:38 PM
jabram is offline
Joined Jul 2012
Heads up for anyone not using genuine HobbyKing Mega.
Anyone using whitespy mega 2 which has different sensors, at this point it is NOT safe to be following the instructions in this thread with whitespy mega as that board has different sensors in a different alignment.
I am sure MP NG can be made to work on whitespy mega BUT that requires some work followed by thorough testing.
If you are using whitespy mega board and post here for help PLEASE state clearly that you have a whitespy mega or whatever OTHER board you are using, avoids a lot of confusion.
By the way, there is nothing wrong with whitespy mega, it is just that the information currently in this thread is not suitable for the newer sensors used in the whitespy mega.
Old Dec 05, 2012, 02:56 AM
JNJO is offline
Find More Posts by JNJO
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
@subaru4wd
Oops, my bad... I forgot you had a witespy 2.0
Like jabram said, your APM_config.h is correct for your baro.
/J
JNJO is offline Find More Posts by JNJO
Old Dec 05, 2012, 03:17 AM
JNJO is offline
JNJO's Avatar
Joined Jun 2012
...When you reconnect the Lipo you will be convinced something is suddenly wrong with your board as it wont start, the lights don't blink etc...
+1
Damn good info jabram.
Thanks, I would never have figured that out.
I've seen it happen, apparantly random, a few times, and always got around it with a reset. (Which is really, really embarassing when there's an audience...)
Old Dec 05, 2012, 04:45 AM
Clavin01 is offline
Clavin01's Avatar
Joined Sep 2008
multiwii
Hello, Yes it connects. I am not sure what multiwii it is. It was not bought from Hobbyking, so it might be a whitespy version. It was bought new along with
the ublox gps, all the sensors have dark type on them, very hard to read.
Cliff
Old Dec 05, 2012, 08:25 AM
jabram is offline
Joined Jul 2012
Cliff
You cannot find out exactly which board you purchased.
You would like help with it.
You hope we can guess which board you purchased.
I suspect this may shock you, sadly we just aren't that good at guessing
I guess your board does NOT look exactly 100% like this Hobby King mega
Old Dec 05, 2012, 09:01 AM
Clavin01 is offline
Clavin01's Avatar
Joined Sep 2008
Multiwii
No it is not the Hk version
looks like a whitespy. I looked at both
This AM. I am sorry for not checking which
Board i have. I looked at the specs and mine
matched the Hk so I though it was the same
mine looks identical to whitespy's version 1
Can this board work with MP?
Again I am sorry about this. And i really
Appreciate what you have done to help me.
I have contacted the seller, it is from Airbot, Which is
most likely the same as Whitespy's board
Spec's Atmega 2560
Baro - BMP085
Acc - BMA180
Gyro - ITG3205
Compass - HMC58831
In software config it say's to use FFIMUv2
Hope this help's
Cliff
Old Dec 05, 2012, 02:12 PM
Sudsy is offline
Find More Posts by Sudsy
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
Ok, I'm going to ask
Hello all;
I will be the first to admitt that I am a hardware guy. Some of the terminology used here (Arduino, Averdude, Lazyzero, etc.) confuse me. I have so far downloaded Arduino 1.0.2.
1. Can someone compile a list of the programs I will need to properly configure this board. I don't need links and can do the searches to find the stuff I need but I am just not sure what that is. Maybe just a brief description of what each program does.
2. Will this board do anything right out of the box? Are these "flashes"and program uploads just revisions to the original firmware and software? (I think this is just new/better performing firmware)
3. I am thinking that the Mission Planner programming is held in the eeprom, is that correct? So I have to erase and reload the eeprom for each different flight profile I want to fly.
4. How does this board act when just flying the quad?
5. I see nice graphics of maps and overlays in the Mission Planner. Where do these come from?
I have not done a thing with this board yet. It is the Hobby King board and I just got it last week. I have four quads and want to build another with this board. I have a frame and will order some motors and speed controls after Christmas.
Bottom line I have fried 2 KK2 boards trying to "flash" them and don't want to do the same thing here. I'm getting old and may not have time to order many more boards from HK.
Sudsy
Sudsy is offline Find More Posts by Sudsy
Old Dec 05, 2012, 02:24 PM
TheFernMan's Avatar
Joined Jul 2012
1) Software
a) Arduino to upload the firmware
b) Actual MegaPirate firmware MegaPirateNG_2.7_R4.zip
c)Mission Planner to config flight options
MegaPirateNG is actually a port or copy of the original Arducopter project.
Arducopter is for those APM1 2 and 2.5 board.
Arducopter was modified and changed to MegaPirateNG support "cheap Arduino MEGA and some sort of IMU boards"
Old Dec 05, 2012, 02:33 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Sudsy
I find it hard to believe you bricked a KK2 while trying to flash it.
You wont have to worry about any of that with this board, as it uses a USB cable and not a ISP plug. So its pretty fool-proof.
AcroFPV is offline Find More Posts by AcroFPV
Discussion [UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module benybee UAV - Unmanned Aerial Vehicles 418 Nov 20, 2015 07:32 PM
Help! PROBLEM on Crius AIO Pro Y6 With MegaPirate NG 2.7 R4. RQuad Multirotor Electronics 3 Jan 22, 2013 12:13 AM
Found MultiWii PRO Flight Controller w/MTK GPS Module Koo Aircraft - Electric - Multirotor (FS/W) 4 Oct 10, 2012 11:47 PM
Yippee! New AirStudio universal Flight Controller for Mega Pirate NG and MultiWii AirCopter Multirotor Electronics 44 Sep 10, 2012 04:56 AM
