Old Oct 16, 2012, 02:09 AM
chambo88 is online now
Find More Posts by chambo88
1 can never have 2 many planes
chambo88's Avatar
Australia, QLD, Surfers Paradise
Joined Sep 2011
Build Log
900mm epp ju52
hey guys, I'm currently building a model for a friend and thought I should share.. as the description implies it's ju52 (tri motor).
construction is already underway and pics will be up today.
specs:
wingspan: 900mm
weight (390g wet)
engine: x3 1300kv 24g
esc: x3 12amp
battery: 1000mah ( 1300-1800mah 3s pending maiden )
chambo88 is online now Find More Posts by chambo88
Old Oct 16, 2012, 07:15 AM
chambo88's Avatar
Joined Sep 2011
the deal with this plane is.. i build the plane and get it all set for eletronics to go in. then the mate im building it for installs all the electronics.. so far its all goin pretty good.. got the motors mounts, wings are ready for servos, tail section is complete.. only waiting on parts to get in finished up now managed to get som slotted aileron and flaps goin as per the real aircraft.. hopefully you can see it in the pics
Old Oct 16, 2012, 07:44 AM
flyingsquid is offline
Find More Posts by flyingsquid
Joined Oct 2012
Wow.... that looks great. I've got a bit of time before I am able to manipulate foam that way! are you doing this from plans?
flyingsquid is offline Find More Posts by flyingsquid
Old Oct 17, 2012, 11:08 AM
snolord1 is offline
Find More Posts by snolord1
Krued Up
snolord1's Avatar
United States, MA, Springfield
Joined Jul 2004
i like it
keep up the good work
snolord1 is offline Find More Posts by snolord1
Old Oct 17, 2012, 06:03 PM
chambo88's Avatar
Joined Sep 2011
thanks guys... flying squid, no plans really, just copying an enlarged pic from Google images. I'm currently creating a how-to thread regarding the shaping of epp.. incase your interested. not much there atm but I'm planning on starting to build the thread and the plane 2moro.. http://www.rcgroups.com/forums/showthread.php?t=1751888
Old Nov 14, 2012, 09:08 AM
chambo88's Avatar
Joined Sep 2011
ok so here is the semi-complete plane. everything is installed and operating. has 1:1 power at 50% throttle max current draw from all motors combined is 12amps. so im thinking minimum flight power will be around the 5-6amps range whih should give about 10-13 min flight times.. also plannin on upgrading to a 1300mah 3s if the maiden goes well.
AUW is 390g with a 1000mah 3s pack.
here are the pics of the semi finished job. ( the guy im building it for has the task of getting it paint ready )
Old Nov 15, 2012, 02:27 PM
Commander Clumsy is offline
Find More Posts by Commander Clumsy
Proud of Brushless Sprouts
Commander Clumsy's Avatar
Belgium, Flanders, Antwerp
Joined Feb 2007
Not to criticize you, but this plane needs motor cowlings.
Please
I like the slotted aileron and flaps!
Commander Clumsy is offline Find More Posts by Commander Clumsy
Old Nov 15, 2012, 03:05 PM
chambo88's Avatar
Joined Sep 2011
Please
i couldnt agree more.. they arent on just yet becuase of the maiden.. fittment of cowlings and all other "detail items" will be left to the mate i built it for.. maiden is scheduled for saturday afternoon
you'll notice the engine nacelles arent even carved at all..
Discussion Techone PopWing 900mm ARF or KIT Marinoob Flying Wings 0 Oct 02, 2012 07:50 AM
Wanted Wanted reasonably priced 900mm DLG j3d1b3n333 Aircraft - Sailplanes (FS/W) 5 Apr 25, 2012 04:02 PM
Discussion Is this motor right for 450 gm 900mm Extra skittum 3D Foamies 3 Mar 07, 2012 01:22 PM
Discussion SuperYak EPP 900mm span Gadgetman Foamies (Scratchbuilt) 5 Jan 12, 2009 03:07 PM
ju52, 4.85 meter span, 3 lrk's, Ron van Sommeren Scale Kit/Scratch Built 9 Aug 13, 2002 06:57 PM
