@ Joe: did you already have a chance to test the new AC2.8 port from Sir Alex?
http://code.google.com/p/megapiraten...e/detail?r=245 |
Australia, NSW, Kendall
Joined Jul 2012
Joe |
Joined Jul 2012
Wait for the slow drop down list in APM Planner to find all USB ports. If you have 3DRadio or Bluetooth make sure it is not already connected to another instance of APM Planner. If all that doesn't work - close APM Planner, unplug USB, wait 30 seconds, plug USB in, start APM Planner select 115200 baud and the correct Com Port, click on APM Planner Connect. |
Australia, NSW
Joined Sep 2006
I have an issue where the gyros are correct but the stick controls aren't. This is how it is currently (quadx config): - pitch forward causes the quad to roll right - pitch backward causes the quad to roll left - roll left causes the quad to pitch backward - roll right causes the quad to pitch forward I have all of the gyros working correctly though, it's strange. I had to change the motor wiring from the standard D2, D5, D3, D6 because it was not working correctly for either stick input or gyros (using this reference http://code.google.com/p/megapirate/wiki/Motors ). I am using turnigy 9x without any firmware upgrade and all trims are zero and channel directions are non-reversed. Edit: The channels all show up correctly in mission planner. Edit2: Actually the artificial horizon pitches when i roll in mission planner. Is there a setting somewhere to reverse the gyros? The board is facing the front of the chopper. |
Joined Jul 2012
If you treat the right side as the front, and wire the motors accordingly, does that work? you may have edit MAG in Arduino code. |
Australia, NSW
Joined Sep 2006
| Thread Tools | |
| Discussion [UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module | benybee | UAV - Unmanned Aerial Vehicles | 157 | May 17, 2013 08:50 PM |
| Help! PROBLEM on Crius AIO Pro Y6 With MegaPirate NG 2.7 R4. | RQuad | Multirotor Electronics | 3 | Jan 22, 2013 12:13 AM |
| Found MultiWii PRO Flight Controller w/MTK GPS Module | Koo | Aircraft - Electric - Multirotor (FS/W) | 4 | Oct 10, 2012 11:47 PM |
| Yippee! New AirStudio universal Flight Controller for Mega Pirate NG and MultiWii | AirCopter | Multirotor Electronics | 44 | Sep 10, 2012 04:56 AM |
