Old Oct 17, 2012, 10:43 PM
jabram is offline
Find More Posts by jabram
Joined Jul 2012
Originally Posted by Tim2 View Post
Jabram,
Great idea to set up a second thread!
One question, you talk about setting up GPS for 5hz update. I thought the MKT works at 10hz. Does it make a difference?
Thanks ... Tim
Simple answer is I don't know if it makes much difference, I suggested the solution in my first post to save all the hassles of what baud rate is the MTK3329 set to out of the box which a lot of people struggle with.
If you want to fiddle, the MiniGPS tool can be found here
http://code.google.com/p/ardupilot/d...s.zip&can=2&q=
That is what /J did according to his earlier post in this thread
Edit: Looks like it was as simple as changing to 10Hz in the MiniGPS tool, and use NMEA in APM_Config
The MTK3329 can work at many different baud rates and update rates so long as the setting you select match your selections in the MP NG code it will work..
jabram is offline Find More Posts by jabram
Old Oct 17, 2012, 10:57 PM
Tim2 is offline
Find More Posts by Tim2
Tim2's Avatar
Devon, Alberta
Joined Apr 2003
Thanks jabram.
I had already flashed my GPS to 115200 10hz. From your post I wasn't sure if it had to be at 5hz so I just wanted to be sure. I will leave it at 10hz for now.
Tim
Tim2 is offline Find More Posts by Tim2
Old Oct 19, 2012, 11:59 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
Great work Jabram...you the Man..Subscribed
Akcopter is offline Find More Posts by Akcopter
Old Oct 19, 2012, 12:39 PM
JNJO is online now
Find More Posts by JNJO
Done Posting, Gone Flying
JNJO's Avatar
Sweden, Uppsala County, Balsta
Joined Jun 2012
Hehe, just got my sonar to work.
It's an SRF05. Selected the default type in APM, D9 to Trig and D10 to Echo.
Now....If only the 3DR could be as co-operative.....
/J
JNJO is online now Find More Posts by JNJO
Old Oct 19, 2012, 07:32 PM
jabram is offline
Joined Jul 2012
/J
What issues are you having with 3DR ?
Old Oct 20, 2012, 04:03 AM
JNJO is online now
JNJO's Avatar
Joined Jun 2012
@jabram.
No heartbeat. But I ran a link between two ports on a laptop and that worked fine, so I'm thinking that the radios are good and set up right.
My initial problem was that I selected the wrong port when uploading firmware to the flight radio, so I actually uploaded to the ground station.... twice.
I also discovered in the process that I only have 3.8V on the 5V, and 2.7V on the 3.3V port pins on the board, which might explain why it's not working with the board, so that's on top of things to fix. Guess I toasted a diode at some point.
Edit: Or not. Can I trouble one of you guys to measure the voltage on the 5V and 3.3V I2C-ports with no USB connected. Also, is your VBUS diode lit when USB is disconnected. As soon as I connect my USB the voltages are correct.
TIA
/J
Old Oct 20, 2012, 09:03 AM
jabram is offline
Joined Jul 2012
I am powering my HK Mega board from an adjustable power supply connected to J10 - D46, edge of board is GND, next pin away from board edge is positive supply input in my case..
With 5V input, 5V=3.91, 3.3V=2.83
With 6V input, 5V=4.88, 3.3V=3.33
With USB disconnected VBUS LED is OFF, 5V LED ON RED, LED2 BLINK, LED3 BLUE. LED4 OFF.
Quit worrying the low voltages are normal, Low Drop Out [LDO] voltage regulators are used which explain the drop, the slightly lower voltage does not affect any of the sensors or GPS or ATmega2560 as they are all rated below those voltages.
If you want exactly 5V and exactly 3.3 volts then power it with 5V input at the 5V pin on J2
Uploading twice to either 3DRadio station does not cause any permanent problems.
The 3DRadio, try this - power the HK Mega board up with the 3DR radio NOT plugged in, once LED on HK Mega blinking - then plug 3DRadio in, then try to connect, if that works the issue is handshaking CTS and RTS on the 3DRadio.
are you sure you have the correct COM Port and Baud rate ?
Try these setting for 3DRadio
Old Oct 20, 2012, 10:46 AM
JNJO is online now
JNJO's Avatar
Joined Jun 2012
@jabram
Tnx. Fantastic info. You confirmed what I suspected, that all is good with my power.
I got the radio to work following your suggestions. Turned out to be a mismatch between the baudrates. To much fiddling late at night.....
Hope we get to fly these bords again soon.
/J
Old Oct 20, 2012, 10:51 AM
jabram is offline
Joined Jul 2012
@jabram
/J
Fat chance of flying, it is either strong winds or rain here. Glad you got it sorted.
Old Oct 20, 2012, 06:49 PM
lobstermash is offline
Find More Posts by lobstermash
Joined Jul 2012
Very nice guys. I've shelved my project to get this going with APNG for now, but this should help when I come back to it!
lobstermash is offline Find More Posts by lobstermash
Old Oct 21, 2012, 08:35 AM
JNJO is online now
JNJO's Avatar
Joined Jun 2012
Big scare yesterday, when I ripped off my USB-connector.
(Don't ask how...It involved a cable twisted around my leg and a ringing phone....)
Anyway, managed to re-attach it (Damn, those SMD:s are small...), but it looks like I toasted the CP2102 USB to serial chip in the process.
Uploading through an FTDI on TX0 didn't work either, but then I found a very well hidden post by Sir Alex, saying that the CP2102 chip had to be removed for that to work.
Did that, and now all is well again. Sort of....
To upload firmware through TX0, I have to burn the boot loader with arduino and an USBavp on the ISP-header first. Propably a fuse bit that needs changing.
And for now, I lost my terminal in APM.
/J
Old Oct 21, 2012, 10:40 AM
jabram is offline
Joined Jul 2012
/J
Darn, bad luck.
The only thing stopping Arduino upload using J2 FTDI socket Hk Mega board is that there is NOT a 100nF capacitor from the J2 socket DTR to the RESET pin on ATMega2560 [Pin 30].
Arduino uses a pulse on DTR to pulse the 2560 RESET via the capacitor, that resets the 2560 and Arduino starts upload before the 2560 times out and boots the application firmware.
I have just uploaded a sketch to HK Mega using FTDI cable connected to J2, no chips removed no different boot loader, no changes at all to the board powered from FTDI cable USB not connected.
Watch the Arduino status line when it changes from "Compiling sketch" to "Uploading " quickly press and release the HK Mega board's Reset button and LED1 should flicker until the upload is completed.
If it doesn't then first power cycle the board by disconnecting the USB end of the FTDi cable so Arduino sees an error and quits trying to "Upload"
then try again to get the timing of pressing the Reset button right.
Terminal on APM, click on Terminal button, as soon as white text appears press ENTER key 3 times, it does work from J2, I have tried it, it works.
Old Oct 21, 2012, 01:54 PM
JNJO is online now
JNJO's Avatar
Joined Jun 2012
...The only thing stopping Arduino upload using J2 FTDI socket Hk Mega board is that there is NOT a 100nF capacitor from the J2 socket DTR to the RESET pin on ATMega2560 [Pin 30]....
...Arduino uses a pulse on DTR to pulse the 2560 RESET via the capacitor, that resets the 2560 and Arduino starts upload before the 2560 times out and boots the application firmware...
...Terminal on APM, click on Terminal button, as soon as white text appears press ENTER key 3 times, it does work from J2, I have tried it, it works....
+3 for the MPNG bible.
Very good info, and thanks for sharing.
Would have taken me a week to even start googling for it.
I didn't even have DTR connected, but I'll try that, with 100nF, next time.
Later,
/J
Old Oct 22, 2012, 05:23 AM
JNJO is online now
JNJO's Avatar
Joined Jun 2012
A0 - a5 i/o?
Now that I have everything working again, thanks to Jabram, I am on the hunt for some more self-inflicted problems.
Did anyone toy with the analog I/O pins A0 - A5? (AT2560 pins 97-92.)
They don't seem to be connected to anything on this board, and at least A0 is used for battery voltage monitoring from a divider, if I read the code correct.
I'm thinking that it can't be to hard to connect a header to those pins, and get easy access to battery monitoring, LED 1-4 and a buzzer maybe.
(Hope the weather clears soon, so I can stop fixing things until they are broke, and fly instead.)
/J
Old Oct 22, 2012, 11:44 AM
jabram is offline
Joined Jul 2012
@/J
I guess until HobbyKing make more of these boards this is going to be a lonely place :-)
Yes, I did notice those pins are not connected, I also considered doing what you suggest, soon realized having a voltage reading is almost useless when one Lipo cell can go down while the overall battery pack voltage still appears to be OK.
Instead I am using the HobbyKing "On Board Lipoly Low Voltage Alarm (2s~4s)", it is VERY LOUD and warns about the state of each individual cell, it connects to the balance lead of the battery, which means you have it connected to something instead of just leaving it flapping about.
http://www.hobbyking.com/hobbyking/s...dProduct=18987
I have it mounted near the battery using double sided tape, when first connected it beeps LOUDLY a few times, tests all Red LEDs then tests all Green LEDS.
I will bore you with a few pictures :-)
Joe
Discussion [UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module benybee UAV - Unmanned Aerial Vehicles 418 Nov 20, 2015 08:32 PM
Help! PROBLEM on Crius AIO Pro Y6 With MegaPirate NG 2.7 R4. RQuad Multirotor Electronics 3 Jan 22, 2013 01:13 AM
Found MultiWii PRO Flight Controller w/MTK GPS Module Koo Aircraft - Electric - Multirotor (FS/W) 4 Oct 11, 2012 12:47 AM
Yippee! New AirStudio universal Flight Controller for Mega Pirate NG and MultiWii AirCopter Multirotor Electronics 44 Sep 10, 2012 05:56 AM
